loading
Step 9: Charge It Up.
it conveniently came with a charger...
what are the needs of this dude... i wants to make it<br>
I don't get it. Why does it need to be charged?
it's electric powered,front wheel drive
If this was my project, I'd consider using an old leaf spring from a salvage yard car. Lots stronger, a little more flex/reflex; but a b!<sup>@h to drill mounting holes. I'd also use aluminum blocks to raise the 'trucks' also look at angling the outer ones to eliminate the excess wear on those outer trucks. Great prototype!</sup><br/>
That's cool, it actually kinda looks like this one: <a rel="nofollow" href="http://scooterdirect.com/PerformanceScooters~20.htm">http://scooterdirect.com/PerformanceScooters~20.htm</a><br/>
CAn i just say theres a much easier way of doing this truck thing.... theres a board called a flow board and it has a bent pole going from one side of the board to the other.. purchasing one of these weird trucks would be alot easier although not nesercarily cheaper
wow all those wheels seems fun :D haha... but yea is there any "briefcase" models ... foldup ones...?
Awesome idea let see when finish your scooter
...i'm confused as to where the power is coming from for forward momentum? are you just rolling down hill? this contraptioni obviously isn't front wheel drive...but you took both rear wheels off and those had to be the drive wheels... if this is just a downhill racer...why use the scooter? not bashing...just wondering..the instructions/project are nice
if you look closley at the front wheel it does look like there is a motor inside but im not sure, if there isn't then it would be very strange to take it apart to make this.
really cool for the oldest still existing instructable
I'm pretty sure it is front wheel drive. If you look close, you can see the power cables in a couple of the pictures. It looks like an in-hub motor, and 250W is a common rating for those.
Crapflinger: I would have to agree with you, why destroy a seemingly new electric scooter?!?!?
This is great I'm gonna build this. But I will build it from a regular scooter, because I don't have that kind
this is so cool i have to build this
About This Instructable
19,150views
20favorites
License:
More by saul:Bamboo Chalk Holder. life changing egg trick training wheels for your helicopter.
Add instructable to:
