Transforming a 300W Sinewave DC/AC Mini Inverter to a 5000W Monster
58,545
55
89
Published
Introduction: Transforming a 300W Sinewave DC/AC Mini Inverter to a 5000W Monster
I was planning to build a PIC microcontroller sinewave inverter and while browsing the internet to buy the necessary items I got accross this little 300w ready made pure sinewave inverter which would cost less than all the main items I was searching.
An idea flashed in my head to try to drive my "already have" square wave inverter's power stage from this ready made thing so I went ahead and ordered it.
After receiving the item I ran some tests on it and was surprised of the many hidden options this tiny thing packed:
-Built-in PWM maintaing a stable 230v at all times.
-Over voltage "+15v" and under voltage "+11v" cutoff.
-Low battery audibale warning.
-Overload cutoff
-Waveform distortion :<5%
Actually 300w is way too much to drive the power stage, 100w would have been more than enough and the price would be much less but unfortunately I didn't find one.
Anyway.. The idea was a 100% success, I connected the mini inverter to my power stage that I already have built from a previous instructable and the monster came to life just as was expected :)
Of course you can adjust the power stage to your needs following the table of my main instructable.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    1 Questions
    are you still helping on this project, I don't see any more replying to people's question for couple years
    the same questions are being repeated over and over again, i've answered all of them and many times too.. people just don't like to read, they prefer to ask instead. That's the main reason of why I don't reply anymore.
    89 Comments
    can the 2N6277's be replaced with IRFZ44N's? Thanks!
    what happened to Nick? It's a 268 volt out put. But enough of the filtering system, the power is only 168 volts.
    hello sir, i found the problem on the output transformer ... the trafo is hot like a short current, when i check the mosfet and the transformer looks fine,the voltage on "drain" mosfet is dropped when i connect to battery
    i don't understand something. i need to make a 5000w inverter. but. i need 84-0-84 + 20 transistors to get 5000w????
    i can't view any of your inverter pictures because of network problem..can someone send all me nicks inverter instructables to giftemma411@gmail.com
    Am researching on inverter....i will appreciate anyone who send me even the author
    Hello Nick,
    I am new here and would first like to say thanks for this project of instruction. Had a few questions on the transformer useage and inputs/outputs. I am guessing that the 12-0-12 trans is rated at 220v ac input and 12v+ dc output in order to supply good current to gates? I also was wondering about the 84vdc tap trans with 220v ac out. Many may not have the means to supply 84v DC via batteries; with this being the case, can't we just use a buck converter and cap to stabilize and provide voltage to center tap? Note: transistors mention are pretty durable and I have found a few alternates to supply power to this wonderful design; ex: MJ15022, rated at 250w 16A 250v. Please assist me...
    Hey Nick,
    Thanks for the update. I will proceed with the 24 trans, any particular brand? Your recommendation is highly appreciated.
    Thx
    Hi Electro46,
    It not a rule to use a 84v transformer, the power stage trans's voltage is related to the DC supply, if you're operating on 24vdc then this trans should be 24-0-24/220 and so on. Read my other instructable to get a clear idea on the transformer's power stage and what to use.
    Hi Nick,
    I have a doubt about this unit. That is when I am using the 300watt sinewave inverter, the out is connected to a 12-0-12 volt transformer. According to your table the 5kw inverter must have a 84 dc volt input. In drawing you are showing the last transformer as 84-0-84. How does this happen will the voltage automatically increase from 12 to 84 after the transistors.
    thanks
    George
    Notice at the bottom of the diagram, he has 7 12V batteries. The +84VDC comes from all 7 batteries in series.
    please refer drawing carefully ,that 7 battery's connected before 220 / 12-0-12, 0.5A transformer
    7 battery's connected yes, but only one is being used for the 300W Sine inverter. The full 84V is being tapped into the 84-0-84/220 Transformer at it's center tap.
    hi nick can i used transistor d1047 for monster inverter?
    hi nick
    i build ur monster circuit n it works,but the problem is,the power output is to high,it goes to 380 volts ac,i used d1047 transistor and my transformer is 12vdc/220vac 45 amps.what is the exact transformer do i used,thanks more power,i nead ur reply,
    hi nick,
    does the output of this monster is a sinewave?
    from 12V DCto 220Vac (sinewave)--> going to 220vac transformer then diode(squarewave),.going to power stage, where does the conversion of sqaurewave from diode to sinewave occurs?
    thank you, im just a little bit confused.
    Is it necessary to use 300W UPS for this project? Can I use UPS with lower wattage, say 100 watts as we only need 12 volts pure sine wave input from the inverter to feed the 2N6227 MOSFETs?
    Thanks
    can anyone help me with this? i have spent more than $100 on transistors and bought a oscilliscope. im going 48 volt to 115. have all the parts but keep burning transistors, using 2n3055. have more on order. my problem is what base resistor should i use? would like to use 48 volt for switching but my next attempt will be 100 ohm at 24 volt switching 48-51 volt collector emitter. im a do it yourselfer but the math for transistor base resistors is to confusing. seems like 100 ohm at 24 volt is somewhere in the middle of what they like if it works i will try 220 ohm at 48 volt for switching power. anyone willing to plz help. aaronandamerica@gmail.com
    Can i uses IRFP260N instead of 2n6277? If yes, which part of the "
    https://www.instructables.com/file/FA93598H82U2ATT" circuit I needs to change?
    preaty cool ! nice work!
    Wouldn't it be easier to use some IGBTs?
    and how about recharging the battery pack? 84v chargers are hard to find and also pretty expensive... could one use a simple charger circuit with 7-8 ATX PSU linked in series?
    anyway I'm definitely going to build one :D
