3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Torchiere Light Misbehaving?
Using too much power? Creating too much heat? Stopped working? In general being a bit of a fire hazard as well as making you feel guilty for pulling more than your fair share of electricity from the power grid?
Mod it with a compact fluorescent light (CFL)!
As nice as they are (and that's pretty nice), many torchiere lights use 300 watt halogen bulbs. They also generate lots of excess heat. With this mod, you can replace the 300 watt halogen bulb with a 25 watt CFL. This will improve the efficiency several times over. Plus, the CFL generates less heat, so air conditioners won't have to work as hard in the summertime.
As a bonus, the light will no longer be a fire hazard.
As an extra bonus, if just 1 million American households do this mod, there will be so many wattages saved, it will too many for me to count, wait, perhaps I can count it ... 1 million x 275 watts x 1 hour per day = 275 million watt hours every day. Or in more common parlance, 275,000 kilowatt hours. And that's assuming that there is only one light used for only one hour in only 1 million households. It's likely much more than that. Plus, there is a significantly smaller amount of heat generated -- less heat for the AC system to deal with. Now, is there someone out there smart enough to quantify the amount of electricity saved due to lower air conditioning loads?
Here's a related instructable that I found AFTER I made this one. Really. http://www.instructables.com/id/EVC73BPF2FRV6W6/
Step 1Parts and tools
You will need a torchiere light. I like to use the older style that has an on/off switch instead of a dimmer switch. You can even use one that has stopped working since the most likely point of failure is the halogen bulb-to-socket connection. The dimmer-switch style may not be very friendly to compact fluorescent lights (CFL). If you do use a dimmer-style, always turn it up to full power, or better yet, use a "dimmer-compatible" CFL. (Note, according to http://www.instructables.com/id/EY6SM8KF4DEPVX1/ using a non-dimmable CFL in a dimmable fixture is hazardous.)
Part list:
Indoor/outdoor pigtail lamp holder (about $2)
Two wire nuts
Two cable ties
Electricians tape (don't get the cheap stuff)
Compact fluorescent light (CFL)
Tools list:
Phillips screwdriver
Wire cutters
Utility knife
14 comments
Oct 3, 2008. 11:32 AMneuralstatic says:
nice idea. how well concealed is the clunky cfl bulb in the shallow dish of the torchiere? (i'm not all that tall so that might help) they make light sockets with a little L bracket that's bendable... you could probably get that on the center nut to keep it more rigid than the ziptie? right behind me i have that steel racking with g4 towers just like in your picture -- i better do the mod!
Feb 13, 2008. 8:30 PMwingman358 says:
I just did a halogen to CFL conversion with my torchiere. I replaced the halogen with two 60w CFL's. I used this instructable and another similar instructable. Took me about 15 easy minutes. Thanks for the idea and great instructable!
Oct 12, 2007. 8:02 AMThe Lightning Stalker says:
Just in case you didn't already know, they make fluorescent torchieres that use the big 2C & 2D bulbs and are almost as bright as the halogen ones. They're a bit dimmable. If you're going to buy a new torchiere, they're definitely the thing to get.
Aug 24, 2007. 5:20 AMthecheatscalc says:
ahahaha, I dunno why, but I thought that you were going to replace the pole of the lamp with those long tube florescents! But, I didn't know those things had halogens on top! that's not a fire hazard...
Aug 25, 2007. 7:02 AMthecheatscalc says:
I've seen the fire hazard of halogens in person. Someone I knew tried to dim his light by sticking some clothing over it. I didn't know it was a halogen and so we went with it. a minute later the rooms filled with smoke and we're dealing with the flaming underwear. I can just see bugs catching on fire with those things. Halogens are great, just they get really hot... and if not used carefully are a huge hazard.
Sep 2, 2007. 8:39 PMjongscx says:
Sadly, that was one of my favorite pastimes, we'd sit out on the porch with a torchiere on and watch the puffs of smoke as moths and whatnot got to close to/fell into the intense light.
Aug 31, 2007. 2:13 AM_soapy_ says:
Almost anything that is hot will do this though, and anything that gets very warm will get way hotter if you put insulating undies over it! Even a regular light bulb or a regular bulb replacement fluorescent will get hot enough to cause problems if you block the air flow. And never dump your clothes on the floor on top of your power strip with a couple of wall warts in it, as it might burn things!
Aug 19, 2007. 10:44 PMVertigo666 says:
hey we have that exact same one At least, we did I still have the black version
Aug 20, 2007. 6:46 PMVertigo666 says:
Hey thanks!
Aug 20, 2007. 12:03 AMmsthursday says:
It would be nice to see a picture of the final lamp (from the top) with the heat shield in place. Great Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:McSensei
