Transforming Lightbox
  • last photo ←
After deciding to sell some articles on an online auction, I discovered that my camera takes horrible pictures. Not being a photographer, I had to do some searching before I figured out how the "pros" do it. The answer; Expensive Cameras, High-Energy Lights and Lightboxes!
Not able to afford any of these, I decided to see what I could do on my own. Please keep in mind that I am aware that this site does have Instructables for Lightboxes, however I had to put my own spin on it, and I am glad I did!
This is my very first Instructable, so please bear with me. Any positive criticism will be greatly appreciated.
Parts:
(1) Roll of Freezer Paper, plastic coated. (Borrowed from the kitchen, thus free!)
(8) 1/2" PVC Elbow Joints (Home Depot), part A
(4) 1/2" PVC T-Joints (Home Depot), part B
(10) 2ft Pre-Cut PVC Sections (Home Depot) part C
(2) GE Floodlight Halogen 100's (Wal-Mart, 1 pictured) Part D
(2) Mainstays Clip-on Lamps (Wal-Mart, 1 pictured) Part E
(3) Ghostline White Poster Board (Wal-Mart, none pictured here)
Home Depot Total: ~$15.00
Wal-Mart Total: ~$26.00
Step 1Step 1
Step 1
Cut four (4) of the 2-ft PVC sections in half to create the eight (8) "halves". Cutting these the same length will make the project a bit more pleasing to the eye later!
7 comments
Jun 9, 2010. 5:58 PMArbitror says:
You can do this way easier and cheaper; just buy 5 foam core boards for $5, then buy a white poster board for 50¢. Then cut the boards so they fit into each other and hold together, then just lay the poster-board inside.
Aug 7, 2010. 7:34 PMwebslog says:
Shadow Ops: I love the idea of using foamcore; however how would you light it? I think the different designs that use fabric/paper/etc. are built so lights can be set up outside the box and create diffuse light.
Aug 7, 2010. 8:49 PMArbitror says:
You aim two lights at the back upper two corners, from the opening at the front. This illuminates the whole box, leaving no shadows on your subject.
Jun 10, 2010. 8:45 PMRionNipal says:
This is a nice idea, but I would only use PVC if I was planning on taking the cube on location. and even then, I would most likely sew a form-fitting pillow case style cover and hide the seam with the ramp. for rigging up a quick rig, Shadow Ops has a great idea
Jun 10, 2010. 8:45 AMac1D says:
Home Depot Total: ~$15.00 Wal-Mart Total: ~$26.00 Total: $41 http://www.dealextreme.com/details.dx/sku.5224 $20.95 http://www.dealextreme.com/details.dx/sku.5269 $21.11 http://www.dealextreme.com/details.dx/sku.33796 $28.71 But well. Doing it ourself have no price! Thanks for the great instructables.
Dec 23, 2009. 12:25 AMkomecake says:
  You could have saved money doing this, but it might not set up quite the same.
 Walmart also has construction light lamps for like $3 plus the bulbs. They are large and great for photography and clip on things. I used to do them when I did headshots in highschool. I did a lot of photography and these lights worked well for me.
 Instead of PVC you could use wood. PVC can get a bit pricey. Thin pieces of wood glued/nailed together would be a cheaper option.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Snarky
