3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Topsy Turvy Tomato Planter Stand
 This is a stand I made to hold a "Topsy Turvy" tomato planter. These planters work great but the problem is they weigh 50+ pounds when full. Since I could not hang it off a shepards hook I came up with this. Its made from 2x3's and is 6 feet tall. The base is 4'x4' and the top piece extends out a foot from the rest of the stand. Everything is held together with two and a half inch decking screws. It held up all year in 30+ mph winds. Currently the tops turvy is home to a birds nest.
10 comments
May 27, 2011. 5:09 PMPizzapie500 says:
Why are my plants growing upwards instead of downwards?
May 9, 2011. 10:04 AMgardenhack says:
clemsonguy1125 - Thanks for the idea! Built one this weekend with my father-in-law - a proud Clemson alum. Used 2 pressure treated 8 foot 2x4s, 2 1/2" deck screws and a few galvanized decking corner braces for the frame. For the planter, I found a basic 3-gallon planter, 10 ft of galvanized 3/32 " steel wire rope and a few wire rope fasteners. It appears fairly sturdy and I'm hoping it will withstand the elements.
May 10, 2011. 8:17 PMgardenhack says:
Thanks, I hadn't even thought about risks from pressure treated lumber. Happy to learn that arsenic treated lumber has been phased out. The wood I purchased was treated using a Micronized Copper Azole (MCA) process. This seems to be the environmentally preferred pressure treatment which appears to be safe for gardening applications. But, I'm by no means an expert and will need to do some more research. To be safe, I may add a drip shield to keep water from dripping directly into the planter from the wood brace.
May 1, 2011. 12:34 PMpbiehler says:
looks like the top corner is trying to come apart. :/ I have been trying to figure out something like this cause right now mine it up under the roofs edge outside on the patio. I have tomatoes in it now and there are vineing types in the top and one the lower row is larger one. lol I know they will probably not sork together but trying something different. Will keep an eye out for your next one . ^.^
May 5, 2011. 12:21 AMpbiehler says:
It still is a great Idea. ^.^ I was thinking that if you brace it with a metal bracket of sorts it should give support from the problem. But if you already have it under control then never mind . ^.^ Have a great day crafting things. ^.~
Jun 13, 2010. 4:10 PM1-2BGardening says:
nice idea and thanks for sharing but in this format I couldn't save the instructions :-(
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:clemsonguy1125
