3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Touch Sticky Note
Touch Sticky Note
This piano-liked thing is what I called touch sticky note. I Use a piece of sponge as the paper, and put 8 x 8 LEDs under the sponge. Whenever I touch the touch screen, the related LED will turn on, and this is how I write for the sponge.
I got the idea from the traditional sticky notes. Normally, a piece of sticky note has a very short life and can only be used for one time, so I was thinking how to make a piece of sticky note live longer, and then the idea of touch sticky notes came to my mind.
http://www.youtube.com/watch?v=1VqwYwur2-g
Step 1Supplies
Materials:
- A 8 x 8 LEDs matrix
*The matrix I used here is from ModernDevice.com, and if you want to use the same matrix I used, you have to buy the LEDs as well. I recommend the 8 mm LEDs, because it perfect fits the board of matrix.
- A resistive touch screen with touch screen breakout board
*The touch screen I used here is from AdaFruit.com, and also you can find the touch screen breakout board on the same website.
- A Arduino setup
- Some wires
- A piece of sponge or anything which is transparent
- A case for all the things above
*I built the case by a 3D printer, but you can also by anything you like.
Tools:
- Soldering tool and solder
- Leg cutter for cutting legs of LEDs
- Utility Knife
- Glue
- 3D Printer (Optional)
2 comments
Mar 13, 2011. 11:31 PMzazenergy says:
This is awesome. Thanks for posting :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Rodger Luo
