Tool Tip: How to Sharpen a Chisel
For many people, chisels are handy little tools...for prying open cans of paint, that is. But a properly-honed chisel is an extremely useful woodworking tool.
Sharpening a chisel is actually quite easy, especially if you use a honing jig. An initial investment of less than $150 will get you chisels, a honing jig and sharpening stones - all of which will likely last longer than you will.
When I was first starting out in woodworking, I assumed that the "sharp" chisel I brought home from the hardware store was ready to go. But just because something is sharp enough to go through your hand if you're not careful does not mean it's sharp enough to take on wood with nice results.
Chisels go through an elementary grinding when being made which simply gives them a beveled edge. Look at the second picture below, and you can see the grinding marks on the main part of the blade. When we're done, the cutting edge will be glassy smooth.
So let's get started!
Step 1Items Needed
Items Needed
There are numerous ways to sharpen chisels. Some do it strictly by hand, while others use a jig. Some sharpen with oilstones, others with waterstones, and still others with diamond stones. Some use a strop at the end. This instructable will demonstrate the use of waterstones and a honing guide, and will get your chisel sharpened to 8000 grit with a microbeveled edge. Now here's what you need:
  • Chisels: I recommend Irwin brand chisels (formerly Marples). Woodcraft sells a set of four for $39.99. This instructable will work for any chisel, but you might need to do it more often for the cheaply-made ones.
  • Honing Guide: A honing guide keeps your blade at the right angle for sharpening. Those who are more experienced go by feel, and indeed you may try this, but I use a jig. The one I use costs only $11.99 from Woodcraft.
  • Sharpening Stones: As I just mentioned, this instructable will demonstrate sharpening with waterstones. I use two combination stones (again, from Woodcraft), that take the sharpening through grits of 800, 1200, 4000 and 8000. The 800/4000 stone will set you back $24.99 and the 1200/8000 stone will cost $49.99.
  • Nagura Stone: If you use a waterstone with a grit of 6000 or higher, you will need a nagura stone. The nagura stone creates the "slurry" that helps sharpens the chisel. The same link for sharpening stones above contains a link for the nagura stone, which you can buy for $9.99.
Total Cost (at time of posting): $136.95. Of course, if you only need one chisel you can knock $20 to $30 off of that total, depending on the size of the chisel you get.
68 comments
1-40 of 68next »
Jan 7, 2011. 4:24 PMDoubleTrouble says:
Firstly, A very nice guide to get people started in sharpening. Glad to see that you went with the water sharpening, IMHO a more precise method of sharpening, less messy and you can more easily get rid of the "metal dust" left on the stone.
             One small item that you forgot to go over that makes all the difference. Being a fine woodworker I am looking for the cleanest cut and the fastest sharpening time. Because of this I flatten the back and sharpen up to the final 8000 grit to a mirror finish before I do anything else. This sets me up for success in my sharpening. Yes, it may take a while but if it is VERY uneven you can even do just 1cm to 1/2 cm near the tip if needs be. Doing an inch or so will save you time in the future and will most likely last a good decade or more. Sharpening any edge too is reducing the material to an infinitely small edge by sharpening or "polishing". Any visible scratches are groves that will leave a serrated edge. The smaller the scratches the finer the sharpening possible. A mirror finish gives us microscopic scratches and a leg up in keeping a sharp tool.
       After sharpening the back up to the 8000, I start on the bevel. 500 (or 800 or whatever) I run it over this level to establish a flat edge, create the geometry of the chisel and get a nice burr going. I then turn it over and with the flattened back I go to the 8000 (eight thousand) stone to "cut off" the burr. You will see it as a darker line on the stone until it disappears and evens out. Then back to the bevel next stone up. Same process and finally when I reach 8000 I have a chisel sharp enough to shave with.
       This seems time consuming but with a little practice it won't take more than 5-10 minutes and leave you with a consistent result. Thanks again for the good Instructable!
Dec 17, 2011. 4:58 PMdent244 says:
Barbers and knife makers take off the burs by rubbing it against a strip off taught leather, maybe that may be better for keeping the bottom flat and removing just the burs
Mar 30, 2009. 10:44 AMthepelton says:
I made a jig for sharpening chisels out of a wedge of wood and some wooden toy wheels. I used an incra jig protractor to get the right angle so that I could lay the chisel on the top of the wheeled edge and roll the whole thing over some sandpaper, and get a wicked sharp edge.
