3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Toolbox Saddlebags for under $20
  • last photo ←
Time and time again I find myself having to pack my rain gear with the loads of other misc. items into my backpack and hope they all fit.
I've always knew that I wanted to use saddlebags to solve this problem but I could never convince myself to dish out $80+.
So I discovered that the most economical and effective alternative was to use toolboxes.
They can be locked and waterproofed but best of all: they're cheap.
Note: These particular toolboxes are NOT waterproof. Use your discretion as to how you'd like to use them and make improvements/adjustments according to your needs.
Step 1Gather your tools and materials
Of course, a great toolbox saddlebag starts with the toolbox. I picked up two 16" Workforce toolboxes from Home Depot for $7.47 each (amazing yeah?). That's about $15 already. (The 22" Husky toolbox will be for another instructable ;) )
Next, pick up the misc. nuts, bolts and flat/lock washers. I've estimated it to run about $5 but I just found them around the garage (FREE!).
Lastly, you'll need to do some minor custom metal work in order to form a rack for the toolboxes to be bolted onto. I had a couple of old refrigerator racks that I had cut to sizesuper heated with a blow torch and bent into shape. Have fun but be safe! (Fiiiireee gooooood.)
It helps to have a screwdriver with drill bits and pliers of some type to bore holes into the toolbox and tighten the screws/nuts.
24 comments
Nov 14, 2011. 2:00 PMspeedhump says:
One of my toolboxes is the same as the one used by Kamiana8. Not a good choice. They leak through the handle attachments.
Oct 27, 2011. 7:10 AMkarlpinturr says:
Nice idea!
I did a similar thing 25-30 years ago, and put a motorcycle topbox on a very badly homemade bike rack. It didn't last long, as I was permanently overloading it. Eventually the rack collapsed, taking me down and cracking the topbox beyond repair (at that time - I might have been able to resurrect it nowadays) on the road. Still...
One question - I have some similar-looking toolboxes to yours, but the rain gets in through the point where the handles join the lids - do you have a way to solve that?
Oct 28, 2011. 6:33 AMkarlpinturr says:
Oops! - Slight misunderstanding there (my bad!) - it was actually a pushbike, not a motorbike.
And the mopre I think about waterproofing the toolboxes, the harder it is to see a solution that won't end up costing more than the boxes, themselves (though it should still work out cheaper than buying something new).
For now, a hole in each corner is probably best.
Oct 28, 2011. 11:50 AMagis68 says:
excellent brilliant excellent and relativly cheap.....5/5.... 4 for giving me the idea to do something same on my Rebel....(not toolbox but little bigger) 1 for the project.....!!!!!!
Oct 27, 2011. 6:34 PMjhamilton-1 says:
I wonder if this would be a bit cleaner if you used a more conventional approach to building the mounting brackets. I love the idea of using toolboxes.
Oct 28, 2011. 7:10 AMTeauxni says:
Then consider webbed strapping with the quick release closures. You could even have one end of the closure permanently on the bike and the other permanently on the rack. The only problem I haven't figure out yet is how to make that theft proof. I'll keep thinking.
Oct 27, 2011. 7:37 PMBrunomaster says:
No podes ser mas groncho y cochino.
Oct 28, 2011. 5:19 AMLorddrake says:
google translate gave me
"You can not be more groncho and pig."
when i plugged it in .. i guess it losses something in the translation lol.
Oct 27, 2011. 7:18 PMTeauxni says:
Looking at your clothes pin photo, I'm thinking that more bolts, washers and some spacers, (could be wood, pvc, or thick foam insulation) would make that a more permanent solution. It seems the clothes pins will shake loose after a while. Great job on this!
Oct 16, 2011. 10:31 PMbadpanda says:
Nice work! Check these out, same concept with ammo cans I did a while back. http://www.instructables.com/id/Ammo-Can-Saddlebags/
Oct 15, 2011. 9:37 PMWareShoals says:
Nice work! I had a lugage rack on my Kawi and used a tool box as a trunk. Nice touch using a refrigerator rack for a support. That was a good idea.
Oct 13, 2011. 10:41 PMl8nite says:
before MacGyver this would have been called redneck engineering either way its a great idea . For a little more money you could use large fishing tackle boxes, they are even more leak resistant and the larger ones have removable bottoms.. WOW the possibilities,,,,,,,,,,,,
Oct 14, 2011. 6:04 PMtyeo098 says:
Or 30/50cal ammo cans.
Oct 14, 2011. 4:58 PMPhil B says:
The hose clamps are a handy and inexpensive way to hang the refrigerator racks onto the motorcycle. I would encourage you to make friends with someone who has a welder. I have one and am always glad to help someone out who needs a couple of simple welds for a useful project. People who have welders are quite often looking for excuses to use them. And, your friend may even be willing to give you some "lessons" in welding. Later, when you can afford a welder, yourself; you will be more ready to make good use of it. That is just a thought.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Kamiana8
