Overview
1. Get Converter Box Coupon
2. Quench your thirst
3. Amazon a Box
4. Collect a few materials
5. Voila!!!
Remove these ads by
Signing UpStep 1Get a Converter Box
2. When you receive it purchase a converter box
- I bought a Tivax STB-T8 Digital to Analog TV Converter Box at http://www.amazon.com
- After the coupon and saver shipping $9.99
An early on the fly HAM antenna was vertical Ham antenna called the CANtenna. It was made of metal coffee cans or tin soup cans soldered end to end in a stack approximating the wavelength desired.
Prized for its increased bandwidth, it usually had short lifespans outdoors due to weather damage
Priceless! love it man!
The Man Who Was Allergic to Radio Waves
I thougt, 'BS' when I first saw the article but after reading it it raises a few questions...I do, however, have a question concerning this statement:
"Cutting a section out of the can as shown here may quite impossibly reduce the functional bandwith of the antenna"
What are you saying?:
1. Cutting the Cans may completely yet won't reduce the functional bandwidth
2. Cutting the Cans may Slightly reduce the functional bandwidth
3. Cutting the Cans Won't affect the functional Bandwidth at all
I am reading the statement as "Cutting a section out of the can as shown here may quite possibly reduce the functional bandwidth"
Step 2 Quote:
"UHF (Ultra High Frequency) is the frequencies that the FCC has reserved for the new Digital Television Formats to be transmitted on.
These frequencies range from 300Mhz to 3,000 MHz (3Ghz). This means the wave ranges from 10cm to 1 meter in length, making two of these aluminum cans end to end along with some 18 gauge speaker wire a perfect way to intercept these waves"
I haven't messed with a simple antenna yet because all indications and experience are pointing me to a medium or large antenna with a preamp at the antenna. For those where a simple antenna is worth the try I'd suggest a dipole cut for 470 MHz, or a dipole cut for 175 MHz if high band VHF is still being used in your area, using standard TV coax between the antenna and TV, that way you don't have worry about keeping the lead in away from metal
I'm going to try this in a "Bare Bones" set up by simply wiring up two aluminum pop cans, and seeing if they help me any?!
