LiFi: Transmit Music Using Light
19,426
41
24
Published
Introduction: LiFi: Transmit Music Using Light
In this instructable I will show you how to convert music to varying light intensity and then transmit it wireless using an LED and a solar cell whose output it seen by a speaker.
Step 1: Demonstration
Step 2: Parts Required
  • 9V Battery
  • Alligator wires
  • Leds (here I use an emergency led light)
  • Solar cell (Preferably above 2V)
  • 3.5mm audio jack to be connected to mobile
  • Speaker
Step 3: Transmitter & Receiver
Connect the 9v battery in series with the audio jack then connect it to the led.
The tip of the speaker jack is connected to positive of the solar cell and negative is connected to the body.
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    24 Comments
    please send me its pdf at ranjanshobhit510@gmail.com
    Wont the 9 volt end up frying your phones sound card.
    Yep, but you should connect a battery in series with it.
    How many volts should the battery be?
    Hey, just had a question. How do I connect everything, the pictures are a little blurry and can't figure it out.
    Thanks
    Thanks for the feedback! I will be uploading a circuit diagram soon.
    could you upload a circuit diagramm soon?
    Could you please post the diagram soon. I have a school project that's due soon and I really wanted to use this as a demonstration. I'd greatly appreciate it.
    Thanks
    how did you modulated the signal at LEDs during transmission?
    The phone's audio jack converts a song to an analog signal output to drive the LEDs
    Does this mean you can use any LED, or does it have to be one with a circuit like the one shown in the pictures?
    Would a light dependant resistor (LDR) be convenient for this type of communication? Or is a photodiode better?
    A photo-diode would be better as it has faster switching time.
    Hi.
    You use a microcontroller before transmitting the signal for the LEDs?
    No a micro-controller is not required.
    Hello.
