If you have a quarter from 1964 you're in luck because you can make a silver ring, but if not you can make a bronze and nickel ring. This project will take about about an hour and after that you will have a fine looking ring that you can show off to all your friends.
Remove these ads by
Signing UpStep 1Tools Required
1. Hammer
2. Dremel
3. Dremel diamond encrusted drill bit
4. Dremel sanding wheel
5. Gloves
6. File, optional
7. Quarter
Either way I guess if it did grow bigger I'd have to use a half dollar then so I guess it saves me a quarter doing it the way I am now. Anyway, nice ible and nice finger too.
Paint the whole ring with nail polish, and scratch out a little design. Take a 9v battery and wrap the positive and attach it to the ring ( scrape the side of the ring where you attach it for connection). Get a small bowl and fill it up with water and table salt ( I used margarita salt; all I had available at the time) and mix it with the water. Submerse the ring and drop the negative lead in, and wait about 5-6 hours.
Smaller designs etch faster this way but for bigger designs, take a q tip and connect the negative lead to one of the cotton sides about a 1/4 from the end. Dip it in the solution, and etch away. I have seen people use a stronger power source such as a car battery charger but whatever floats your boat. Don't breath in the gas emitted from this by the way. (Not responsible for whatever happens).
-hostic
It's not pedantry. Suppose you were trying to figure out something written in French, with just a little knowledge of that language. If the writer misspelled many of the words, or didn't use standard grammar, you would have a really difficult time figuring out what they wrote, since dictionaries couldn't help you.
