loading
UPDATE 04/04/2016 : Multipoint software + Emulating NES video/pictures + OPTION_7 Point and Click + speed test + OPTION video
UPDATE 03/24/2016 : CCD sensor reverse Engineering + Using 2 CCD sensors + Laser engraving vector files + Retropie playing
Hi and welcome to my third Instructable !
I have been reading about DIY touch screen table projects for a while now, and I find most of them very complicated. Often They imply using a videoprojector, reflection mirror and IR camera. The result gives you a complete multi touch screen solution, but you need some depth for the videoprojector to have a big screen. Not the best solution for a coffee table...
I made this tutorial to help people to build their own touch screen solution based on any flat screen TV. It uses light triangulation technology to read the coordinates. This method is quite cheap ( the priciest part is the TV), with a good quality image and you can make the table almost as small and as thin as your TV is.
Of course, nothing is perfect and with this solution it's not possible to build a 100% multi-touch screen and it's hard to cover the entire screen area. But depending on the way you make it you can have some interesting results. Plus, I am sure there are a lot of possibilities I haven't thought about to improve this.
Step 1: How does it work ?
This solution implies the use of light triangulation to read a very precise coordinate. Basically, it's like having a huge number of IR receptors with some IR LED. You turn on every LED one by one and read the sensors. When one receptor can't see any light, it means that an object is blocking the light. With enough LED and sensors you can get a much more precise solution.
But for this project, I was looking for something more suited for the reading. A CCD sensor, is in every scanner. In those devices, it's basically a black and white camera which reads only one line of pixels. To scan a color document, a RGB LED blink in the three colors and the CCD reads all of them for every line of the document. Then it can calculate the exact colors depending of the Red Green and Blue reaction.
Using a CCD sensor gives you access to 2700 light sensors on a 20cm line. Most people who take sensors and actuators from an old printer/scanners only take the RGB LED and the light conductor from this part, as we can see here. If you like recycling, you could examine the possibilities of CCD. Not having found many DIY projects on the internet using them, there are probably a lot of different ways with which you could use these sensors! In this tutorial I will also explain how to hack your own scanner.
For this touch table, I used one CCD sensor with 24 IR LEDs. The object is detected on a 740x380mm surface by a Teensy board (which works under Arduino environnement). This board turns the IR LED ON, reads the CCD and calculates the exact position of an object. Then it sends the coordinates as a mouse, a keyboard, a Python program or just as Serial on a Raspberry Pi which shows the interface through the HDMI on a 32" TV screen.
Step 2: Part list
When I am working on a project, I like to build things that are the most cost efficient possible but still of good quality. So even those on a tight budget can afford to build their own. It's hard to give the exact amount of money spent, as many things are second hand or from the tip. Here is an approximation :
Electronic :
  • Raspberry Pi (41$). I built my project with a Pi 2, but the B+ should also be fast enough.
  • Teensy 3.X (20$). I love building projects with my Arduino UNO. But the specifications of this tiny Teensy board are really crazy! (32 bits cortex M4, 72MHz, 256K Flash, 64K RAM, 34 digital PIN...). I think it's very useful to keep one at home. If one of your projects needs more PIN, more memory, more speed or just needs to be smaller, you can easily switch as it's fully Arduino compatible! Just install the Arduino plug-in and keep developing! The only little thing you have to be careful of is the access to the button to reprogram. I had to wire an external button when the table was built and I still needed to calibrate and debug.
  • The CCD sensor. You can easily get one from any old scanners which can be found everywhere :)
  • LED IR (0.1$). I used some 950nm.
  • The TV. It's hard to give a price, mine is a LG 32" that I bought second hand for 80$.
  • Wire
  • resistor
  • Computer Fan. You can find some in most old computers, you don't need to buy one.
Some parts can be a bit difficult to solder, I recommend having a good soldering iron. At home I have been using a WS81 from Weller. A bit expensive to buy but it's precise and you can keep it for 20 years ;-)
The wooden box and table :
This part is gonna depend on your TV screen. This is for my 32" LG TV :
The TV box :
  • 2 panels of MDF wood 10mm for the sides : 140 x 845mm
  • 2 panels of MDF wood 10mm for the sides : 140 x 560mm
  • 1 panel of MDF wood 10mm for the top : 950 x 650mm
  • 1 panel of MDF wood 3mm above the top : 950 x 650mm
  • 1 panel of Pine wood 18mm under the TV : 825 x 560mm
  • 2 large Framing lumber supporting the TV : 37 x 54mm (300mm long)
  • Small Framing lumber to ease the screw 15 x 20mm
  • Screws
The Table under :
  • 1 panel of MDF wood 18mm for the top of table : 670 x 350mm
  • 1 panel of MDF wood 10mm for the layer under the table : 670 x 350mm
  • A very large framing lumber for the table's feet 37 x 54mm, 280mm long(2 for each feet)
  • Screws
Approximate cost of the wood 70$
I also used a Trotec laser cutting machine to engrave some characters on it and to cut several small parts of the wood. You can rent it for 25$ an hour from the Fablab next to my place. As I often help them on electronic projects I can sometime have it for free :-)
Touch detection :
  • 1 Plexiglass 5mm for the support : 750 x 460mm
  • 2 Plexiglass 2.5mm, 735 x 12mm
  • 1 Plexiglass 2.5mm, 430 x 12mm (protecting the sensor)
  • 1 Plexiglass 5mm, 430 x 12mm (with the LED on it)
  • 8 mirrors 150 x 15mm (approximately as it's hand cut)
  • To create a IR lighting paper filter I combined a 106 primary red paper filter with a 181 congo blue paper filter
  • black masking tape
Step 3: CCD Reverse engineering part 1
As Wikipedia is way better than me on explaining :
"A charge-coupled device (CCD) is a device for the movement of electrical charge, usually from within the device to an area where the charge can be manipulated, for example conversion into a digital value. This is achieved by "shifting" the signals between stages within the device one at a time. CCDs move charge between capacitive bins in the device, with the shift allowing for the transfer of charge between bins.
