Remove these ads by
Signing UpStep 1Parts, Tools and Materials
For tools:
- Wire strippers
- Solder and Soldering Iron
- Glue gun (For gluing long leads down so the wire doesn't bend back and fourth and
break)
- Dremel or Tin Snips (Anything for cutting Perf Board)
- Side cutters
- Markers (Optional)
For Parts:
- 3x 2N3906 Transistors (Or similar)
- 3x 2N3904 Transistors (Or similar)
- 3x 1000 uF 6.3+volts capacitors
- 3x 6 ohm 1/4 watt resistors (Color code, Blue, Black, Gold, Gold)
- 3x 10k ohm 1/4 watt resistors (Color code, Brown, Black, Yellow, Gold)
- 1x 330 ohm 1/2 watt resistor (Color code, Brown, Black, Brown, Gold)
- 3x 1N914 Diodes
- 3x Germanium Diodes
- 3x Red LED
- 3x Green LED
- 3x Blue LED
- Momentary Push Button Switch
- DC Barrel Jack or Battery pack
- On/Off switch (Optional)
- Ribbon Cable with Plug (Optional)
- 5-6v dc power supply. I used 4 AA batteries.
For Materials:
- A lamp or other enclosure (Not covered yet, as I want to enter this in a Contest, will be
updated later)
- A shade or something to blend colors (In the video I used a Paper Funnel)
- Assortment of wire, preferably color coated
Plus, I could not find germanium diodes so I consulted my electronics teacher at the university and he told me to switch them with pyritium diodes. Do you think it would make any difference?
To answer your question, yes, they should work with little to no noticeable affect.
Also, he sounds like an...interesting...fellow. Maybe not someone you would want around said laser gun, but inertesting none the less! :P I have heard that Uni Teachers have a tendency for being kinda out there though! Haha!
Can wait for a reply! Thank you!
Thanks
If this doesn't answer your question, reply, and be more specific, like what about the touch pads? Material, how they are connected...?
I will get a pic of a dc barrel jack and post it when I get to my desktop.
As for making it change color to the different songs, that would be easier to do with Arduino or microchips and what not, and I deal in analog circuits. But you can make the color change as the song is playing. Like I said, it would be about adjusting a few resistor values and the capacitor value, and then making a simple audio...I think its called a crossover, but it's pretty much just a filter. There is an excellent 'Ible for a filter, it would need slight tweaking I think, but it would go to the inputs where you touch your fingers to. I will reply later tonight or tomorrow (ASAP) on what would need to be done, and I will try and get a new schematic drawn up too, and will include the link to the other 'Ible for the audio filter.
There are never too many questions as long as you are asking because you don't know, and not because you want to be a pain.
THANKS A LOT . :)))
Ok, I'll get on the touch pads right away, and your welcome! :D
And BTW, I don't have any pictures because I was too busy working on my paper works and this lamp. :D
And your very welcome! I enjoyed helping out! :D
