3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Transistor Amplifier Build
I've made a couple of these. I found the original schematic online then modified it because I did not have one of the parts the original plan calls for. My design allows the use of much more common parts. Although it uses more parts and is a bit more complicated.
Step 1The Schematic
The Schematic
Looking at a schematic is always how I decide of I want to build a circuit or not so I will present it first. I found the one I based my design off of here:
http://www.redcircuits.com/Page1.htm
Although mine isn't exactly like that one it is essentially the same topography. It sure looks simple enough doesn't it? That is why I choose to build it myself. I made my schematic because I did not have a TLE2141C Op-Amp. If you do then you can build the original and it should be easier than building mine.
IC1 and IC2 on my schematic are 15 volt regulators I used 12 volt ones. SL4 from the power supply section should power the lower voltage dual op-amp of course.
19 comments
Jan 1, 2012. 8:31 PMARJOON says:
if you want i can design a smaller and more efficient pcb for you. so that we don't need to buy expensive large pcbs and a lot of etchant. nice tible
Jan 2, 2012. 7:01 PMARJOON says:
yeah sure, but in some countries those pcbs may cost about 10-15 dollars to manufacture, since this ible is made facilitate lijes of people or hobbyists.
still glad that i got a reply
Jan 3, 2012. 7:59 AMARJOON says:
what can i do. there is only one board supplier in Mauritius, so they take advantage of it. and eBuying is not recommended here for the time being. :P
Oct 12, 2011. 1:55 PMmdog93 says:
Where would i get these parts as "junk" are these parts commonly found somehwere?
Oct 13, 2011. 11:12 AMmdog93 says:
Yeah, i thought you might say that. I find getting hold of stuff hard and when i do get things i don't oten find useful parts case the chips are almost always surface mount components. I also have never seen any chips i recognise when taking apart electronics. Is there an easy way to identify them?or And will i find the right sort of ICs in stereos then?
Sorry, last question i promise- if i had to buy all of the parts for this project, how much would it cost roughly? Would it still be cheap?
Thanks mdog93
Oct 13, 2011. 2:12 PMmdog93 says:
Hmm i suppose you're right it'll be different for everybody. Even when it's trial answand error i like to know if what i'm doing and how i'm doing it is correct. Sometimes no way is 'correct' but i do like it to be fairly black and white. I have made a lm386n-1 mini amp before though with fairly successful results.
Oct 14, 2011. 2:34 AMmdog93 says:
Yeah, can you recommend any good digital circuis to get me started? The lm386n-1 based mini amp i made i believe was analog. Maybe i'll do some more mini amp circuits to gain some more understanding of things. I'll have a look at the parts i'd need to buy for this, see what it would cost.
Oct 15, 2011. 3:47 AMmdog93 says:
Yes that does help, i need to reread it more thoroughly anyway referring to the circuit diagram to make sure i understand it. but i don't have time for projects like this at the moment but i hope to in the future. Thanks for your words of wisdom.
Oct 12, 2011. 10:28 PMQuercus austrina says:
Man, I love analog and discrete design. IC's are great for making things work the first time, every time, but there is no better satisfaction than getting it right the first time with discrete parts. Wish you had a sound sample. I'd love to hear it.
Qa
Oct 11, 2011. 10:21 PMsuckafish says:
Excellent. Thanks for the schematic. I love Eagle. If I use the bill of materials on Eagle are all the values the right ones besides the Voltage Regulators?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
71
Author:pfred2
I was pfred1 but moved, changed my email address, and lost my password. I suppose worse things could happen.