Nov 20, 2011. 4:01 AMLMillerCarver says:
Excellent Tip!
Thanks for the suggestion.
Sep 13, 2009. 6:37 AMDanzeyboy says:
Man alive that looks sharp. My chisels are all chipped and need an expert like you. I'm a plumber so I put them through a lot of nails etc!
Sep 25, 2011. 7:24 PMpfred2 says:
You need one of these:
http://a.imageshack.us/img838/5759/sideo.jpg
Skip the stones!
Oct 12, 2009. 9:09 AMgitm says:
If you're putting chisels through nails you should use what's called a 'cold chisel'. Cold chisels are designed for that sort of thing and look almost nothing like wood chisels. You can find them at Lowes or Home Depot. They are beveled on both sides, each at about 35 degrees from the long axis (about 70 degrees total).
Sep 16, 2010. 8:13 AMwa7jos says:
When you get your chisel where you want it in the guide, score a mark across the face of the chisel at the base of the guide. This will allow you to quickly find the right spot the next time you sharpen.
I use the Veritas sharpening jig. It has a roller on the back with an eccentric cam. Just turn the cam 90 degrees to raise the chisel up 1/2 degree for the micro-bevel step.
Once you get your chisel sharp, it is usually only necessary to hit it with a few strokes of the finest grit to "tune it up".
Feb 7, 2008. 6:17 PMroflmaozedong says:
WOOPS im so sorry! i meant to push the plus but accidentally pushed the minus when i was rating! shoot i hope it can get fixed haha. sorry!!! good instructable!
Sep 8, 2010. 8:06 AMBroom says:
Bwahaha!
Dec 12, 2008. 7:02 AMsee spot run says:
nice Instructable-- couple things for other people to remember -- sharpen early; sharpen often; 1. in step six you say to look for the thin line on the chisel edge. this line is on the bevelled side of the chisel. The back needs to be dead flat. If you see a thin line on the back of the chisel, then it's time to flatten the back again and sharpen. 2. another thing that took a little while for me to figure out is that the stones need to be flattened periodically to keep them flat too. when using a honing guide the center of the stone tends to get dished out because as from the metal rubbing on the stone. the back of the chisel is only going to get as flat as the stone. To "dress" the stones, I rub the wetstone back and forth on a thick piece of glass (3/16" min for me) with some wet/dry sandpaper spray-mounted to it, sprinkled with some water. Typically the ends of the stone rub when first dressing. After a few minutes of work the whole surface of the stone shows wear equally. At this point I know the stone is flat (or at least as flat as the glass.) I got my current piece of glass for free from an architect friend as a 12"x12" left-over sample. my previous piece was a scratched up glass tabletop.
Sep 8, 2010. 8:04 AMBroom says:
Thanks!
Mar 18, 2009. 4:59 PMtrooperdog says:
wow , thanks thats good info ....
Oct 31, 2009. 9:09 PMmauriceh says:
OK, I *KNOW* you will laugh at this, but please think about it:
One of the very best ways to "true' your stones ( making them flat again is called "True'ing" them) is to pour some water on a flat concrete sidewalk, and work the stone on this surface.
I find a "figure 8" pattern is best.
This cuts the stone to flat very quickly and effectively.
Once it is flat, I then finish it with sandpaper, wet, on glass, as you described above. That is just to take out any scratches on the stone.
Sep 8, 2010. 8:05 AMBroom says:
Should work, if you vary the path of the stone a good bit (to avoid an area of cement with locallized wave).
Mar 28, 2009. 3:10 PMezcheese says:
The way I was taught was that a chisel was not sharp enough to use until you could shave your arm with it. To this day my left arm is hairless from testing my plane blades and chisels on it. I use water stones up to 6000 grit and then strop using the palm of my hand. You don't need a leather strop & paste. Its got to be done quick or else you cut yourself though.
Sep 8, 2010. 8:03 AMBroom says:
Easier method (and doesn't deforest your manly arm hair!): rest the edge of your chisel (or knife) against your thumb nail, tilted at a 45-degree angle. Just rest it - don't apply force! If the edge doesn't slide down the nail, it is "biting", and sharp.
Sharper edges will bite on steeper slopes of your nail. But 45-deg is a pretty decent edge.
Nov 19, 2009. 10:15 PMamclaussen says:
 I have found that sharpening with progressively finer wetordry sandpaper over glass is both very practical and comparatively inexpensive.  A flat thick glass piece and the required 3M sandpapers are way cheaper than a set of stones; and you don't need to flatten them.  Only the worst cases of badly dented chisels will benefit from a complete treatment on a set of 3 to 4 stones.
In my case, I bought a somewhat similar adjustable angle guide from "General" brand of tools that uses two small wheels that can roll freely at both sides of the sandpaper strip if you cut it a little wider than the blade to be sharpened, so that they don't have to roll over the sandpaper.  Cutting the sandpaper in those widths gives several strips from every sandpaper sheet, which means even more savings!
To sharpen the narrow chisel blades, I made a wooden base with a lateral guide rail, so that the sharpening guide can roll straight and paralell to the sandpaper strip.
The glass plate is 3/8" (9 mm) thick, which is very rigid and ensures flatness even with some heavy down pressure; and was not expensive since the size is not large.
For me, the glass and wetordry sandpaper is the way to go.
amclaussen, Mexico City.
Sep 8, 2010. 7:58 AMBroom says:
Brilliant.
Jan 21, 2010. 6:39 PMKnexFreek says:
 cool
May 14, 2009. 6:54 PMFuture filmaker says:
Now, I have a question, I accidently put a chink in my blade, so it now has a gap right in the middle, If I used this technique, would I be able to sharpen it back into a blade? (the dink is about .5 centimeters long, and is the shape of a half circle)
May 15, 2009. 4:25 AMFuture filmaker says:
lol, maybe I should just go and ask for help from a professional at my woodcraft store before I ruin my chisel !
Jul 21, 2009. 9:30 PManderekel says:
What I did with my plane blades that had some nicks (bought some used planes) is I had my local sharpening guy sharpen them. He ground out all the nicks for me and cost me 10.50 for three blades. Then I'm gonna sharpen'em back up to nice and ready to use. It's a lot easier than trying to do it yourself and possibly screwing it up. :D
May 14, 2009. 6:49 PMFuture filmaker says:
Man , I love the store "woodcraft"!! And I figured out there is one about 20 miles from my house : )
Apr 2, 2008. 8:35 AMjeff-o says:
Great instructable. I recently had to sharpen one of my chisels and did it with increasingly finer sandpaper. It's good to know that I was at least somewhat on track! Maybe once I own a full set I'll invest in proper stones as well.
Sep 2, 2008. 8:29 AMi.am.flink says:
Many people use only sand paper. Some auto parts stores that cater to mechanics doing restorations that include body work will have extremely fine paper that equates to 12000 grit. The "scary sharp" system is based on sandpaper with an adhesive back applied to glass. You can get a piece of glass for a jalousie window (the slat kind) and some 3m spray adhesive to hold the paper to the glass. An experienced sharpener may mange nicely with only fingers to hold the chisel. Personally, I use a Veritas jig to hold my blades. I'm not using it to get done quicker, mind, I just want it to be right when I'm done.
May 13, 2009. 11:41 AMdawfun says:
I relied on the "Scary Sharp" approach for a couple of years while I built up my skills and tool collection. Once I ran out of sandpaper, I went ahead and invested in "proper" sharpening stones.
This is the original (a great read) on "Scary Sharpening": http://tinyurl.com/gcyg4
May 13, 2009. 1:02 PMjeff-o says:
Hilarious! And informative, too. I'll probably stick with sandpaper for the time being...
Sep 2, 2008. 12:21 PMjeff-o says:
That's sort of what I used. I started with 100 grit and moved up to 4000. It was enough for what I had to do. I don't use my chisels very often, but when you need one it's the only tool that will do!
Apr 15, 2009. 10:45 AMdavid_baines says:
Excellent instructable, thank you. I've been wondering for quite a while how to sharpen chisels properly, and now I'll just have to find all the bits needed. Thanks for the links to the suppliers, I've sometimes seen waterstones in supermarkets, but didn't know where to go to find different grades. I've never heard of nagura stones before. Thanks!
Apr 2, 2009. 11:30 PMeric m says:
These stones cost too much. Why ?
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:offseid
Just a guy who likes makin' stuff!
