3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Transforming a boring old black t-shirt using bleach!
Do you have a few boring old black t-shirts that you are sick of? Here's a way to transform them into "something else". It's sort of like tie-dying, but using bleach to remove the dye, instead of adding dyes. It's also a much quicker process, which I am sure "the have-it-nows" will appreciate!
Step 1Purloin your boring old shirt
I have kidnapped an old black shirt from my son! You can also use boring old dark blue shirts for this transformation too! It is really cool! Be sure to use 100% cotton for this. First you need to wash the shirt (for who knows what perils lurk within its folds!) Once washed you can spin it dry and you are ready to begin!
91 comments
1-40 of 91next »
Aug 28, 2011. 9:28 AMRaisedByRobots says:
wow, awesome results!
Jun 21, 2010. 3:31 PMmeyers says:
what if i add a colour corant to the bleach and water solution? Would the dye be for example blue instead of the bleach stain colour?
Mar 6, 2011. 6:48 PMmlockhart says:
No - only because bleach removes color from anything. If your dye is in the same solution as the bleach, the bleach'll suck the color right out of it!
But, if you dye the shirt a color afterward, the places you've bleached will be extra thirsty and be very receptive to color!
Cool idea
Mar 7, 2011. 3:45 AMmeyers says:
Well thank you very much ;D
I'll try it.
Feb 7, 2011. 9:41 AMPerculiartom says:
what type of bleach do you use?
Jul 14, 2010. 1:45 PMgi joe says:
thanks cool shirt
Mar 4, 2010. 11:51 PMBobbyCage says:
any way to keep all the "holes" black, makin 'em look like bullet holes?
Mar 4, 2010. 11:56 PMBobbyCage says:
 oh...and also, the bigger the "object", like the marble, the bigger the circle?
Feb 10, 2010. 10:12 PMmaniqueen says:
I reaaally like the first one in the second row of pictures... you should do a tutorial for that one!! pleeease
Jul 1, 2008. 6:56 AMve2vfd says:
If you want additionnal spotty effect, when you take the shirt out of the bleach, lay it down flat on a table (outside!) and sprinkle straight vinegar on it.
The vinegar reacts violently with the bleach and burns deep spots in the fabric.
WARNING: This releases *very* nasty fumes, do it outside!
Oct 27, 2008. 5:10 PMbomberman3 says:
this also works with ammonia.
Dec 21, 2009. 5:39 PMbomberman3 says:
No, but seriously, don't. You will die.
Apr 11, 2009. 11:54 AMMaureclaire says:
NEVER mix bleach and ammonia !!! VERY toxic !!! I KNOW someone who DIED that way !!! I am serious !!!
Mar 13, 2009. 7:36 PMx z i t says:
viniger is easier 2 get tho
Jan 19, 2009. 6:14 PMNinjaSloth says:
if you mix bleach with ammonia....................wow just don't...... you'll die
Dec 21, 2009. 4:09 PMLance Mt. says:
 anyone know the actual chemical reaction taking place? To cause the toxicity?
Jul 12, 2011. 8:03 AMnina rabbit says:
According to Wikipedia: "Mixing with chlorine-containing products or strong oxidants, such as household bleach, can lead to hazardous compounds such as chloramines" (see http://en.wikipedia.org/wiki/Chloramine). Ammonia is generally irritating to mucous membranes such as in the eyes, nose, sinus, lungs, mouth, etc. Exposure to industrial strength ammonia for 30 minutes or more is considered hazardous to human respiratory health and injurious to the lungs. The fumes produced when ammonia and chlorine mix creates a gaseous release of compounds with even greater toxicity. In conclusion: DON'T MIX AMMONIA WITH BLEACH.
Jul 4, 2010. 12:55 PMMandalore_Stier says:
http://www.bbc.co.uk/dna/h2g2/classic/A795611
Dec 7, 2009. 5:47 PMKottonKandy says:
Way cool! I can't wait to try this!
    -K.K
Jul 16, 2009. 6:29 PMCriscoCisco says:
Can you bleach tie dye with a brown shirt?
Mar 27, 2008. 2:49 PMwhitehawk says:
Great instructable - thanks! Just a quick tip to add: When you remove the shirt from the bleach mixture, it's a good idea to rinse it first in water, then in water with vinegar added. The vinegar neutralizes the bleach to make sure it doesn't keep working. cheers, julie
Apr 10, 2009. 3:19 PMjeana41 says:
Very cool! How do you get the design of the one next to the diagonal, the tiger stripy looking one?
Apr 3, 2008. 4:53 PMxylo0 says:
How do u get the arrow design?
Apr 8, 2009. 9:02 AMjeana41 says:
Very cool! How do you get the patter of the one next to the diagonal (the "tiger" one)?
Jan 12, 2009. 11:12 AMNinjaSloth says:
does any dark color work because i want to try some of my old brown shirts. They arn't very dark but i just wanna know if it could work before i destroy them.
Nov 28, 2008. 5:23 PMhyperactiveguy says:
I used to have a pair of black underwear... then somebody accidentally spilled bleach on them. Now they're black and orange HALLOWEEN ALL YEAR ROUND!!
Aug 20, 2008. 11:38 AMhammer9876 says:
I accidentally spilled multiple spots of some "mildew remover" (bleach) on a shirt I was wearing. It didn't looked bleached until it went through the wash. Over time, the fibers deteriorated and my white-splotched shirt became my holey shirt. Be careful will bleach.
Aug 18, 2008. 3:50 PMMissPennyFarthing says:
Cool! :-) A couple of them remind me of Army camouflage!
Aug 16, 2008. 4:54 PMseantowle says:
how do you do the one where it has the three circles and the lines diagonally across? thanks in advance
Aug 17, 2008. 1:22 PMkangri says:
Awesome Instructable!! I just finished bleaching my shirt and my sister did hers, and now they're in the washing machine. I used the bullseye technique while my sister tried the scrunching technique. They came out great, but we should've used tighter rubber bands for my sis's shirt XD I'm gunna try this using other colors. Thanks again!
Mar 23, 2008. 2:19 PMMosh says:
OK, all I need now is a source of cheap shirts! Thanks :)
Mar 24, 2008. 12:09 AMMosh says:
Normally sensible advise... but right now I'm working in a "tourist town" in the Alps. Believe me, there are no thrift stores! Even the local supermarkets can get away with charging Harrods prices for their fresh produce :)
Actually, I'm wondering how this process would work on old shirts which have prints on them. I might experiment and see if the bleach damages the design or just "attacks" the dye in the shirt itself. I have *loads* of old Iron Maiden shirts that'd look superb with the tie-bleach effect if the print remains "safe".
1-40 of 91next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
124
Author:stinkymum
Born in England many years ago, moved to California in 1980, moved to New York in 1993, became a US citizen. Favourite place to visit, besides London England, is Lake Winnipesaukkee in New Hampshire,...
more »
