Introduction: Transform Your Xbox Into R/C Car !!!!!
How 2 build your Xbox into this remote control dodge magnum R/C car with tv and sound.
visit www.mlomd.com for more info.
Step 1: PARTS LIST
PARTS LIST
- MICROSOFT XBOX.
- DODGE R/C 1/6 SCALE MAGNUM jada toys.
- 4 WIRELESS CONTROLLERS.
- SOLDERING GUN.
- 4 80MM FANS WITH LEDS.
- DREMEL
- EXTRA WIRE 22GA AND 18GA
- 5in lcd with sound.
- 2 Y adapters a/v splitters
Step 2: TAKING APART THE CAR
-Turn the car over
laying it on a soft
clean cloth.
- Unscrew all 8
Phillips screws
- And 4 around the
bumper
- Slowly separate
avoid ripping any
wires.
Step 3: TOP AND BOTTOM OF THE CAR
Top and Bottom
- Undo all wires from
the cars motherboard.
- Now you have 2
separate pieces.
- The top will hold the
xbox
- The bottom will have
all the parts for the
car and 2 fans.
Step 4: Cutting Back Window
Cutting back window
- Unscrew the back
window from
inside.
- Then dremel it out
along the factory
lines.
- And epoxy the dvd
tray door when
done.
Step 5: THE BOTTOM OF THE CAR
THE BOTTOM
- The care comes with
mp3 compartment .
- You will need to move
the cars pc board
forward.
- Extend some wires
solder the connections
and shrink tube.
- Remove the mp3 door
and dremel out the
compartment to fit 2
of the fans.
- Leave a strip of plastic
between the fans.
Step 6: POWER AND EJECT BUTTON
POWER AND EJECT
- Unscrew the back
plate from the inside
of the car and dremel
out holes
- You will need to
extend the power and
eject button 1 foot.
- Cut the wires one by
one they are all
yellow.
- Solder them and use
shrink tubing
Step 7: THE TOP OF THE CAR
The Top
- The top of the car
will hold the xbox.
- There are stock
supports that will
hold the back of
the dvd drive.
- The front of the
dvd drive will be
screwed into stock
holes in the car.
Step 8: INSIDE DVD SUPPORT
Inside dvd support
- You will use the cars
stock support for the
rear of the dvd.
- Some trimming of the
plastic support
- To get the dvd drive
to fit.
- Use the stock xbox
hard drive tray.
Pictures show hd
upside down. Flip it
over so it is right side
up when you put it all
back together.
Step 9: INSIDE MOTHERBOARD
Inside motherboard
- Some motherboards are
different than others
placement is key.
- You will have to extend the
dvd yellow wires 1 foot.
- Cut the wires one by one
they are all yellow.
shrink tubing.
- Secure the motherboard
down with screws.
- Some motherboards
require you to extend
power supply.
Step 10: POWER SUPPLY
Power supply
- Epoxy the power
supply to stock
supports.
- Dremel out a hole
for the power
supply to come
out.
- Use the spot where
the car trunk
handle would be.
Step 11: ADD A/V PLUGS
Add the a/v plugs
- Drill out 3 holes for
audio and video plugs.
- Use screw type rca
female to female
connectors.
- Add you’re a/v Y
adapter inside the car
one to audio and one
to video.
- The Y splitter will
connect to your small
tv.
Step 12: CUT OUT THE HOOD
CUT OUT HOOD
Very Carefully dremel out a square in the hood for the tv.
Step 13: Wireless Controllers
Wireless controllers
- Add any 4 wireless
controllers .
- Logic tech are the
best.
- epoxy the wireless
receivers to the
inside of the
windshield.
Step 14: ADD HARD DRIVE LIGHTS
Add hd activity
- Flip over the
motherboard and
solder the - to this
spot
- Solder the + to any
5v source or 12v
- depending on your
leds.
- You can add hd
activity leds to come
out the tailpipes.
Step 15: 1-2-3
PUT IT ALL BACK TOGETHER.
Epilog Challenge
What Can You Do with a Dremel Tool?
Holiday Gifts Contest
Craftsman Tools Contest
Joby Transform It! Challenge
