3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Traffic Lights [Beginner Arduino Project]
Step 6Make the program
Make the program
You can download the attached file or copy and paste this code to your arduino software.
// Traffic Lights
// By Ben Hovinga http://ben.hovinga.me/
// Lights {GREEN, YELLOW, RED, PEDGREEN, PEDRED}
int light [2][5] = {{2,3,4,6,7},{8,9,10,12,13}};
// Buttons {light[0],light[1]}
int btn [] = {5,11};
// Timers
int tgreen = 30000; // 30s
int tyellow = 3000; // 3s
int tred = 3000; // 3s
int tpedwarn = 5000; // 5s (must be less than tgreen)
int tpedwarnint = 500; // 0.5s (must be less than tpedwarn)
// Other Vals. Don't Change
int btnval = 0;
boolean pedwait [] = {false,false};
boolean pedactive [] = {false,false};
int direct = 0;
int stp = 1;
boolean stpset = false;
unsigned long now = 0;
unsigned long changeat = -1;
unsigned long changeatped = -1;
boolean pedredon = true;
// SETUP
void setup() {
  // Assign all Pins
  for (int x = 0; x < 2; x++){
    for (int y = 0; y < 5; y++){
      pinMode(light[x][y], OUTPUT);
    // Start everything stopped (red)
    digitalWrite(light[x][2], HIGH);
    digitalWrite(light[x][4], HIGH);
  // Assign buttons
    pinMode(btn[x], INPUT);
// RUN
void loop() {
  // Update Time
  now = millis();
  // Check if button pressed
  for (int x = 0; x < 2; x ++){
    btnval = digitalRead(btn[x]);
    if (btnval == HIGH){
      pedwait[x] = true; // We have someone waiting to cross
  // Get into it
  switch (stp){
    // Green
    case 1:
      // Setup
      if (stpset == false){
        changeat = now + tgreen - tpedwarn; // Set timer
        // Turn on Ped
        if (pedwait[direct] == true){
          // Lights change for ped
          digitalWrite(light[direct][3], HIGH);
          digitalWrite(light[direct][4], LOW);
          // Set some vars
          pedwait[direct] = false;
          pedactive[direct] = true;
          pedredon = false;
        // Turn on Green
        digitalWrite(light[direct][0], HIGH);
        // Turn off Red
        digitalWrite(light[direct][2], LOW);
        stpset = true; // We are setup
      // Run
      else{
        if (now > changeat){ // Times up
          if (pedactive[direct] == true){
            // Turn off Ped
            digitalWrite(light[direct][3], LOW);
            digitalWrite(light[direct][4], HIGH);
            pedredon = true;
          // Next step
          stp++;
          stpset = false;
    break;
    // Warn ped (if possible)
    case 2:
      // Setup
        changeat = now + tpedwarn;
        changeatped = now + tpedwarnint;
        stpset = true;
      // Run
      else{
        // Flash Ped Red
          if (pedredon == true && changeatped < now){
            pedredon = false;
          if (pedredon == false && changeatped < now){
            pedredon = true;
          // Turn off
          digitalWrite(light[direct][0], LOW);
          pedredon = true;
          pedactive[direct] = false;
          // Next step
          stp++;
          stpset = false;
    break;
    // Yellow
    case 3:
      // Setup
        changeat = now + tyellow;
        digitalWrite(light[direct][1], HIGH);
        stpset = true;
      // Run
      else{
          // Turn off
          digitalWrite(light[direct][1], LOW);
          // Next step
          stp++;
          stpset = false;
    break;
    // Red
    case 4:
      // Setup
        changeat = now + tred;
        digitalWrite(light[direct][2], HIGH);
        stpset = true;
      // Run
      else{
          // Start over
          stp = 1;
          stpset = false;
          // Change Direction
          if (direct == 1){
            direct = 0;
          else {
            direct = 1;
    break;
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:agnivohneb