The CCD is a major piece of technology in digital imaging. In a CCD image sensor, pixels are represented by p-doped MOS capacitors. These capacitors are biased above the threshold for inversion when image acquisition begins, allowing the conversion of incoming photons into electron charges at the semiconductor-oxide interface; the CCD is then used to read out these charges. Although CCDs are not the only technology to allow for light detection, CCD image sensors are widely used in professional, medical, and scientific applications where high-quality image data is required. In applications with less exacting quality demands, such as consumer and professional digital cameras, active pixel sensors (CMOS) are generally used; the large quality advantage CCDs enjoyed early on has narrowed over time."
Basically, the CCD you find in a scanner doesn't read lights in two dimensions, but on one line. With the one I tried, there are 2700 different light detectors that we can use as 2700 pixels on a X position.
As I couldn't find any tutorials explaining how they work on the internet, I tried to understand the logic by myself. I started by taking a printer scanner from the trash and opening it. Please be very careful with these devices, they use 220V! Don't do it if you are not sure of what you are doing. Always manipulate them when it's not plugged in and isolate any high power part.
By visually checking all the lines going from the control board to the CCD you can try to identify the 4 lines controlling the RGB LED, they are generally located at the extremity of the CCD board. With a multimeter, you can check where those lines are going on the communication flex.
Then you can check if some lines are bigger than others (it's probably going to be the power and the ground, you can verify which one it is with your oscilloscope when the power is ON). Plug an oscilloscope between the other lines and the ground to understand what they are doing.
I tried two CCD sensors from different brands and they where both using the same communication protocol but not on the same "line order on the flex". When I turned the scanner ON, I could see some data passing. It means that the device was probably testing the sensor when it is turned ON.
- One line was giving a perfect square signal, I deduced that it was a signal clock.
- One signal was turning ON and OFF at the beginning of the clock transmission, it's the Latch signal
- one signal was sending a lot of analog value. Those values changed when my hand was next to the sensor. It is the values from the CCD.
So I made a test program the on a Arduino UNO board. You can download it at the end of the step
With this, you can read on the serial port 16 average values (I call them pixels) of 168 light sensor on the sensor, so almost the 2700 total. Just plug in the lines as explained at the beginning of the above file on any Arduino board and read the data on the serial monitor.
Step 4: CCD reverse engineering part 2
Last week, I was trying to find some solutions to improve the cover of the detection area. To do this, I wanted to have a second sensor to test new configurations and speed. So I went back to the tip and I took several printer/scanner from different brands.
I was a bit frustrating to discover that some scanner have a different kind of CCD sensor. No need to open the entire device, they are pretty easy to recognize, as the black plastic package is way bigger (picture 1). Inside, they have a way more complex mirror architecture, a lens and... a very tiny CCD sensor! I will try to hack those one to see the possibilities soon, but for now, I needed another "normal" 22cm CCD. So I moved on!
Second printer I opened was from EP*** brand (Picture 2). The flex connection had 12 lines on 5V :
  • 1 Analog OUTPUT to 4 are big lines easy to identify for the LED
  • 2 (large) VCC? 5 (large) seem to be VCC
  • 3 GND 6 GND
  • 4 (thin) has a square signal with a 100ns period, the clock!
  • 5 (thin) has a short square signal every 20us.
  • 6 (thin) has a short square signal every 20us, another latch?? the latch.
  • 7 (GND)
  • 8 VCC
  • 9-12 RGB LED
After few hours of test, I couldn't find the good protocol to have the OUTPUT response. Even when the CCD was plugged in the scanner, the analog wasn't giving any clear response (on startup test as the printer was then reporting an error).
So I moved on to a third printer from H* brand. The flex had 14 lines on 3.3V :
  • 1 The analog
  • 2 VCC
  • 3 GND but not linked directly to the other GND
  • 4 VCC but not linked directly to the other VCC
  • 5 A latch every 40us
  • 6 GND
  • 7 ?
  • 8 GND
  • 9 CLK (clocking every 500ns)
  • 10 VCC
  • 11 - 14 RGB LED
I could access some PAD from the different line (picture 3). After a bit of testing I succeed to have a clean answer on the analog line (pictures and explanations 4 and 5).
