Track Honeybees With Temperature
 by mJusticz
Featured
Data analysis coming soon!
My school is kind of strange. We don't have a cafeteria, but we do have a four week course on "The Simpsons." We don't have a jungle-gym on the elementary playground, but we do have a half-buried firetruck. We don't have a football team, but we do have a bee-keeping club. It's pretty awesome.
This year I decided to do some cool experiments with honey bees. This project uses 12 temperature probes placed throughout a beehive to track the movement of honey bees over the course of several weeks. The project is completely solar powered, weatherproof, and can log months of data onto a 1GB memory card. I wouldn't have been able to build this without the parts supplied by the bee keeping club.
Parts you'll need (in no particular order): TOTAL: $328.65 + Shipping (if you're getting everything new)
Here's the code I wrote for this project. Much of it was modified from existing Arduino SD card examples.
The parts for the SD card may have to change a little depending on what shield and Arduino you use. Because I used a Mega here, I had to do a bit of a work around to get the SD shield to work without modifying it, so it could probably be simplified a bit further.
Step 1: Mount the Cable Glands
First, I measured and drilled holes for the 13 cable glands. Cable glands allow for a cable to pass through an enclosure while remaining waterproof. I put 5 glands on each side with two on the front for the temperature probes, and one on the back for power.
The outermost cable glands had a nut on the inside that ran into one of the box's support posts. I just cut off part of the outside of the nut to make it fit – it shouldn’t compromise the seal too badly, and the box should survive splashes from the rain just fine (hopefully this thing won’t end up entirely underwater!).
Foxtrot70 says: Nov 12, 2012. 8:48 AM
Great Instructable!!! Another input for your project would be Pinhole mini cams at each sensor location to view, the activity of the bees vs. temperature. Keep up the good work!
amandaghassaei says: Oct 11, 2012. 12:04 PM
wow this looks really interesting! do you have any pics that show how the probes attach to the hive?
mJusticz (author) in reply to amandaghassaeiOct 11, 2012. 12:08 PM
Thanks! I'm working on it right now, and will make a blog post with more details soon. Basically, I'll insert two probes in between each frame. There will be some really cool data analysis coming from this project.
mJusticz (author) in reply to mJusticzOct 11, 2012. 12:09 PM
Oh, and as for pictures, we're going out to the hive in a couple weeks -- I'll try to post some then.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
