loading
Step 10: Listos para la primera prueba! (ready for first test!)
El taladro est� ubicado en su lugar, aunque por el momento no lo usar� como motor sino simplemente como sost�n para poder girar la pieza a mano. �Chicos, no hagan esto en casa!
La hoja de la amoladora est� en posici�n horizontal porque me resulta m�s c�moda. Como no tengo en mente ning�n dise�o en particular, puedo tornear "lo que salga". Es solo para probar.
Por otra parte, la posici�n horizontal no produce arrastre de la pieza en el sentido de giro, lo cual es MUY PELIGROSO.
The drill is located in place, although currently I don't use it as an engine but merely as a support for rotate the piece by hand. Guys, don't do this at home!
The blade grinder is in the horizontal position because I find it more comfortable. As I have no design in mind in particular, may become "what comes out." It is for testing only.
Moreover, the horizontal position does not produce drag the piece in the direction of rotation, which is VERY DANGEROUS.
<p>well done, just one remark I would add a metal plate around the circle saw in order to protect your hand. <br>To be honnest, I find the last images where you turn the drill around, only inches from the spinning saw, horrifying.<br>Should you glance on the saw with a finger, the damage could be considerable....</p>
<p>You are a genious sir. I feel linked to you in some way because we &quot;third worlders&quot; simply don't have money to burn on new materials and tools, so we collect any scrap and junk to transform it. I must follow such genious.</p><p>Usted es un genio. Me siento allegado a usted en cierta forma porque nosotros los &quot;tercer mundistas&quot; simplemente no tenemos el dinero para gastar en materiales nuevos y herramienta, as&iacute; que reunimos cualquier pedacito o chatarra para transformarlo en algo nuevo. Debo seguir un genio as&iacute;.</p>
<p>Amigo mexicano, gracias por los elogios pero no es para tanto. Diariamente &quot;meto la pata&quot; montones de veces, hago cosas in&uacute;tiles que deber&iacute;a tirar a la basura pero quedan dando vueltas por ah&iacute; y ocupando lugar, etc, etc. Pero soy feliz haci&eacute;ndolo, acertando algunas veces aunque sean proporcionalmente pocas. Me gustar&iacute;a tener un galp&oacute;n grande y confortable en vez de mi peque&ntilde;o tallercito atestado de cosas viejas, pero tambi&eacute;n debo reconocer que hay muchos otros m&aacute;s inteligentes y trabajadores que yo, y que no tienen nada. </p><p>Veo que eres m&uacute;sico, y encima, compositor. No sabes cu&aacute;nto envidio a los buenos m&uacute;sicos. Durante a&ntilde;os he tratado de aprender m&uacute;sica, con muy poco resultado. Tengo buen o&iacute;do, pero mis dedos y mi cerebro no est&aacute;n a la altura de lo que se requiere para producir interpretaciones aceptables a la guitarra o al teclado. Me voy a meter de cabeza en tu p&aacute;gina para bajar lo que pueda. Afortunadamente tengo un nieto y una nieta (o dos) que tocan el piano, el contrabajo y la bater&iacute;a, y puedo acudir a elos para que interpreten tus partituras. Durante un tiempo jugu&eacute; con MIDIs, y ver&eacute; si puedo bajarme un editor gratis para escuchar tus partituras. Un abrazo!</p>
<p>Veo que no tengo que hacer nada, solo darles &quot;play&quot; a tus partituras. Gracias por poner tu m&uacute;sica al alcance de los dem&aacute;s.</p>
<p>Muchas gracias. No soy compositor, s&oacute;lo arreglista. Mis partituras est&aacute;n escritas con &quot;Musescore&quot; que es un programa gratuito para editarlas.</p><p>Yo no estudi&eacute; m&uacute;sica propiamente dicho, me tom&oacute; varios a&ntilde;os aprender por mi cuenta lo que ya s&eacute; del piano. Usted podr&iacute;a tal vez aprender por su cuenta sin que nadie lo presione con cosas complicadas. Si tiene buen o&iacute;do se le facilitar&aacute; bastante.</p>
<p>S&iacute;, cuando tengo a mano un piano, algo saco, pero mis interpretaciones, por m&aacute;s que las repita cientos de veces, son totalmente desprovistas de gracia. Ni hablar de piezas dif&iacute;ciles, hay varias melod&iacute;as que por m&aacute;s que intente no tengo manera de sacarlas. &quot;Lo que natura non da...&quot;.</p>
<p>Mi m&uacute;sica no es compleja. Mi secreto est&aacute; en la interpretaci&oacute;n, en la &quot;expresi&oacute;n&quot; al tocarla. No busque complejidad o perfecci&oacute;n, busque la interpretaci&oacute;n. Lo dem&aacute;s llegar&aacute; despu&eacute;s.</p>
Great! <br>Excelente!.... simple, sencillo, economico, para poco uso... pero, a fin de cuentas, para TENERLO cuando se ocupe...
