Transparent Lampshade Design
2,467
54
5
Published
Introduction: Transparent Lampshade Design
What do you need?
• 200 x 150 cm Plexiglas Thickness: 3mm
Optionally color and texture may vary dependent.
• Plexiglass adhesive (Chloroform)
• electrical wiring
• 8 watts color night light
Step 1: Do Yourself Template
First of all we need to model our design in 3d platform. To make it 3d i used software called 3dsmax. When modelling is over, i exported the file as designlampshade.obj . To break the pieces of object i used software called Autodesk 123make. I imported the obj. file that i created with import option.
I checked the option ‘radikal syles’ from the segment ‘construction Technique’ which is placed left side of the wiewport. I made center adjustment from ‘siles direction’ part . In the ‘object size‘ section i placed piece count of our parts . I adjusted thickness of our parts with ‘manufacturing setting’ option.
All arrangement of the pieces;
Get plans > export > lampshadedesign.dxf
Step 2:
Step 3:
After the final check of all measurements, i proceed the laser cut operation.
I loaded the file that i saved as Dfx file format into a laser cut program. I placed the plexiglass in position at laser cuter and cutted every piece of it separetly.
Important note: Assigning numbers to pieces is important because pieces will be in different measuraments.
My Template Files:
Step 4:
I placed them together with placement order and fixed them with rubber band. To glue them together i used chloroform.
Important note: Don't smell it. It has narcotic effect. Use it in outdoors.
Video link: How to use cloroform?
I used it with syringe. A little drop was enough at intersection points of parts. It was left to dry off. To fix it better, glue them in both sides.
Step 5: Finally :)
Socket, wire and lamp setup is placed on the spot where the lamp will be placed.
Goog LUCK :) !!!
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    5 Comments
    actually you are better than sweet my work :)
