3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trackmate :: Classy Hardwood Curio
Step 3Install the webcam
Install the webcam
Before the webcam can be installed, the bulky clip should be removed. I used the Logitech QuickCam Pro for Notebooks (which works well in windows), but any decent quality webcam that allows manual functionality (i.e., exposure control and focus) should work. To remove the clip from the same camera used here, remove the tiny rubber piece from the hinge and unscrew the underlying screw.
Use the hot glue gun to secure the camera to the top of the frame. Make sure that the camera view is angled over a bit so that when the image is reflected off of a mirror, it will be centered on the glass in the frame. Also, make sure there will be clearance between the camera and the side of the box so that you can fit everything together later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:adamkumpf(dsLabs)
Background in Electrical Engineering, Computer Science, Robotics, and Tangible Interfaces from MIT. Currently working at Teague as a Physical Prototyper and regularly contributing to dsLabs. Other p...
more »
