Traffic Light
528
5
Posted
Introduction: Traffic Light
  • 1 LED(Red, Green, Yellow)
  • 3 Arduino UNO (download)
  • computer(with Arduno app!)
  • program
  • programmer
Step 1: Plug in Your LED(Green)
plug the LED(Green)into pins 13 (+) GND (-)
make sure the + and - are in the right way.
Step 2: Plug in LED(Red)
Step 3: Plug in LED(Yellow)
Step 4: Code for the LEDs
Copy and paste this code!
Blink Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and Leonardo, it is attached to digital pin 13. If you're unsure what pin the on-board LED is connected to on your Arduino model, check the documentation athttp://arduino.cc This example code is in the public domain. modified 8 May 2014 by Scott Fitzgerald * / the setup function runs once when you press reset or power the board void setup() { // initialize digital pin 13 as an output. pinMode(13, OUTPUT); } // the loop function runs over and over again forever void loop() { digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(13, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
Most Arduinos have an on-board LED you can control. On the Uno and Leonardo, it is attached to digital pin 13. If you're unsure what pin the on-board LED is connected to on your Arduino model, check the documentation at http://arduino.cc
Step 5: What Will It Look Like When It Is Done
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