The CCD I was using since the beginning is from CA*** brand. Here are the lines :
  • 1 Analog
  • 2-3 GND
  • 4 VCC
  • 5 ?
  • 6 Latch
  • 7 Clock
  • 8 ?
  • 9 - 12 RGB LED
Step 5: Building the 2 CCD connection board
I had now to build a little board to be able to control the two CCD with the same latch and clock signal.
The connection for this board are :
  1. The Latch (orange) (common for the 2 CCD)
  2. The Clock (yellow) (common for the 2 CCD)
  3. Analog (green) of the second CCD
  4. Analog (blue) of the first CCD
  5. GND (green)
  6. VCC (blue) (3.3V)
So I send the Latch signal, then I read the two Analog at every clock period. Most of the pictures and video have only one sensor, it's because I made them before upgrading the table :s
Step 6: Building a touch screen : Basic electronic design
Now we have a working CCD sensor with Arduino, we can start building our first touch screen:
You can take the glass from the scanner to use it as the surface. On one side you add the sensor and on the other side a IR LED. Power the LED (don't forget to add a resistor depending on the spec!) and start reading the sensor, you will see that a part of the serial data will raise. On a 10 bit ADC like the one on Arduino, the range value is 0 to 2^10=1024. On my test, my value is always between 550 to 980.
Two important things :
  • Any other light can disturb this experience, especially sunlight! So close your curtains, don't point any light directly to the sensor and ideally, add some black tape around your sensor.
  • Most LED have a very small emitting angle (around 20°). Don't be to surprised if only a part of your sensor sees the light, it just means that the LED is too close!
To visualize this I made a little processing program that you can download at the bottom of this step. This program shows 20 different cluster of the CCD sensor. If the average analog value of the zone is close to 1024, the cluster is white. If it is lower it gets darker. As Processing needs to communicate with "Serial.write" data and not "Serial.print" like the Arduino Serial port, you need to upload this new Arduino code on your board.
Now, if you put your finger between the LED and the sensor, you should see the cluster getting darker. Congratulations! You have made your first touch interface!! Now you can detect the area where your finger is, not very precise, but functional!
Step 7: Building the touch screen : find a precise X Y position
To improve the precision of the detection we are going to have to complexify the system by adding some LED on different digital ports of the board. As you can see on the pictures, I now have 15 LEDs (choose as many as you want) wired in a plastic brown sticks. The distance between each LED is 5cm so the total distance is 70cm.
Now, how are we going to detect a very precise position?
1. we need to check if the system is detecting something. The method is gonna be :
  • Turn ON LED 1,
  • Read the sensor and check if something is blocking the light
  • If something is in the way store the pixels above calibration in a table
  • Turn OFF LED1
  • Turn ON LED 2
  • if something is in the way store the pixels above calibration in a table
  • Turn OFF LED2
  • ...(do this for every LED)
Now we have stored all the areas detecting something.
2. calculate the function
I know school is often far away and mathematics didn't seem very useful at the time. But do you remember the basic function Y = AX + B ?
Here we are going to have a full application of this. We are going to calculate the function crossing the LED and the middle of the area the CCD sensor detected.
To simplify, we are going to set the XY origin of the graphic on the first LED called LED 1. We can then calculate B for every LED (in mm) :
LED 1 = 0, LED 2 = 50 (50mm distance), LED 3 = 100, LED 4 = 150...
The A is a bit more tricky, if Y = AX + B then A = (Y - B)/X
If we take the average of the pixels detected (in the program it's "(maxi + mini)/2") we can calculate the exact height (Y). We also need to transform the pixels in dimension.
(NB_PIXELS-(maxi+mini)/2)*CCD_HEIGHT)/NB_PIXELS+(SCREEN_HEIGHT/2)-(CCD_HEIGHT/2)
and as we have Y, B and X we calculate A :
A = (Y - B)/X
Now we have A and B of all the lines going from every LED to the middle of the area they can't see on the sensor. We have function1 : Y = A1 X + B1 and Y = A2 X + B2
We can then calculate the crossing of those functions :
The coordinate X and Y of the crossing will be :
X = (B2 - B1) / (A1 - A2)
Y = (((A1*X) + B1) + ((A2*X) + B2)) / 2
The X and Y are the crossing coordinates. If you calculate all the functions crossing point and you average them you should have a good approximation of the central position of the object.The multi-point can't work with only averaging, it need a more complex algorithm (in step 9).
Step 8: Building a touch screen : Improve design and speed tests
As we can see on the picture, this method is not really perfect. With 15 LEDs on one side, you can see on picture 1 there are still many areas we cannot detect.
So how are we going to make the detection area bigger?
  • The easiest solution would be to add some LED which point to the sensors. This solution, which you can see on picture 2, would cover the entire central area but not the one closest to the LED. It's not that good as It would need a lot of LEDs, which would make our system go slower.
