3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Diy tracing lightbox from lcd monitor.
INTRO:
Hola, este es mi primer instructable, asi que espero que quede todo ok.
Mi tarea es hacer una mesa de luz para calcar  y como fuente de luz para fotografia macro , a partir de un monitor viejo de pc. Importante, que funcione la retroiluminacion.
Hi, this is my first instructable, so I hope everything is ok.
My job is to make a light box for art tracing and like light source for macro photography from an old pc monitor. Important that the backlight works ok
Step 1Materiales y a desmontar
materiales y a desmontar
Cosas necesarias para comenzar
Monitor lcd, 17" esta bien, no pesa mucho.
interruptor on-off
cable
destornilladores
soldador y estaño
metacrilato
polimetro digital.
No hay fotos de las herramientas, pero se iran viendo poco a poco.
A DESMONTAR:
Empezamos quitando el pie, despues el marco del monitor con cuidado con el cable de la botonera, y si tiene tornillos en la parte posterior, tambien.
Ya se ve el modulo lcd entero.
Things needed to start:
LCD Monitor, 17 "is fine, not heavy.
on-off switch
wires
screwdrivers
soldering iron and tin
methacrylate
digital multimeter.
There are no photos of the tools, but it will go slowly watching.
Dissassemble:
We started by removing the foot, then  the frame monitor carefully with  the wires on the keypad, and if you have screws in the back, too.
You can  see the entire LCD module.
5 comments
Jan 26, 2012. 2:13 PMAntava says:
Thanks this one came very handy in did. I glanced at your idea and rushed to make it without reading the instructions properly so i didn't add the on/off button. Still works pretty well only that I have to press the Menu button every minute or so.The vga cable is damaged will it still work the on/off button if later on I want to add it? Muchas gracias me vino de p**** madre.
Jan 27, 2012. 4:05 PMAntava says:
Gracias por responder tan pronto. La verdad es que ya lo he resuelto. No sin um poco de dolor de cabeza, pero decidi eliminar por completo la placa de video. Adonde el psu se atacha con la placa de video, conecte un interruptor on/off y ya no se me apaga. Pero si me parece que la luz se quedo un poco mas flojita que antes pero igual me vale. Muchas gracias por todo.
Jan 7, 2011. 6:41 PMrimar2000 says:
Bienvenido al club de Instructables bilingües!
Welcome to the Bilingual Instructables club!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Niord
