This cookie dunking cup is designed to be used simular to those disposable "push-pop" snacks.
You can make this cup either out of plastic or metal parts and a couple of "o" rings.
Remove these ads by
Signing UpStep 1If your good at blue print reading you can create the device using the image. Otherwise, step by steps to come later
good idea though. next invent a cereal machine to combine the milk and cereal perfectly.
I only say this after reading the mad scientists post, which makes methink he treats his body like a landfill.
'yeah, with brushes.. but then if you let em go too long, the mushycookie would get shredded... you could also add a neck rest towards theend to assist your head at the end of the conveyor belt that would dumpthem into your mouth, as well as a drain spout to fill a cup with thecookie drenched milk...'
This started out as a nice idea. a little dunking cup so you don't getyour fingers wet, or burned in a hot drink. and turned into a 'how muchsoggy dough can you get in your mouth without lifting a finger' debate.
Just my two cents.
*warning* very shitty drawing *warning*