  • The non detected areas are on the sides. An interesting solution could be to improve the distance between the LED and the sensor from the screen. This would solve part of the problem in the non-detected areas as you can see on picture 3. But the further the LEDs are from the sensors, the more interference we are going to have.
  • After a bit of testing, I decided to add some reflective mirrors on the two sides. With this solution, if you add just a few LEDs which point to the side through the mirror you can cover a wide area. As you can see on picture 4.
  • We could imagine a mixed solution like on the picture 5
  • Another solution could be a combination of the three previous points. The sensors and LEDs are a bit far away from the screen, some mirrors cover most of the UP and DOWN sides. It's close to the picture 6. You can probably add some LED to cover the corners like on picture 5. Still not perfect, but almost entirely covered!
Using 2 CCD sensors
My new solution was to add a second CCD sensor (picture 7). Now, the entire screen is almost covered! But as two sensors is slowing down the system, I can play with the number of LED I use, and with the number of pixels. This way I am quiet flexible on the cover, the precision and the speed I want!
For example, if I need to emulate a keyboard for a Nintendo Nes, I only need 8 buttons. I can split my screen in 8 parts and detect if something is on this zone. Only 30 pixels (15 par sensor) and 8 LEDs is way enough to do that and I can reach around 40Hz speed.
If I want to emulate a mouse I need access to the entire screen with some precision. So I ll use 100 pixels (or more) and 16 LEDs. The speed will drop down to 15Hz but I can click where I want!
On the video, I show the Processing program running on the Raspberry Pi. I only used one CCD as it was before the 2 CCD upgrade, but the position still takes some time to synchronize. This problem is only because Processing is a heavy program, so the Raspberry Pi is struggling to refresh and synchronize the screen and the serial port fast. I had to add a delay on the Teensy program to slow down the communication. If you try the Processing GUI on a more powerful computer, it will be perfectly synchronize.
As my LEDs don't have a big enough angle to cover the two sensors, I added a second LEDs in parallel pointing to another direction. I just had to adapt the resistor to have twice the power, and it's done!
Step 9: Multipoint algorithm
As I was saying, the multi-point cannot be perfect using a light triangulation technology with a CCD sensor. It is pretty complex to work on this part... But it is also very fun to imagine many different solutions on how to have the best results without adding problems.
Here is how I made mine :
  • First, I store all the value of the CCD in tab[][] for every LEDs
  • Then I calculate all the factor A and B of affine functions Y = A * X + B going from every LED to the center of the "black zones" that the sensor don't see (in red on the picture).
  • I selected the first function of the first LED (lets call it N) and calculated the crossing with the first function of the next LED (N+1). This is my first reference point. The very important step here is to remove those two functions by decrementing k in tab_position[LED][k][Black_zone] (the tab where the B and A are stored).
  • Now I just check if the first function of every next LED (N+LED_LEFT) are going close to this point. If they are, I adapt the position of the reference point and remove them as well.
  • When I checked all the other LEDs, I just start over for the second point. I can perfectly get the position of two LEDs or more (like on the second picture with 4 points) as long as several black zones detection for a LED aren't detecting two points in the same time. Their is still some improving work to do on how to use those "big black zone" detecting two points. In my code I choose to ignore them as I could.
This algorithm isn't perfect, but it allow me to use some multi-point for games, as I can choose where the detection points are (see the NES remote on step "Final program, let's play!"). I will keep improving it, and hope some people will advice and help me as well :-)
Step 10: Electronic connection
On the Fritzing picture, you can see how everything is connected.
A good thing about using a Teensy Board is you have 34 digital Input/Output. So we have enough free digital PIN to control 30 LEDs without the need of external LED drivers. As only one LED is on at a time, we don't need much power either.
In this project we are going to use the following Pin :
  • RX/TX (digital Pin 0 - 1) for the serial communication
  • CCD sensor control (digital Pin 2 - 3)
  • CCD sensor read on analog (analog Pin 9)
  • direct LED control (digital Pin 6 - 22)
I now have two LEDs instead of one for every PIN (to improve the angle for two sensors). The LEDs are powered on their Anode, which means you have to set your Pin Low to turn the LED ON. A 110ohm resistor is wired on the power line to avoid sending to much power on the LEDs.
Step 11: Arduino Teensy software
I have already talked about the great hardware specifications of the Teensy board. But combined with the Arduino software environment, the Teensy also offers some great possibilities. But first let's install the plug-in
Now you should see a category "Teensy" when you choose your board. And if you select it, you have access to several other options like the "USB Serial Type" to instantly transform your board into a USB keyboard or mouse (some possibilities can be found on Arduino Leonardo). The USB communication type is a "Full Speed" which means it can communicate at 12Mb/s. You can also change the speed of the board (on this project I used the overclock at 92Mhz).
For now, all of my Arduino UNO codes have been successfully built on the Teensy which means the adaptation between the ARM Cortex M4 and the AVR Atmega328 have been very well made. I tried to write the code to be understandable. Here is the structure of the main loop :
  • A for loop from 0 to the number of LED
- Turn an LED on (as the LEDs are wired with the Anode on VCC and Cathode on the PIN, you have to give a LOW state to turn it ON)
- ClearCCD(), The sensor has to be cleared once before reading the value... I don't know why. If anyone has an idea of how I could speed up this part, I would very much appreciate it.
