3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tough PVC Cases For Anything
Ever need a case for something that you didn't want broken? Like making things that are simple, yet indestructible?
It is very simple to make a very tough case out of some PVC or ABS pipe.
I made a gift for my  friend, but it was pretty delicate, so I needed a case to put it in. Looking at the junk lying around my work table, I devised this and built in in about an hour.
Step 1Materials and Tools
Tools:
  • Saw, either a hack saw, hand saw, or reciprocating saw.
  • Ruler and marker to make straight lines.
  • Drill
  • Rivet gun
  • Hot glue
  • Knife
Materials:
  • PVC or ABS pipe, mine was 2-inch diameter, but whatever works
  • Tough foam, or two end caps to fit the pipe
  • Cloth-optional
  • Short screws or rivets
  • two small hinges
49 comments
1-40 of 49next »
Apr 18, 2012. 12:21 PMbobzjr says:
Another idea to tweak the design - solid endcaps attached to one side of clamshell. Instead of two half moons, a full circle attached to one side.
Apr 18, 2012. 12:03 PMbobzjr says:
Nice instructable! Thanks for posting. Have you considered using an integrated velcro strap for the "latch" mechanism? I'm wanting to use what you've shared and use this type mechansim...
Feb 4, 2012. 3:06 PMwiley coyote says:
Excellent idea! I'm may try to make one using a living hinge.... see http://en.wikipedia.org/wiki/Living_hinge... for a more streamlined effect and possible added stability without alignment issues, etc... with hinges and hardware.
Apr 18, 2012. 9:26 AMbobzjr says:
How would you make a living hinge? Would you use the interior vinyl lining as the hinge material? I can't think of anyway to use only the PVC material itself for the hinge...
Mar 31, 2012. 9:43 AMPfarmkid says:
two things
1. +
2. 1
Equals +1
Mar 7, 2012. 5:40 AMJunophor says:
You are right!!
A very good idea instead of using an oakley case;-))))) for your instructables
Cheers Aeon Junophor
Mar 6, 2012. 5:01 PMSantawon says:
Very cool idea. I have a hundred ideas I could do with these. Going to make some as soon as possible. Thanks for the awesome instructions.....
Mar 3, 2012. 8:40 PMRane says:
I have made something similar to this once for a geocaching container. Good instructable.
Feb 5, 2012. 4:38 AMjpwwalker says:
Such a great way of putting small items in my tool box such as drill bits! I might even make another one to put a pair of safety glasses in to stop them getting scratched in my box!!
Feb 12, 2012. 5:13 AMabstracted says:
great idea for my camera lenz`s
Feb 10, 2012. 10:09 PMpaqrat says:
Great idea and great instructable. I may have to try this. If one were to use clear plastic as one end one could possibly see what is inside.
Feb 1, 2012. 9:44 PMquantumz says:
This is a great idea that yields a handsome case.
One possible addition would be to use expanding foam insulation to make a custom shaped insert inside the tube, so the object isn't rattling around inside the case.
Like in this project for making custom tool drawers:
http://madmodder.net/index.php?topic=4770.0
Feb 11, 2012. 2:01 AMcriggie says:
Stunning idea - I've got a socket set which had a thin plastic liner. It broke so I tried making something with polystychrene, which worked but is messy.
That's on the plan for tomorrow.
Feb 2, 2012. 8:38 PMapburner says:
That is a great idea also. Fantastic tool storage idea. And the PVC carrier is brilliant.
Feb 5, 2012. 2:40 AMtinker234 says:
could i possibly add lead to the case for radioactive materials
Feb 7, 2012. 6:32 PMtinker234 says:
forgot to add im not allowed to disclose my ressearch by boss
Feb 7, 2012. 6:33 PMtinker234 says:
i think that this a great projects thanks
Feb 5, 2012. 10:36 PMEd-win says:
If you will drill the hole for the hinges before you cut the pipe into it is eaiser. Neat idea.
Feb 5, 2012. 11:55 AMlukeD says:
You are such a genius!!
this is so simple!
I have a little problem, I like to go fishing in my free time.
and I use very fragile fishing floats. They break very fast, so if I make a case for the floats with pvc of 0.6 inch. that would be very great! I'll try it for sure.
what I will add to your design are holes, around 10 I think, So the I can put the floats in the case when they are still wet, and thanks to the holes the floats can dry. the foam to close the sides will stay, so I can put thee hook of the fishing tackle into that foam,
then i can wrap the rest of the fishing line around the pvc pipe.
there will be space for one fishing float in one sase.
A perfect design for most fishers I think.
great ible
rated *5
Feb 5, 2012. 12:25 PMehudwill says:
I made a case like this out of bamboo, but had trouble with the latch. I like your latch idea. Great job.
Feb 5, 2012. 7:45 AMprestux says:
Great Idea! Thanks.
Feb 4, 2012. 11:05 AMtinker234 says:
could i possibly put the hinges inside and cover them
Feb 4, 2012. 3:31 PMn0ukf says:
putting the hinges on the inside, you'd have to bevel the outside of the hinged joint so that it will open.
My thought instead was to put the pins inward instead of outward (notch out the joint for them).
Feb 4, 2012. 9:15 PMtinker234 says:
wow thank you
Feb 4, 2012. 3:08 PMwiley coyote says:
Try it by making one of these down one side, rather than cut through. The exterior, and interior, should be smooth.
Living hinge.... http://en.wikipedia.org/wiki/Living_hinge
Feb 4, 2012. 9:16 PMtinker234 says:
thanks
Feb 4, 2012. 4:14 PMMorNiLachnan says:
You sir, are a god. :-)
Going to make a few of these to hold some of our camping gear.
Feb 3, 2012. 8:21 AMgtoal says:
I made a hard case for my one-piece pool cue out of this piping once, all it took was a couple of end-caps and a carrying handle. Fast & cheap!
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:ilpug
I am a High School Senior in the heart of Northern California, and i have been making things as long as i remember. I am on track to become an Engineer when i get to college, and i would be happy to h...
more »
