3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Transform - Ventilator to Belt sander
 Hello,
In this instructable you will see how to turn your old ventilator into a brand new belt sander.
Steps overview:
1. Disassembling the ventilator
2. Preparing the mounts
3. Preparing the belt
4. Turn it on and sand something
You will need:
Lots of good mood :)
Materials:
an old ventilator
Sand paper
10mmX1.5mm aluminum pipe (50 mm length)
Plastic rod - 30mm diameter, 50mm length (i used PVC, but it can be any kind of plastic)
Double sided duct tape tesa® 4900
Tools:
Dremel (Accessories - contour sander+ disc)
screwdriver
screwing machine
Hammer
Locking pliers
Socket set/wrench
M6 screw
2 M6 nuts
woodscrew
6.2 mm drill
10.0 mm drill
Step 1Disassembling the ventilator
  • last photo ←
1. Disassemble the front and back covers (using the screwdriver)
2. Disassemble the fan (using the socket)
3. Drill a hole in the exterior diameter and screw on the wood screw to the frame(to prevent the vertical rotation)
4. Drill a 6.2mm hole in the side of the casing (be sure not to drill on electric wires)
5. Open the screws in the area of the hole.
6. Insert the M6 screw into the hole from the inside and tighten the nut.
7 comments
Nov 22, 2010. 6:21 PMrimar2000 says:
Good work, belt sander is a very useful tool.
Nov 23, 2010. 3:23 AMrimar2000 says:
Of course, nobody can pretend to use this device to do a heavy work. But for small pieces it is good, surely.
Nov 21, 2010. 4:00 PMscraptopower says:
Really unusual transformation! It's a shame you couldn't have somehow left the fan blades on for dust"extraction" :D
Nov 22, 2010. 10:21 AMCrLz says:
Cool! and fan blades would make it cooler....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:sitzikbs