Gracias, padbravo.
Now I know I'm far from being the sharpest tool in the shed, but even I know that there are much safer ways of making a lathe and turning wood. I'm not being rude or anything, but there are easier ways to make good looking works of art, without losing a finger, or hand, or maybe even your life. And I'm not talking robotic wood turning, thats just wrong.
Clearly you have not even looked at all the pictures, because otherwise you would have realized that the insecurity problem is already solved. I have all my fingers still in their places. <br> <br>Thanks for your concern!
Creo que es preocupante es la misma que la m&iacute;a la amoladora cuting de madera <br>puede ser peligroso verry yo s&eacute; de un amigo que el diente del disco se desprendi&oacute; y mat&oacute; a su hija
I agree, these cutting discs are very dangerous.
Hola Rimar. Muy bueno el torno! Me interesa saber c&oacute;mo hiciste los aros del Portamotor, portacontrapunta y portaherramienta. Quiero hacer un aparato similar pero para un dremel. Gracias. Mariano
Hola marianov. Gracias por tu comentario. Los aros los hice &quot;a martillazos&quot; con varilla de 1/2 x 1/8. Si hubiera tenido de 1/2 x 1/16 usaba esa. No es f&aacute;cil hacerlos de esa manera, pero no he podido descubrir una manera efectiva y sencilla de hacerlos.<br> <br> Este &quot;torno&quot; (demasiado presuntuoso el t&eacute;rmino) lo tengo medio archivado porque para tornear madera uso <a href="https://www.instructables.com/id/Mejoras-a-mi-KISS-lathe-my-KISS-lathe-upgrades/" rel="nofollow">el otro</a>, y este tiene el inconveniente del bochinche que mete, con el taladro y la amoladora funcionando al mismo tiempo. Lo reservo para las cosas que el otro no puede hacer.
Buenismo amigo, muy pr&aacute;ctico. Hace tiempo lo hab&iacute;a visto pero estaba un poco exceptico, ahora soy un creyente total, te felicito.
Bueno, gracias. Te lo vendo!
que bien men, eso es usar los recursos, gracias
Gracias, jorozco. Lo tengo medio abandonado a ese torno, me entusuasm&eacute; con el otro (https://www.instructables.com/id/My-KISS-lathe-mi-torno-HSE/), que tambi&eacute;n est&aacute; moment&aacute;neamente dejado de lado hasta que le haga un variador de velocidad.
buen trabajo! tambien me gust&oacute; el relato. muy entendible , parecia platica
Gracias, JOKERFIRE! Instructables me ayuda a aprender ingl&eacute;s.<br>
Amazing work. Very inspiring!!!. Thanks for such a clear instructable :)
I love your work, Rimar. <br><br>Incidentally, when you commented on my instructable, I did not realise that you do not speak English.<br><br>:)
Thanks for the compliment,Tinworm. <br><br>Latest data I have done some accessories for the lathe: a counterpoint, a plane chuck and another threaded for wood works. I will add photos to the instructable.
Question: how do you keep the piece stick to the drill? just using bolts? this would not let ugly unwanted holes at the final piece? considering wood work...<br>
Somewhere above I say that this lathe is by no means a finished piece. For the moment, it is as you say: the piece ends with three ugly holes that must be removed or refilled. Later I will make one more adaptable chuck. Thanks for your comment!
Rimar, this is sad.<br> A option would be using a bracelet to hold the wood in place, but I dunno how wel it would fit. the piece could end up flying around and hitting someone pretty hard...&nbsp;<br> <br> plus, I think a little moster cutting would be more precisely, that saw scare me as hell... hehehe I may do one in future, as I like to work with wood, maybe I put a eletric 3/8'' eletric drill with a smaller cutter, or a saw with a smaller cut disk...<br> <br> fala portugu&ecirc;s? ou s&oacute; espanhol e ingl&ecirc;s?<br> <br> anyway. nice job!<br> <br> PS: I dont know how a real lathe hold the piece stick.... if so, I could make something and tell ya... maybe with some research...<br> <br> g'luck finishing this. I wann to see the new updates =}
Maurice, I speak only spanish. I use on line translators to write in English. Portuguese is easy to understand, it is more alike Spanish than English. I spent two weeks in Sao Paulo, and at times I did not realize that they speak to me in another language. Educated people pronounce the Portuguese very clearly, and one who speaks Spanish can understand almost everything. Now to the issues of the chuck to hold a piece of wood: there are plenty of ways to do it, you choose the one that suits you. Maybe you want have more than one chuck, for use according to the size of the piece. It is not the same turning a dish that a chess piece.
yeah, I see that, anyway, I'll have to way some more to build mine, I'm changing to a new house... more a couple of weeks and I'll be ready to put this on world... and... I have problems with spanish, more than english... so if anyone speaks with me in spanish, I run away screaming... hahaha keep safe! ;-)
muy bien apparato! gracias para tu nuevo invento! sorry for my espanol! my father who speaks spanish fluently did not teach me very well...