- readCCD(), read the sensor, if a value is above the calibration it is stored and the function return 1. If something have been detected, the flag_detect is set to 1.
- Turn the LED off (HIGH state for OFF in this configuration)
  • If something has been detected, then the flag_detect is set to 1 and you enter the IF function. You can then choose your calibration between the following :
- OPTION 1; send Serial monitor.
Basic debugging : This option allows you to read the 16 clusters directly on the serial monitor.
- OPTION 2; calculate position + send Serial monitor
Debugging position : send the coordinates X and Y to the serial monitor
- OPTION 3; send Processing interface
Debugging visual : look at the CCD results on a Processing GUI. The interface is going to have to be adapted to the number of LED (16 default).
- OPTION 4; calculate position + send Python Pi interface
Send the position to the PyQT interface
- OPTION 5; calculate position + send mouse (only on Teensy)
Send the position as a USB mouse interface. To use this option you will have to go to "Tools" -> "USB Type" -> "Keyboard + Mouse + Joystick". (See the Warning at the bottom of this Step)
- OPTION 6; calculate position + send Keyboard (only on Teensy)
Send the position as a USB keyboard interface. To use this option you will have to go to "Tools" -> "USB Type" -> "Keyboard + Mouse + Joystick".
- OPTION 7; Point and click. Same as mouse but click instead of following the position
  • You can eventually add a delay at the end of the loop(). Depending on the speed you need
WARNING: OPTION 5 uses the command mouse.mouveTo(X, Y) which doesn't work on a Linux station. If you want to do the same configuration as me with a Linux Raspberry Pi you are going to need to use the UGLY HACK made by Paul Stoffregen who seems to be one of the developers of the Teensy Project. He is really good and he helps a lot with debugging if you have any questions. Thank you Paul!
For this hack, you need to modify a part of the file name usb_desc.c It should be installed in your Arduino folder. The new configuration given by Paul is slightly different but he makes it work! By then, the mouse.move() function is not working anymore.
Step 12: Raspberry Pi Python & Processing GUI Touch interface
On the Raspberry Pi side, there are many different ways to show some data with a GUI. I choose to write a basic interface with PyQT following a friend's advice. Now, the interface has a full screen picture, read the serial datas and write them on a little panel on the left of the screen and draws a cursor following the serial position received.
The program run on Python3.2 and Pyqt4 on the Raspberry Pi. You can easily find many tutorial to install them and run a program.
As Raspberry Pi had made a good release on installing and running Processing on the board. I also decided to adapt my debugging code to show it on the big screen, it's very slow but but great for debugging and improving the Teensy code. To do this, you will have to rotate the screen 90° (If your sensors and LEDs are on both sides like me).
  • To do this, you will have to modify the startup file config.txt. Here is how you do it :
  • Open the Terminal (or use the one on startup)
  • Access to the file : sudo nano /boot/config.txt
  • Then go at the bottom and add : display_rotate=1
  • Then : ctrl X
  • And y to say yes on saving the program.
  • Restart you Raspberry Pi : sudo reboot
Now your screen is rotated, you can play with the number to have different rotation (2 is 180°, 3 is 270°, 0x10000 for horizontal flipn 0x20000 for vertical flip)
Step 13: Build the surface, playing with plexiglass and mirror
Another tricky part was building the detection area. I didn't know which material to choose so I started with glass panels. But it was too fragile to manipulate and cut so I moved to plexiglass.
  • A plexiglass panel of 420x720, 5mm thick carried most of the detection parts (except the sensors and the Teensy because I wanted them to be lower).
  • From this first panel I cut a line 12mm height. I made some regular holes to insert the LED.
  • Then I bought another plexiglass panel 2.5mm thick and I cut it into a 12 mm line to make the other borders.
  • I fixed some black tape around the CCD sensor to isolate it from external light and set it at the good height.
  • For the reflective mirror, the shop next to my place couldn't cut smaller than 100mm. So I bought some 100x300 panel and a glass cutting knife. On internet there are a lot of videos to learn how to cut glass. Still it's not very easy and I broke many... it's easier to buy smaller mirrors (like 100x150), but don't forget to buy more than you need, as it's hard not to break any!
When everything is fixed and working. You can add some transparent glue above the surrounding plexiglass lines and around the LED to create an isolation if any liquid falls on it.
Step 14: Build the wooden enclosure
The wooden enclosure depends exclusively on the TV you have. I will only give the basic specification for mine, but I think the pictures are going to explain it better.
  • I used some 18mm thick Pine Wood to support the weight of the TV. I made several holes around the ventilation area of the TV.
  • Some large framing lumber to support the two sides of the TV so the back is not in direct contact with the wood panel behind.
  • Some small framing lumber all around to fix the decorative MDF around it
  • Some laser engravings on the surrounding 10mm MDF panels adding Pacman, Mario, Toad, the opening for the Raspberry Pi USB, the fan and the infrared hole of the TV.
