Trash Can Trauma Halloween Prop (From Kit and MAKE: Halloween Edition) by gigemags
Featured
This project was my first attempt at a pneumatic Halloween prop 2 seasons ago. We got fired up to try this after reading MAKE: Special Edition on Halloween. On p. 80, they describe the whole process in good MAKE fashion. Their instructions are good and the magazine is worth purchasing. Just thought we would share our experience in making the project.
Since it was our first compressed air prop, we opted for the kit from Evilusions.com. They are some great guys and were very helpful.
Finally, this is not an inexpensive project since I purchased a few kits and an air compressor. Since I now have worked with the compressor and components for a few years now, I would feel more comfortable recommending purchasing the components separately and more cheaply.
Materials (Total around $300 or so; could be cheaper if you follow many articles on the web about the pneumatic components and purchase them directly and reuse some old Halloween props):
- pneumatic popup kit: http://evilusions.com/shop/product_info.php?cPath=71&products_id=914 (shows $200 now)
- prop head: http://evilusions.com/shop/product_info.php?products_id=580 (about $50)
- trash can with lid, we used a gray plastic one (about $50)
- a few lumber scraps to build the base, we used 12" or 2x4 and 2 pieces of 12" 2x6, this will vary for your can and angles you use (less than $10)
- wood screws and washers to mount the base in the can, additional screws to make the base and fasten the pneumatic controller and piston to the base
- additional decorations for the pop-up dude...some creativity required here. we -reused an old static prop
- paint and stencil for the can. we used fluorescent green paint and a Powerpoint stencil cut out with Exactos.
Tools:
- saw to cut scraps for the base
- drill or something else (knife) to punch holes in the trash can (MAKE's project used a metal can)
- screwdriver and wrench/driver
Other:
- this project requires an air compressor. I was able to find a sufficient one at the Depot for under $100.
Step 1: Make the Base
When you make the base, you will need to test the height of the base in the can along with the pneumatic cylinder to make sure when it is mounted, the cylinder's rod can extend and clear the mouth of the can. It will probably be helpful to mount the prop's head for this test. You can see what I mean by the mount angle in the second picture.
Its probably worth mentioning that since i bought the prop head from Evilusions, they provided a threaded mount to match the end of the pneumatic piston. Don't forget this if you use your own prop.
chuckr44 says: Oct 7, 2009. 5:56 AM
Oh man. I'd love to dress up as a zombie and hide in this thing. I'd pop out and scream "No candy here!"
Ha.
gadget-evilusions says: May 4, 2009. 11:18 PM
Looks nice.
Sandisk1duo says: Mar 15, 2009. 3:15 PM
Cost?
gigemags (author) says: Mar 15, 2009. 4:11 PM
I've updated the Intro to include some comments on cost. It can definitely be done more cheaply than I did it. I did another project last October (a banging coffin lid) and it was much cheaper - i was much more comfortable with the parts. Thanks for the question.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
