Tools Needed for Projects
1,241
28
Posted
Introduction: Tools Needed for Projects
If you going to be making projects you need the right tool for the job. Tools can be expensive I slowly started gathering tools as I needed them for projects. Also keeping your tools organized is very important in saving time when you need to find and use them. I have a main tool box that is good for transporting. mount power tools is a good organizer and cool to display and easy to find along with saving room
this peg board works great
Step 1: Tool Box
24 inch portable Tool box
american wrenches
metric wrenches
pipe cutter
staple gun
staples
protractor
tape measure
stud finder
wrench and bits
torque wrench
can opener
plyers
scissors
flash light
alan wrenches
duct tape
hammer
rubber hammer
drilll bits
bit gage
sharpe marker
hole cutter
wire nuts
butter knife
oil/lube
compass
razor blade
cutter
zip ties
level
caliber
calk gun
Step 2: Electronics Kit
Tool box
multi meter
wire strippers
wire cutters
small needle nose pliers
wires
connectors
arduino
bread board
switch
battery packs
resistors
capacitors
leds
lcd display
helper clamp
solder
solder wick
buttons
raspberry pi
banana plugs
female banana plugs
fans
Step 3: Power Tools
Power tools
cordless drill
drill
jig saw
cicular saw
finishing sander
recipricating saw
heat gun
Step 4: Glues
white elmers glue
super glue
wood glue
rubber cement
silicone
pvc cement/glue
glue brush
Step 5: Bench Tools
solder iron
power supply
cordless drill battery charger
12 volt battery charger
easy access tool box
bench fan
bench light
static mat
Step 6: Survival Tools
Survival Tools
bolt cutters
hatchet
axe(needed)
hand bow saw
sponge
face mask
bungie cords
cordage
can opener
first aid kit
bandana
flashlight
hand warmers
poncho
compass
knife
utility knife
lighter
magniesum fire starter
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    Tools are toys.