  • The box is closed with one 10mm panel and one 3mm panel of MDF with a big square hole the size of the touch screen.
  • I also added some brown varnish to give a more natural wooden color to the MDF
The little table under is made with :
  • A 18mm panel MDF on the top to support the structure.
  • 4 feets, each of it made with two large framing lumber screwed together.
  • A layer made with a 10mm panel of MDF to store the remote of the TV and a multi-socket powering TV and Raspberry Pi
Step 15: The laser engraving
In this step, I added some of the illustrator files I used for the engraving.
For the others, they are from this awesome website. It's a really good database of Adobe Illustrator Vector files of games (like Zelda, Mario, Mortal Combat or Street Fighter...), movies (Star Wars, Despicable Me), Comics (Superman, Batman, Deadpool...) and many other categories!
Step 16: Final program, let's play!
Now we have everything fitting together, let's try a few games :)
With the keyboard option of the Teensy program you can emulate any key based game. I made few test with the PyGame already on the Debian Pi like the game squirrel.py. Then, I installed Retropie on a second SD card and tried playing with few games.As the engraving of the table, I have the games Mario, Zelda, Star Wars and Pac-Man (and others!)
But my keyboard code wasn't adapted to emulate a gaming keyboard so I had to make few modifications on pressing and holding the keys. If you use the normal program, the frequency of sending the key is not high enough, so Mario is gonna move very slow, like if you where just pressing the button very quickly instead of holding it.
My new keyboard game code hold the position of the button while it's reading the next one. With this configuration the movement of Mario are smooth :-) . I also implemented the multi-point as you need to be able to move and jump in the same time.
As we can easily access the usb port, it's also possible to plug a controller in and to emulate some games without a touch screen.
Step 17: How to improve the project
Still a lot of thing to do, it's hard to work on everything in the same time :-)
  • Now I made the multi-touch work, I can't stop thinking on how to improve the algorithm. But it's quiet a complex part for me :p
  • With the second CCD sensor, the screen is almost entirely covered. I still want to add more LED to create a slow mode but with a 100% screen cover.
  • I added a small button on the Teensy to be able to change mode. But we can't switch from a keyboard to a mouse or to serial. I can only change the different serial mode (like processing/python or debugging). Maybe Pymouse could be an interesting way to improve.
  • Maybe adding several sensor to use it as a monitor of the apartment. We can find some very interesting project on this area and I could add a nice Python GUI as the link between Teensy and Raspberry Pi isn't very useful right now.
Step 18: Conclusion
I hoped you all enjoyed this Instructable and that it will inspire many other projects using CCD sensors or coffee tables!
As you can see in the last step, there are still many ways to improve it... If you have any ideas or any questions, I would be happy to work with other people on making it more reliable, efficient and fun! ;-)
<p>Very interest Jeahnot!</p><p>By the way, there is a method for sensing finger roughness and distance thrue all glass with line focal imaging. What do you think about this? (2D-and 3D-targets, <em>offsets and tolerances can be effectively controlled with Line Confocal Scanner)</em></p><p>It's Focalspec Finland idea 2016 to to win hands down any laser in that case! Less ccds+lightsources, more accurary+more speed and more features for detecting! (spectrum analysis of the speed of light)</p>
<p>You might be able to do something with a laser and a rotating mirror. The laser spot would be projected as a red dot on the edge which would have to be a kind of frosted glass or plastic. The timing would be done relative to first and last illumination of sensors positioned so they couldn't be occluded.</p><p>You could do a two dimensional version with laser shining onto the W and N sides and sensors on the E and S sides.</p><p>Of course this system would be better with the laser bean not hitting the sides at too oblique an angle which would require the rotating mirrors to be well away from the side of the screen. Alternatively the laser could pass under the volume interceptable by fingers, a bit like this!</p>
<p>Hi, </p><p>This could be a nice implementation!! Do you mean adding one motor to rotate every mirror simultaneously? </p>
<p>jeanot, yes..ish. Not a very clear explanation. My sketch is with a motor rotating three mirrors in a triangle so that as soon as the reflected beam has exited at one extreme a new beam starts at the beginning again. The beam would then be reflected up using the prism and show as a red dot on the inside of the edge. Rather than get some feedback or control of the motor; one or two of the sensors could be used to signal 'beam starting' and 'beam ending'. Obviously there would be trigonometry to figure out exactly where on the perimeter the dot should be at an intermediate time!</p><p>It's rather complicated to implement - just a brain-storming type idea.</p><p>PS I've not figured out the issue with the pi3d events multiple key presses at the same time! </p>
<p>Hi, if you don't mind can I have more details about this project. This is my email danielalex3600@gmail.com . I have you can share with me and we can upgrade something about this project. Thank You.</p>
<p>Hi, </p><p>This Instructable already have all the information I think... I am not sure of what else I could give you. In which part do you need information? (code, schematics, how it works...). </p>
