Introduction: Toolholder for 3mm Tools and Bits
Picture of Toolholder for 3mm Tools and Bits
Some small build in between: Nothing special, just a rough description and the design files.
Here are the design files for a toolholder for 3mm Tools (for Proxxon, Dremel etc) and Bits. Just take the design files and cut them with a lasercutter out of 5mm material. If you need storage room for other tools, just change the holes in the thin pieces. Best way is to align them with the holes which are already there, then delete the original one.
The cutted parts are then glued together (in this case it was 5mm poplar plywood with a cherry tree staining). For the tool holder there are just one thin piece of wood for each line of tools (which are long enough such that the backplate holds them in place), while for the bit holder a second piece of wood without holes prevents the bits to fall out of the bottom.
Additional holes kann be drilled into the backplate to mount the system on the wall. Done.
MsSweetSatisfaction (author)2015-02-21
Hello, and welcome to the Instructables community!
It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables.
Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable.
Successful projects on Instructables include:
- clearly written details of a finished project with instructions
- proper spelling and grammar
- pictures of the project that you took yourself
I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note.
Also, we like to feature and reward pro memberships to really well done projects. If you want to see what we look for, check out here!
Thanks for your submission and we hope to see your project published soon!
About This Instructable
230views
9favorites
License:
Bio: ... found out that the FabLab Aachen has a Laser cutter and a PCB mill (and other fun stuff of course), decided to stay there for ... More »
More by janth:Color-changing Laser Cut JeweleryAcrylic Description Sheet With LEDAcrylic Rainbow Flowers
Add instructable to:
