Step 2: Adding the knock
To do this you will need to utilize your hack saw and file set. Clamp your arrow to your workbench. With your file (I used the triangular file) file a starting groove for your hack saw. Make sure that this is perpendicular to the direction of the grain of your arrow. (A) After that, cut down approximately half an inch with your hack saw. (B) Use your hobby files to widen the cut until it looks like image C . Ignore the string at the base of the nock, that is from a later step. Use your sandpaper to smooth out the nock, remove any splinters or rough edges, and slightly taper the entrance to make nocking easier.
If you're like me and do not have access to a workbench, I was able to cut my nocks by holding the shaft between my knees, stabilize it with my left hand, and cut the nock with my right. You will have to turn the shaft 180 degrees every few strokes in order too make sure the cut does not angle to one side of the shaft or the other.
At this point you can stain your shafts whatever color you like and add whatever finish you like. I used Tung Oil to make my arrows more resistant to the elements.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