the code &amp; schematic please.<br>im sorry, but i can't open any documents/files from instructable.<br>i dont know why.<br>so if its not trouble you, can you please help me to sent you coding &amp; schematic, also how its work. thank you
<p>just a quick drawing 3lasers on 1 side + 2ccd, and on the opposite site 1laser and 2 ccd. It is only an idea. I dont know if it wont be too slow. If there is any chance to reduce ccds when using mirrors.. would be fine. but have no clue how to program all of it. :-( . thanks</p>
<p>The challenge isn't really the programing part, if you use a bit Arduino, you will see that the code isn't that complicated. It's more trying to find and hack several identical CCD sensors... </p><p>I don't really like the idea on buying scanners just to destroy them and get my sensor, so i am a bit dependant on what I can find on the pit next to my place. </p><p>We could, of course, use 4 different CCD, but I am a bit worried that it would make the project way more complicated to use as each of them would react probably a bit differently. That's why I used only one or two in my project, and tried to multiply the number of LEDs. </p><p>I found some CCDs on ebay recently, I am trying to finish quickly another project, and I will probably have time in January to test it. If it work good, I could probably try your design (after another ebay command for the three others!) </p>
<p>hi guys. did anybody try to use line lasers instead of diods? line laser's got 120 degrees. I am able to cover 100% with 4 lasers and 4 ccds at least on paper. I am not a programmer.... </p>
<p>Hi! </p><p>It should work as well with line lasers, so it could be a good option. Some wider angle LEDs could be use too.</p><p>The more CCD you have, the more you will be able to cover the area of course.. but a 100%, I can&quot;t see any scenario for the 4 corners :p</p>
THANK! but I can't understand how to calculate X Y position. Can you show EX?
<p>hi, </p><p>This part is a bit tricky... </p><p>You can see on the step 6 and 7 how it works. </p><p>Basicaly every time an object is between an LED and the sensor, I calculate a line betwwen them. Several LEDs mean I can have several lines, and the crossing of those is the position. </p><p>Soory, I am not sure I am more clear :s</p>
<p>thank</p>
<p>hi my friend this is actually very interesting usiing ccd as a sensor, but I need your help because I want to hack some scanners to do this instructable and I dont find enough info in this tutorial, could you help me with some datasheets or other diagrams that maybe you have!</p>
<p>Hi, </p><p>That's the complicated part of this project, there isn't much documentation about it. I spent a lot of time on internet, but I couldn't find any datasheet of any scanner brand... That's the reason I had to &quot;reverse engineer&quot; the scanners I use. </p><p>The communication protocol is probably the same on many scanner, but the pinout seems most of the time different. That's why we don't have much choice as using an oscilloscope to read the CCD activity and figure out how to wire it. </p><p>If you have any question, I can help you. But I already posted all the data I have :( . </p><p>Good luck</p>
<p>COuld this be used to say connect to a computer and run windows 10? just curious as my group has a tv we currently use for a digital game mat and we are looking at converting it into a touch screen cheaply.</p>
<p>Yes, the teensy board can be connected to any computer over USB. It just acted like an Arduino board!</p>
<p>I Loveeeeeeeeeeee Arcade Stuff And Just Made A Cardboard Skeeball Machine</p>
<p>haha, I think I would love to add plenty of sensors in this ;-) </p>
<p>So, two ideas, have you looked into these?<br><br>1: since a normal page is twice as wide as the CCD sensor, that means the flatbed scanner had to have a way to warp 8.5 inches of image into a 4 inch strip and then warp it back out afterward. It would seem then that you could use some sort of lenses or something to focus the image of the entire line of LEDs into the 4 inch sensor bar to get a full view of the LED bar.<br><br>2: Seems like putting one of these on each axis (so like sensors on the bottom and right of the TV, LEDs on the top and left) would allow complete multitouch, because the worst case scenario is that you have a right triangle of points, so each axis is missing one point, but the other axis catches it. You'd probably have to halve your speed this way, but maybe not, you might be able to judge the strength of the shadows in each area to do both axes at the same time.</p>
<p>Hi, </p><p style="margin-left: 20.0px;">1. I am not sure I understand what you mean. The CCD sensor I used is 22cm (8.5inch) wide. Which is the size of a standard A4 page. So I don't have any lens here. I could use a A3 scanner to have a larger CCD sensor. But I didn't find any affordable for now :( </p><p style="margin-left: 20.0px;">2. The more I add sensors and LEDs, the more the screen is gonna get close to a good multipoint. But I think if I want to keep the speed, I ll probably need to add several Teensy, one for each CCD. I can probably also move to a faster uC (I think the digitalWriteFast of the Teensy isn't fully functional on high speed transition, that's why it didn't worked with my CCDs), maybe a STM32. </p><p style="margin-left: 20.0px;">I made several test on what would be the best positions with several CCD, maybe it would be the best on two sides,</p><p style="margin-left: 20.0px;">Thanks for your help </p><p style="margin-left: 20.0px;">Jean</p>
<p>awesome this got you victory to 3 contests</p>
<p>Thanks, I wasn't expected to win in the three, so very happy right now :)</p>
<p>But i can bet this project worth winning 5. Really liked your project</p>
<p>Haha, this project already made a lot. Now I have to focus on new ideas for new Instructables :-) </p>
Congrats you've won $4,909.00 worth of prizes...