Gracias. No es tan malo tu espa&ntilde;ol, por lo menos se entiende... (Thanks. Your Spanish isn't sso bad, at least it is understandable)
thats a decent machine you made. to harden your drill-bit you could caseharden it. i dont know if you are familiar with this process or not but to do this you would put the piece (or pieces) to be hardened in a steel container full of bone charcoal, close the container with a steel lid, make sure it has a couple of gas-venting holes (3mm in diameter is good, doesnt suck the flame back inside if flammable charcoal vapours catch fire during the casehardening firing) then to harden it, put the closed container in a bed of coals of a fire and feed the fire throughout a day, so that the steel container is red-hot throughout the time. when the container is completely cooled again, then the pieces of iron (the drill-bit)&nbsp; will have a thin coating on all sides of harder high carbon steel, which shrinks over the iron and makes it as hard and strong as steel but not as brittle because of the inner core of relatively flexible iron.<br />
Thanks for your explanation. <br /> <br /> <span class="long_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">I had planned to use a little potassium ferrocyanide I retain from 30 years ago. </span><span style="background-color: rgb(255,255,255);" title="">Anyway, the main problem remains the lack of a forge, of which there are many interesting designs in Instructables. </span><span style="background-color: rgb(255,255,255);" title="">Sorry, this is the second main problem, </span></span><span class="long_text" id="result_box"><span style="background-color: rgb(255,255,255);" title=""> first </span></span><span class="long_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">is that I have so many things on </span></span><span class="long_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">hand&nbsp; </span></span><span class="long_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">that I never make time.</span></span><br />
yeah fair enough.<br />
&nbsp;B.R.A.V.O Nice project...felicitaciones amigo hispanohablante...y esta muy interesante tu aporte....gracias.Saludos desde Colombia
Gracias, colombiano. Un abrazo latinoamericano, que buena falta nos hace la uni&oacute;n... (<span class="short_text" id="result_box"><span style="" title="">Thank you, Colombian. </span><span style="background-color: rgb(255,255,255);" title="">A Latin American </span></span><span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">hug </span></span><span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="">, that much we miss the union...)</span></span>
Buen&iacute;simo, Felicitaciones!!
Gracias, z&eacute;nquiu (thank you).<br />
muy chulo, me gusta<br /> i like it<br />
Gracias. Lo tengo abandonado m&aacute;s de lo que yo quisiera; a&uacute;n no le he hecho los accesorios que necesita. (<span class="short_text" id="result_box"><span title="Gracias.">Thank you. </span></span><span class="short_text" id="result_box"><span style="background-color: rgb(235,239,249);" title="Lo he dejado abandonado">I've abandoned</span></span><span class="short_text" id="result_box"><span> it </span></span><span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="m&aacute;s de lo que yo quisiera">more than what I would like</span></span><span class="short_text" id="result_box"><span>; I have not yet made the accessories that it needs).</span></span>
I'm a machinist, and I think that thing is one part awesome and one part scary as hell. I'd be scared to death to run it. could definitely lose some fingers on it. but it's a great idea.<br />
I agree, but look step 13. Now the <span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="engendro diabolico">diabolical monster is a little safer...<br /> </span></span>
This is super cool! And great pictorial, muchos gracias!<br />
Thanks, strayturk. <br /> <br /> I <span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);">'m quite behind in my plans: &quot;He who covers a lot, just press only a little&quot;</span></span>
Nice job with your lathe and instructable.&nbsp; Very easy to understand and follow.&nbsp; I only wish my Spanish was as good as your English.<br />
Thanks, very much. Thanks to Google translator, too.<br />
Excelente manual, me encant&oacute; la pieza acabada. Feliz 2010!<br />
<span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="gracias, igualmente">Thanks, </span></span><span class="short_text" id="result_box"><span style="background-color: rgb(235,239,249);" title="Yo retribuyo">I reciprocate</span></span>
I like your ideas and inventiveness, too bad some people are more concerned with your delivery than the end result.&nbsp; Have a great New Year!
Thanks for your words, uncle Jack. <br /> <br /> <span class="short_text" id="result_box"><span style="background-color: rgb(255,255,255);" title="Yo te retribuyo tus buenos deseos para el 2010">I will reciprocate your good wishes for 2010</span></span><br />
About This Instructable
89,293views
112favorites
License:
Bio: I am leaving Instructables, soon. I am very upset with the turnaround that has the page to post the manufacture of a dildo. Me llamo ... More »
More by rimar2000:Calculating a pulleys based speed drive (Variador de velocidad a poleas) Aerostato (hot air balloon) Easy monopod (Monópode fácil)
Add instructable to:
