Introduction: Solar
Picture of Solar
Having seen a number of solar panels on the web and some light tracking builds on Instructables, I thought it would be a neat idea to blend the two together. The solar panel charges best when it attracts the most amount of solar light so why not enable this in real time?
I have used an Arduino Uno and a motor shield to drive two servo motors both left and right, up and down. Adafruit sells a great motor shield for this very purpose and ServoCity stocks the Pan & Tilt mechanism that I used. In addition, I used an 17W solar panel and battery kit from Voltaic which comes with the necessary adaptors to hook up a battery which can charge an iPhone around seven times or a Macbook Pro once!
Step 1: Parts Used
Picture of Parts Used
The parts list used is as follows:
x1 Arduino Uno
x1 Motor Shield (product 1438 at www.adafruit.com)
x1 Pan & Tilt mechanism (SPT200 Kit at www.servocity.com)
x1 Battery and Solar Panel (17W Kit at www.voltaicsystems.com)
x4 analog light sensors (product: 1384 at www.adafruit.com)
Sufficient wires to connect the sensors to the motor shield.
IMPORTANT NOTE:
I used two high torque motors so that I can disengage them when not in use. This prevents the panel from falling down when the motors are not in use!
Step 2: Arduino Code
You can download the Arduino Code here. I have documented most of the lines to make it clear what each part of the code does. In short, it averages out the readings of the two vertical and the two horizontal light sensors and moves the servos accordingly. To conserve battery power, the servo motors are disengaged when not in use.
Step 3: Wiring
Picture of Wiring
I have uploaded the Fritzing file to help assist in the wiring of the build; I hope it helps!
Step 4: Pan and Tilt Mechanism
Picture of Pan and Tilt Mechanism
Step 5: Laser Cut Files
Note that I have attached the CorelDraw X3 files to laser cut the base of the Pan & Tilt mechanism, the base of the solar panel and the enclosures to the four light sensors.
StevenDeDomenico (author)2015-12-18
Around $350AU as the components are very good quality. I saved by laser cutting my own parts where possible. Works amazing though.
hi sir i hope you can help me as i wanna use this system at my graduation project
LuisG70 (author)2016-02-11
Thanks
agonzales20 (author)2015-12-18
roughly how much did this cost
StevenDeDomenico (author)2015-12-02
Thank you; I hope it helps with the efficiency!
DIY Hacks and How Tos (author)2015-12-02
These are great. Trackers are supposed improve the efficiency by up to 60%.
About This Instructable
7,711views
126favorites
License:
More by StevenDeDomenico:Automated Dog FeederSolarArduino Nixie GPS Clock
Add instructable to:
