Introduction: Touch Switch
Picture of Touch Switch
The Switch which basically detects the touch & accordingly turns ON & OFF.
Step 1: Parts
Picture of Parts
For Touch Switch we need 4 Parts as listed:-
1) IRFZ44 (40..any IRFZ Series Mosfet) it is a Special type of MOSFET which holds its o/p.
2) Touch Plate.
3) Resistor of 470 ohm.
4) LED.
Apart from this you also need a general purpose printed circuit board, battery cap & male-female pins.
You can Buy DIY Kit for this project as well as Parts from HERE !
Step 2: Circuit Diagram
Picture of Circuit Diagram
  • Here S1 and S2 indicates the touch. S1 for switching ON & S2 for switching OFF.
Step 3: Making Touch Plate
Picture of Making Touch Plate
  • Take the strip of the touch plate shown in step 2. Cut the plate such a way that 3 strips come under it.
  • Now take a strip of 3 male pins & solder as shown in figure.
Step 4: Soldering Switch
Picture of Soldering Switch
  • The source of the MOSFET is given directly 9v dc.
  • Gate is soldered with 2nd female pin (middle one).
  • The drain is soldered with 470 ohm resistor whose other end is given to the LED & the other terminal of the LED is grounded.
  • Two other female pins the left most & right most is given 9v & other one is grounded.
  • Now all the vcc & ground are taken at two female pins where we need to connect the battery.
  • Now when you put your finger between the 9v & gate the LED turns ON. And when you touch ground & gate together it turns OFF.
Step 5: Applications
Picture of Applications
The Touch switch has infinitely many applications some of which are listed below:-
  1. It can be used as touch sensor.
  2. Anywhere at the place of regular switch.(Only for low voltage applications)
Aabhishek Sharma (author)2017-09-26
https://youtu.be/tRGSlU60GiM
I like this Very good packaging neat and clean,please
Have a look at mine https://youtu.be/tRGSlU60GiM touch sensor with touch pads
gm280 (author)2016-04-27
I see a few folks are asking about using 120vac capabilities with this circuit. If I were going to do that, I would incorporate an Opto-Isolator so that there is zero issues with the 120vac getting to the touch circuitry. Just a safer way to isolate things and my opinion.
Sy333 (author)2016-04-23
do i need to use a risistor ?
Geet Patel made it! (author)2015-07-28
Here is the PCB version of the touch switch.
BeachsideHank (author)2015-05-19
Easy, simple circuit, clear description and images. I assume it can switch higher voltage/ current if a relay is used?
Thanks for sharing.
3of5 (author)BeachsideHank2015-05-21
I was just going to ask this, It would be nice for projects. Just remember to use a relay made for handling 9 volts. The tiny 120volt ones I find laying around would work nicely as I used to make morse code practice units with them. and when replacing the LED with a relay, don't forget to take the 470 ohm resistor out.
Yes if relay is used with this circuit it can be used for higher voltage application.
About This Instructable
10,075views
217favorites
License:
More by Darp Raithatha:Home Automation & Control Systems Home Control SystemSmart Remote controlled lights
Add instructable to:
