3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trackmate :: Classy Hardwood Curio
The Classy Hardwood Curio is a great way to get started with Trackmate. This version is sophisticated looking, easy-to-construct, and won't burn a hole in your pocket.
Trackmate is an open source initiative to create an inexpensive, do-it-yourself tangible tracking system. Using the project's Tracker software, any computer can recognize tagged objects and their corresponding position, rotation, and color information when placed on the imaging surface.
Using a system like the one shown here, you can track physical objects on a surface and use them to control and manipulate spatial applications on your computer. Since objects are each uniquely tagged, they can easily be mapped to particular actions, information, or relationships. See the LusidOSC project for more details about spatial applications.
Step 1Setup the picture frame
Start with a 4x6 inch picture frame with a wide border.
Remove the back from the picture frame and remove the glass plate. Optionally, at this point you can sand one side of the glass with special glass/diamond sandpaper (important note: if you sand glass, use water to reduce glass dust since it can be hazardous to breathe) to diffuse the lighting and make the glass look frosted. Standard sandpaper should work too, but it will take a lot more work.
Use a hot glue gun to securely affix the glass to the frame. If your glass is frosted, make sure the frosted side is facing out (i.e., the glass feels rough when touching it from the pretty side of the frame).
2 comments
Mar 26, 2010. 8:49 PMBen The Builder says:
 This looks awesome, is it a basic software download to run all of this? cause it seems like it's the webcam recognizing things, and then some sort of software to translate the movements, where would I find the software? and also do you think this could be put into a side panel for a computer that could recognize your fingers in pre positioned slots so that you could adjust....say volume. brightness or would you have to place down some sort of slider that would stay in the view of the camera
Jun 29, 2009. 8:37 AMglut says:
very good idea. trackmate it's a very interesting project. I have just started tests and the results are really exciting.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:adamkumpf(dsLabs)
Background in Electrical Engineering, Computer Science, Robotics, and Tangible Interfaces from MIT. Currently working at Teague as a Physical Prototyper and regularly contributing to dsLabs. Other p...
more »
