Step 2They're Called Waterstones For a Reason
All Steps Viewing
One of the very best ways to "true' your stones ( making them flat again is called "True'ing" them) is to pour some water on a flat concrete sidewalk, and work the stone on this surface.
I find a "figure 8" pattern is best.
This cuts the stone to flat very quickly and effectively.
Once it is flat, I then finish it with sandpaper, wet, on glass, as you described above. That is just to take out any scratches on the stone.
In my case, I bought a somewhat similar adjustable angle guide from "General" brand of tools that uses two small wheels that can roll freely at both sides of the sandpaper strip if you cut it a little wider than the blade to be sharpened, so that they don't have to roll over the sandpaper. Cutting the sandpaper in those widths gives several strips from every sandpaper sheet, which means even more savings!
To sharpen the narrow chisel blades, I made a wooden base with a lateral guide rail, so that the sharpening guide can roll straight and paralell to the sandpaper strip.
The glass plate is 3/8" (9 mm) thick, which is very rigid and ensures flatness even with some heavy down pressure; and was not expensive since the size is not large.
For me, the glass and wetordry sandpaper is the way to go.
amclaussen, Mexico City.
