Time and time again I find myself having to pack my rain gear with the loads of other misc. items into my backpack and hope they all fit.
I've always knew that I wanted to use saddlebags to solve this problem but I could never convince myself to dish out $80+.
So I discovered that the most economical and effective alternative was to use toolboxes.
They can be locked and waterproofed but best of all: they're cheap.
Note: These particular toolboxes are NOT waterproof. Use your discretion as to how you'd like to use them and make improvements/adjustments according to your needs.
Step 1: Gather your tools and materials
Next, pick up the misc. nuts, bolts and flat/lock washers. I've estimated it to run about $5 but I just found them around the garage (FREE!).
Lastly, you'll need to do some minor custom metal work in order to form a rack for the toolboxes to be bolted onto. I had a couple of old refrigerator racks that I had cut to sizesuper heated with a blow torch and bent into shape. Have fun but be safe! (Fiiiireee gooooood.)
It helps to have a screwdriver with drill bits and pliers of some type to bore holes into the toolbox and tighten the screws/nuts.
CHECK OUT THE REVISED VERSION: http://www.instructables.com/id/Revised-Toolbox-Saddlebags-for-under-20/
Step 2: Form a rack
Use whatever you can find around the garage that would make a suitable rack.
As I have mentioned, I found an old refrigerator rack and macgyver-ed something together.
The general shape would suit this particular toolbox best because it will allow you to open the box while fully extending the top cover.
I used a blow torch to super heat the metal and bend them into these shapes.
Step 3: Bolt the toolbox to the rack
Once you've got the holes where you need them, bolt the toolbox to the rack.
Step 4: Attach the rack to the bike
I used 4 pipe clamps to attach them to the bar but of course, unless you have the same bike, you might have to find an alternate method.
The clothespins (another macgyver invention I've come up with) acted as mini shock absorber and dampens the vibrations from a bumpy road. To my surprise, it actually worked haha!
That's pretty much it!
Maybe grab a couple of locks and keys, paint it a different color and you're set.
I've managed to fit my rain gear comfortably and there's still room for more.
Comment and rate please and let me know if you've got some ideas to improve the design or created your own! :)
Step 5: Other useful information
To remedy this, I simply wrapped a bungee cord around the box or better yet, a strong length of string and secured it to the bike's frame. This way, much of the stress is shared between the hose clamps and the bungee/string and the toolbox does not have to bare the full weight of the cargo being loaded. This method has reduced (maybe even eliminated) the need to periodically replace worn out hose clamps with new ones.
I was thankful enough to discover a hidden benefit to having these toolbox saddlebags on my bike and I'd like to share it with my viewers. I've had the unfortunate experience of seeing my bike toppled over onto its side due to high winds while it was parked on it's side stand. My bike is not equipped with a center stand (which may have helped, but I don't know). Nonetheless, the structural damage done to my bike was significantly reduced thanks to the saddlebags. The toolboxes absorbed the impact (bare in mind it did damage the toolbox but not beyond repair) and prevented further damage to the motorcycle itself. I was able to unhook the hose clamps, bend the refrigerator racks back into shape and re-attach it to the bike again. I rode back home without any problems and was able to heat the toolboxes and shape them back to it's original design and it still works haha! I was too cheap to just buy a brand new $7 box but oh well, I guess I ended up with a savings of $7.
Visit Our Store »
Go Pro Today »
I plan on a similar idea with 2 old Samsonite train cases. We all know how durable those are!! Plus they lock, and have a tray inside for small stuff. They look like hard bags anyway... not sure if they are water proof though. One fits great on my luggage rack too. I just bungee it on.
Picked them up from local thrift store for under 5 bucks. Guess larger suitcases would work too, but my bike is pretty small (vt500). Stuck some reflectors on the back to make them look "official". Would pipe hanging straps work to mount them?? Could wrap the bottom with old bicycle inner tubes, or heater hose to absorb some of the shock...hmmm...
You could get some velcro to attach a piece of leather or vinyl to the top of your tool boxes and fashion a sort of "do rag" for the top. Wrap it down and around over the latch and velcro or snap into place. Or attach it through your racks with hammer on snaps. (sort of like a hinge) Snaps are available in heavy duty for tarps etc...
Love making something out of nothing - and thankfully there are an abundance of thrift stores in Denver to supply my creative larks.
Oh! I just realized hard plastic coolers would work great too, and they would be waterproof. Just put a toolbox hasp on to lock them up. You could paint to match your bike. A friend of mine "dumpster dives" and has a garage full of cool junk to build stuff with. Check your local apartment complex at the end of the month when people are moving out...
Oh, I'm gonna love this website. :D Thanks guys
For the waterproofing problem on my toolboxes I just hot glued the holes from the inside-out and it's working pretty well so far. Not to mention it's a cheap alternative to doing all this fancy stuff with fabrics and such which I'd never be very good at haha
I did a similar thing 25-30 years ago, and put a motorcycle topbox on a very badly homemade bike rack. It didn't last long, as I was permanently overloading it. Eventually the rack collapsed, taking me down and cracking the topbox beyond repair (at that time - I might have been able to resurrect it nowadays) on the road. Still...
One question - I have some similar-looking toolboxes to yours, but the rain gets in through the point where the handles join the lids - do you have a way to solve that?
As far as waterproofing it, my best idea right now is to grab some kind of water-repellent-type fabric that would fit over the toolbox (think "umbrella") and sew on a drawstring; this should allow you to seal it shut and in theory, keep the water out.
I'm trying to work on this solution myself since I totally understand your problem as I had water collect in my toolbox before. At that time it was dark and I was too tired to get upset or fix it so I just drilled a 1/16" hole through the bottom of the toolbox and drained the water haha I'm much more adamant on finding a solution now and I look forward to posting my results.
And the mopre I think about waterproofing the toolboxes, the harder it is to see a solution that won't end up costing more than the boxes, themselves (though it should still work out cheaper than buying something new).
For now, a hole in each corner is probably best.
I'd be crazy enough to take apart an umbrella and see how that works haha
"You can not be more groncho and pig."
when i plugged it in .. i guess it losses something in the translation lol.