<p>Thanks!! </p><p>That's gonna be a lot of new materials to play with :-) Can't wait to start new projects!! </p>
<p>gotta say awesome project. i tear apart a lot of electronics always wondered what those CCD sensors might be good for. very clever solution. i might have to dig one out of the junk boxes and play around with one now :D</p>
<p>I am still thinking on building a database of how each of those sensors works. Lets keep in touch of you discover new protocols or hack new brand, so I can add them to the list ;-) </p><p>I have to start thinking of new projects based on those now :p </p>
<p>Great project, well done on winning, good work!</p>
<p>Thanks a lot!! I am really happy and already wondering what to make with this 3D printer :-)</p>
<p>I bet, some serious 3d printer envy going on here! I'll look forward to seeing what you do with it :)</p>
<p>haha, ;-)</p>
<p>What happens if you spill your coffee?</p>
<p>Then having a fitted carpet could be risky :p</p>
<p>Hi, </p><p>The panel of plexyglass has some small border sealed to it. So it shouldn't be a problem :) </p>
<p>thats awesome, so origional (and useful)!</p><p>thanks for sharing!:)</p>
<p>Thanks, a bit struggling right now on improving the multi-point :p </p>
<p><strong><u>THIS IS AN AWSOME PROJECT. EASY TO MAKE</u></strong></p>
<p>This is a fabulous project! A very worthy winner of the Pi contest, so well done for that!</p><p>With regard to speed, I wonder whether you could increase that with a more intelligent scanning algorithm. I haven't given it much though yet but what about a more tree-like scan rather than a linear one. What I mean is, say, turn on LEDS 1-8, followed by 9-16, followed by 17-24. If you see a shadow for one set and not the others then the point is near the left and you only need scan the LEDs from that one group. If you see for all then the point is near the right, so you only need to use a few LEDs to get enough overlap to triangulate the point. </p><p>I reckon you could get equal accuracy with a fraction of the scanning, at least in single-point mode. In multi-point mode it will be more difficult but I still think there are advantages to be had. Processing is fast compared to scanning, so use some analysis to get more value from your scanning time!</p><p>My other thought is that it would be great to do this <em>within</em> the glass . You might need to use visible light (glass does not transmit IR very well), but you could arrange LEDs shining within the glass and the total internal reflection will stop the light escaping except where the surface is touched. You might be able to achieve the same result and actually respond to touch rather than simply breaking a beam in the vicinity of the surface. The CCD is probably more sensitive to visible light anyway and I would bet that it would be less sensitive to ambient conditions.</p><p>Anyway, a fab project and one that I would love to try if I ever get the time.</p><p>Ugi</p>
<p>I was thinking about the scanning algorithm, but as I was developing the multi-point, it was not the good time to implement it. I made an update yesterday using a second CCD sensor to cover the entire screen with less LED. It helped increasing a bit the speed. </p><p>Then I thought about the needs of the application : </p><p>If I want to use a Mouse, I need a precise position, but not much speed. </p><p>If I use a keyboard for an arcade game I need a lot of speed but not much precision to emulate few buttons. </p><p>So I started to adapt like this : Only 8 LEDs with 2 sensors (25 pixels each) seems enough for the Arcade, and 16 with 2 sensors (100 pixels each) for the mouse give me a great precision!! </p><p>About the glass, it is a really good idea. I need to run few test to see if I can &quot;block&quot; the lights this way and about how the glass transmit. I am using IR filter to protect my CCD sensor from perturbation, do you think it's not gonna be possible to use this system with IR LED and filter? don't know much about that :) </p><p>Thanks a lot for your advices, if you need any help for CCD hacking, let me know ;-) </p>
U could use pymouse and then use it as a full time interface rather than just using it for games. I used it once but with a joystick and it shows great promise. And you can use spi or i2c instead of usb
<p>I never used Pymouse, I need to check that! Thanks :) </p>
<p>Its great. And since its the raspberry the possibility are endless. U can even use pykeyboard too. If u want help with it just lemme know. I got a CCD yesterday. Am going to try out your project and see.</p>
<p>I have just updated some CCD sensor hacking if you want to play with those ;-)</p>
<p style="margin-left: 20.0px;">Great, I spent my weekend hacking some new CCD. I will write an update in this Instructable in a day or two to show the results.</p>
<p>Or maybe next weekend, I have to finish the multi-point as well :p</p>
this is why I like instructables.. amazing projects like this.. Kudos! well built , and great instructable!
About This Instructable
105,384views
1,206favorites
License:
Bio: Born in the Alps, I love travelling, paragliding, trekking and, of course, designing projects. :) I learned a lot from open source project on the last ... More »
More by jeanotP1314:Virtual Reality on Raspberry Pi with BeYourHero! Healthy, Smart & Natural Air Cleaner with Arduino, WIFI and Blynk Touch Screen coffee table DIY with 32" TV and low cost CCD sensor
Add instructable to:
