Thus I decided to design a little battery recharger that was small, light weight, and cute. Ok, the cute part wasn't the original idea but who can argue with cute?
Cost: $5
Time: 20 Minutes
Difficulty: Very Easy
Remove these ads by
Signing UpStep 1What you need
4V or greater solar cell
AA or AAA battery holder
1N914 Blocking Diode
Altoids Tin to house it in (or whatever)
Tape
Tools:
Soldering Iron
All the supplies for this project can be found at my website, http://www.browndoggadgets.com. 90% of the money goes to me making more projects, the other 10% goes for dog treats and the occasional stuffed frog toy.
*** Several people asked me to put together a kit of all the parts with a discount, so here is that kit.
100V 200mA High Conductance Fast Diode:
http://uk.rs-online.com/web/p/rectifier/7044013/
That's a "big scale" solar project, unlike this small scale solar project.
So adding a second 4V solar cell you could either get 8V 60mA or 4V 120mA.
To charge in lower light, you'd want to go for 8V 60mA.
To charge up the batteries faster, you want 4V 120mA.
Push the button and see if there is enough power coming in.
I'm sure there is a better way, like using some sort of voltage trigger, but I like keeping things very uncomplicated.
i.e. need at least 7V
also, with the 10% of battery capacity rule: is it only 10% of one battery, or 10% of the sum of the batteries current capacities.
i.e. 10% 1 battery @2000 mah = 200 mah
10% 4 batteries @2000 mah = 800 mah or is it still 200 mah?
Your Instructables are amazing! keep up the good work!
How you wire them up determines their capacity.
Hook them up in Parallel and you keep adding capacity. 1 AA is 2,000mA. 2 AA in Parallel is 4,000mA. 3 AA in Parallel is 6,000mA.
use this to charge your AA's...
... then use your AA's - with a MintyBoost circuit - to charge your iPhone.
As long as you get your AA's charged, this -will- work.
Depending on how low your batteries are it can take anywhere from 5 - 10 hours of sunlight. The way I use it is that I have a spare set of batteries stored in the tin, then swap out my "dead" batteries with those spare and then charge the "dead" ones up. By the time my spares are used up my "dead" are all charged.
You could always build a 6V power system using a 9V Solar Panel (say around 3 watt)_, a cheap charge controller, and a big 6V battery.
Though if you want to use them in projects I would suggest not doing so. The ones you make are going to be very very poor compared to even the cheapest factory made ones. Shoot, you can get them for free if you can find someone throwing out old garden lights.
Though I've seen quite a few places selling new solar graden lights for less than $3, which is darned cheap for a solar cell + LED + circuit + rechargeable battery. You might as well buy one and gut it.
Then you'd just need a USB cable to hook into your 3DS. I've seen them before, so I know you can find them.
Or you can use a voltage booster which would take a low voltage and boost it up to the 5 you need. If you're interested I have such a kit available on my website, and I'm going to be writing an instructable on it quite soon.
The kit to make the circuit.
A solar to USB system built into an Altoids tin.
Where do you keep finding these altoid cans???
Otherwise if you like mints it wouldn't be too hard to buy one every now and then and enjoy yourself.
