3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Trash Concrete
Trash Concrete
I wanted to extend a hillside patio area.  Hauling in dirt fill by hand was more work than I wanted to do, and it would probably settle over time.  Cement was better.
The gravel in regular concrete is heavy and costs money.  I decided to replace it with free plastic bottles and pieces of Styrofoam trash.  Sand and cement were the only purchased materials.
Although the air cavities from the bottles don't have the compression strength of solid cement, the spaces between them create interior columns, walls and arches which are load bearing.  The top layer was more solid, with pieces of foam and cement to help spread out the weight.  The patio only needs to support foot traffic, and it does that just fine.
Step 1Collecting the Trash
I don't drink soda pop, or use vast quantities of Chlorox.  Going against the normal flow of things, I went to our city's recycling department and was given bottles that they had collected.  I also put the word out locally and helped clean up our barrio of locally generated bottles.
122 comments
1-40 of 122next »
Mar 29, 2012. 12:34 PM323maderas says:
It just occurred to me that this would be a good place to put discarded computer cases-stack them w cement between like they were bricks, layer or two of mesh over all of it, and finish-crete it. I know it's metal that can be recycled, but if you need a little more weight-bearing base for a bench or something, this would work.
Jan 25, 2011. 1:30 PMvincent7520 says:
Shouldn't we call that pollution ???…
Concrete you can do away with. Grind it in pieces and it makes material such as gravel for new roads …
But concrete with foam and plastic ? Both the latter will pollute for a hundred years, maybe more …
And this just when we and some governments are trying to prevent these material to spread with coherent recycling methods and enforcement.
I must confess I am somewhat at loss with this instructable.
Don't you think there were other methods for efficiency, economics and light work, the combination of the three being perfectly acceptable ?…
What other members think ? …
Best wishes to all.
Mar 21, 2012. 5:54 PMMr. Seeder says:
Ok, plain and simple we need other methods of recycling. We need to find other processes of breaking down and reusing these "Non-Recyclable" plastics and polymers and hopefully at some point leave polymers behind in place for something strong and biodegradable. This may be one possible alternative solution for now but, by no means is this a "solution" or in my opinion a good alternative at that. We need to change our ways if we want to change this planet. But i do commend you and everyone else who are at least trying to address the problem and come up with solutions. Keep fighting the fight guys..
-Cheers
Mar 22, 2012. 2:33 AMvincent7520 says:
COuldn't agree less than 200% with you !!!…
Cheers.
Mar 22, 2012. 11:26 AMvincent7520 says:
I don't agree with you on this point : by using the waste so liberally you spread it and it will be not reclaimed when chemistry will allow to treat it …
My idea would be to dispose of it in dumps made for that and let it sit there until it can be "bio-degraded".
Then again I know it is a somewhat wishful thinking, still containing those "non-recyclable" plastics in specific places is essential to me.
As for you way of living : please keep on the good inventive life you lead. We need a whole lot more people like you !!!…
Mar 23, 2012. 8:33 AMvincent7520 says:
Well that's a good sign anyway…
We're going in the right direction
Best wishes
Feb 15, 2012. 5:59 AMtheson says:
I agree thinkenstien , the more plastic you lock up in concrete the less ends up floating out there in our water ways. I seen on pbs there is an island of plastic the size of new england, floating out in the middle of the pacific ocean.
Jan 27, 2011. 8:35 AMpokster says:
well, at the moment its not entirely profitable as you say, but they've discovered a type of bacteria that when plastic is heat treated is capable of breaking down the molecular structure of the plastic rendering it completely re-usable without lowering the quality of the plastic. this actually means that in the next couple of years like with glass bottles we will be paid for our plastic refuse. jobs and work will be created from collecting plastic from dumps, landfills and other such places, and converted into building materials. i read an article in the irish times about plans to develop a 'plastic island' holiday resort! damn interesting stuff!
The thing about this recycling technique is that it has only been discovered in the last year at the start of 2010, by a UCD student in dublin. so full implementation will take a bit of time!
Jan 26, 2011. 4:09 AMvincent7520 says:
OK, I understand your point and basically I agree with you, especially about roads.
Nonetheless I think (but it maybe only my "aesthetics" feeling, whatever that means !… LOL) it really bothers me to see all this plastic not being recuperated one way or another
Best wishes …
Jan 27, 2011. 8:16 AMbluumax says:
You sure don't want to talk to anyone that works in the recycle industry, you'd be blown away by what really takes place.
Remember all that computer crap that went to China for recycling?
You really don't want to know what they do.
This is a great use of material, besides it takes a lot of ENERGY to move it, clean it, separate it, melt it all down, yada, yada, yada....
The reality is, recycling is a FOR PROFIT business, they don't do if for puppy dogs & rainbows.
I always thought this would have great insulation properties too.
Mar 16, 2011. 4:31 AMvincent7520 says:
hi there see my answer to you and and bricabracwizard and jpinney below
have a good day
Mar 15, 2011. 3:47 PMbricabracwizard says:
Yes, you definitely wouldn't want to know how much the west dumps on third world countries and how they dispose of it and what happens to the locals!!
