Introduction: Tools Wall Mount
About: Hey! My name is Roey Leon, from Tel Aviv, Israel. On my free time, as a hobby of mine, I love building stuff from scratch. It always starts with a crazy idea, and then I realize that it`s too Dangerous / Unach…
Hello everyone
We have a small warehouse ,  all our small projects and repairing takes place over there
But the problem is we don't have any organized place to store the tools , they are all over the place, part of them ware mounted on this wall , and the other are somewhere else.
I decided to do some Building and solve this issue.
So i decided to build a Wall Mount
Step 1: Buying Woooood
Went to a wood-house and bought a few 3.7 Meter woods
Step 2: Cut It to Fit the Car
Cool saw
Step 3: In the Car
Step 4: The Look Before the Project
I took a snapshot of how it looks before , catastrophic
Step 5: Create Back Boards As a Spacer
Step 6: Putting the Boards Together
First , drill holes  , make sure you mark the center points of the board
Step 7: Create Custom Bolts
Make sure you measure the size of the bolt using a Caliber
Grab it with the clamps , and cut it using a saw
Between the Clamps and the Bolt i rapped it with some fabric in order to keep the screw thread complete.
* if you wont do that rapping issue , you will encounter problems when you are screwing the nut
Step 8: Custom Bolts Ready
Step 9: Attach Back Boards
Step 10: Drill Holes in the Wall & Mount the Board
Step 11: Saw the Board in Order to Fit to the Faucet Location
I Have Ordered a new Faucet , will arrive shortly  ( Will update the picture )
Step 12: Create a Small Board for Screwdrivers
Grab the board with claps , then start drilling
Step 13: Create Another Board for All the Drillers
Same here , grab it with clamps and drill
Step 14: Create Another Board for All Small Bits
Step 15: Create Another Small for the Little Grinding Tools
Step 16: Start Hanging the Tools
In order to hang the tools, you can use two methods .
first one , with screws , just drill them and hand on them the tools
Second one , with an iron wire ( in picture ) , cut it into small 8 cm pieces , drill a hole first and then Knock it in with a hammer.
 i chose the second option due to the fact that it is less likely to crack the Board and will look better
Step 17: Soldering Iron & Hot Glue Mount & Wall Plug
created two mounts, for the Soldering iron and the Hot glue..
and more over i added an external point electrical outlet  ( the electrical wire goes behind the board )
Step 18: Almost Done
I have ordered plenty of other useful tools , they will arrive in a few days, and then i will update the Post
Till then , i`m done
Furniture Contest
Furniture Contest