Mar 16, 2011. 4:30 AMvincent7520 says:
hi there see my answer to you and jpinney below
have a good day
Jan 27, 2011. 7:31 AMjpinney says:
But Vincent, it is being reused. When most still ends up in the landfill or along the sides of our highways and byways, this starts to look like a better use.
Hello there ! … this is an answer to Bricabracwizard, bluumax and jpinney :
I do know the strain we put on poor countries, and I feel it's a shame (and it is not solely environmental … ).
But if I agree not to dump my junk in our neighbor's backyard I don't either want to see mine filled up to the brim …
To me recycling is not hiding non recyclable stuff in constructions that will be uncovered by future generations who will have to face highly polluted soil (think of the food chain …) but creating low environmental impact materials that can either be reused for the same or other practical purposes or that will dissipate in nature at a reasonable pace so that future generations will not have to endure our misgivings.
Also I do know what's going on in the recycle industry : not really ethical, to say the least… Can even tell you of a funny story (from my country !…)
Oct 22, 2011. 9:43 AMReuse Portland says:
Be careful. Don't forget what happened to Haiti.
Jan 26, 2011. 12:27 AMnachsan says:
I agree with Thinkenstein it's a good way to use plastic. If it's gonna last 100 years it can be 50 under your feet, and you don't waste other materials, don´t forget that the making of cement is a very pollutioning proccess.
For the next extension you could fill the bottles with water, it make them more resistant. And don´t use the foam, it will compact in a few years and the concrete could break!!!!
P.S.: sorry for my english, ha, ha
Oct 4, 2011. 11:15 PM1161858 says:
why not just fill them with dirt being enclosed in the bottles they wont sag from seeping water and wont expand and evaporate like water and im sure there is plenty of dirt laying around
Jan 27, 2011. 11:46 AMZovits says:
I was also thinking about water-filled bottles. But in winter water would freeze and expand in the process, that could crack the concrete.
Jan 27, 2011. 3:20 PMBosun Rick says:
I'm thinking he probably doesn't worry about his patio freezing In Puereto Rico
Jan 27, 2011. 3:11 PMbrickman93 says:
just fill em half way.
Jan 27, 2011. 4:45 PMken2400 says:
So in the end one want to lighten the mix.
I wonder if air could be injected into the mix while it is setting and making blocks with a number of small air holes then use the full mix to put them together.
I thought of using peanuts but have not done so yet.
Jan 27, 2011. 9:37 PMdansan101 says:
They have done that before! using a chemical reaction where gas is produced as the concrete begins to cure. Its used in houses as its lighter, cheaper and acts as a better insulator than standard concrete blocks. Ive also seen concrete filled with single direction "fibre opitcs' cables allowing light to shine through the concrete
Jan 30, 2011. 12:54 AMzippydaspinhead says:
Look up "air-ated concrete" on google (that may not be the right word) They use that type of concrete as the emergency rest beds for planes that cannot stop on the runway.
Saw a whole show on it on Discovery once interesting stuff.
Jan 27, 2011. 7:43 PMjonpersonals says:
Jonpersonals Cont. Recycled products make the best 500 year concrete...!
I have 4 o5 coments now but I can see them? not computer expert...
Last idea I wanted a sparkly surface on my long back walkway for nite use.\ Saw how stop signs use glass to lite up so I did this too..... Auto windshields are free every where and will shatter in to small pieces , just put them into your cement mixer for a couple of min and they are like shiny not sharp stones min with cement binder , can use a bit of clean sand and gravel to extend the mix. Use this oaver found cement pieces and you have a super sparkly surface to walk on. People can hardly believe idt when they see it..... One other note standard 1" slope in 5 or 10 ft sucks. use 1" in about 2' to keep it clear of water..
You can use clorox bottles buried at the edges every few feet probably 2 bottles deep, to catch water if you have a build up..punch a bottom hole.
Jan 31, 2011. 10:15 AMtomtomorrow says:
Sounds like a great idea! Do you have or know of a link for that project? How small should the pieces be? What would you say is a good mix ratio for the glass to cement?
Feb 9, 2011. 2:35 PMjonpersonals says:
Hi Tom I did hobby work/construction of concrete for years and this was my Idea after examining why stop signs reflect so well. Its glass the particules.
When you break saftey glass it breaks into 1/4 or 1/2 " ... I said this below .
I am going to take a nite photo to show how it lites up with just a moon even.
later Jon
Feb 2, 2011. 1:38 PMjonpersonals says:
Hi T Auto glass being tempered breaks int 1/4 to 3/8" about as you probably know. To add glass just substute glass for the rocks or pebles in your cement mix. . Actually for the last /top mix or surface you will use builders sand, (this sand is sharp edged unlike round beach sand, and therefore gives a stronger CONCRETE than the round sand) ... Be sure to wash any sand as it will have debris in it.... Mix= test your mix for slump as I mentioned befor. OK?
Feb 2, 2011. 6:55 PMtomtomorrow says:
Thanks, johnpersonals, for the answer and also for the tip on builders sand. I will try it on a small project first and if it looks as good as you say, I will do it to my patio floor.
Jan 30, 2011. 2:13 PMburwuro says:
If you could Grind The Bottles And plastics up wouldn't that be a better use same with the sytrofoam?
1-40 of 122next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
341
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
