loading
Step 6: Finger Joints - A Laser Cutter Friendly Building Technique
At the hardware store I picked up stock in a variety of widths.  3.5" (9cm), 2.5" (6cm). 5.5" (14cm) and I found 3" (8cm) wide stock at an art/hobby store.  I used stock that was 1/4" (.6cm) thick so 5.5" (14cm) wide stock was as wide of a piece as I could get easily in store.  The back of my case is obviously larger than 12.5x5.5 so I needed to piece together a few panels to create the back.
I used the finger joint technique for the construction of this project.  I chose a consistent joint size to use across the whole project - making small adjustments to areas that overlap or might give me trouble.  Some of the pieces will be placed at right angles to others so I chose 1/4" as the depth of the finger joint - the depth of the stock I'm using.   I decided to make the width of the finger joints 1/2".
The idea in creating finger joints is to make two pieces that interlock perfectly so they can be glued together.  Material needs to be removed from one piece and left intact on the opposite piece so the two panels interlock.
I used this technique for every piece on the project.   The selves and supports were created in the same way.  I cut joints on one edge of the shelf and correlating holes in the back panel of the box as well as on the side supports.
The construction of finger joints is not that dissimilar to putting together legos - they press together and if cut well fit very tightly.
At this point, you need to start thinking about the depth of each side of the case.  Things to take into consideration:
- Depth of objects
- Inside dimension of the suitcase
- The stock you are using
This is the point where you figure out exactly how deep each shelf will be.
While creating the layout on my computer, I used a color-code system for the different widths of wood so I could quickly identify the depth of shelves and side panels.
and you're making Manhattans and Sours on the go! Bravo sir!<br>(is there also an ice container on board?)
<p>This is so nice, bought a suitcase right now!</p>
<p>Nice idea well done</p>
<p>Nice job! The link to your blog entry is broken... removing the date from it will fix it.</p>
<p>The perfect gift for a lawyer or politician. Now, about building this laser cutter? I seem to have misplaced my neighbor's.</p>
Old Fashioneds.. yeah. :D Great work, way nicer than my Executair 100 (?).
You can't deny that the simplicity and straight-forwardness of the Executair 100 would make it a lot easier to serve your self after a few rounds...
<p>I have since acquired 6 more portable bars... one is leather exterior and wood/velvet interior... yours is still the nicest one, though. :D</p>
<p>This looks like the very expensive Item like 150$/&euro; great</p>
<p>Awesome Instructable.</p><p>A shame all my work travel is by plane, I wouldn't want to have to check this. I guess I could fill the bottles when I touch down, but that kind of negates being able to have exactly what I need in the travel bar.</p>
This design is well done. I like the Art Deco look (or maybe it's just a 1920's look) because that's when cocktails were king. <br> <br>How much does the full kit weigh when loaded up? Can it be carried with one hand, or it is more of a luggable?
Thanks, it was something I wanted to make to have around for forever and I really thought about how to design a functional object that will last. <br> <br>It is around 20lbs when fully loaded. It can be carried with one hand but 1) It is a second hand suitcase, I'm not exactly sure how abused it was before I bought it, 2) I don't want to put unnecessary pressure on it and risk breaking it, 3) It is a bit heavy for me to carry and any momentum that builds up when carrying/swinging it can pull me over pretty easily so I carry it with a careful lift.
<p>Then maybe better with a carry on luggage with pull out handle and wheels :)</p>
<p>I thought I was the only one who felt like this I also drink whiskey, scotch, cognac, and usually I have to bring my own bottle places but don't like drinking out of plastic cups or not having drinks to mix or chase. Thanks for this I will be attempting this myself. Nice job </p>
<p>Funny and useful ! </p>
<p>Wow, that's a great build. Impressive work. Nice detailed instructable with great photos, material list, and step-by-step instructions. Nice use of laser cut pieces! Great work!</p>
awesome
This is amazing! I concur with asandoval7
I will for sure be telling my mom about this she will use it a lot!!!!!!!
This is brilliant, so so classy!
Thanks a million pounds a bit like that and it will take a while now available on this product out the new one for me is a great deal on a daily rate for this transaction is an automated response free of viruses as the one you want a copy for the use the information in it to you soon
Very cool little drinking travel kit! Might need to add something to my site about drinking games www.halfnakeddrinkinggames.com.
This is very cool! I might need to add something to my &lt;a href=&quot;http://www.halfnakeddrinkinggames.com&quot; alt=&quot;Half Naked Drinking Games&quot;&gt;website about drinking games.&lt;/a&gt;
That's cool I might make one for my dad
I hope you win! Good luck.
Ahhhhhh beyond cool. Now to incorporate a record player or an app that notifies your friends of the location of the suitcase bar when its opened.
QR code with the 'subscribe' link stuck on the side of the case.
Thanks! I need to become friends with someone who owns a suitcase record player and we will be a traveling party duo! Wherever we are there will be a party. ;)
Will carry one with me in my travel car. Thank you. <br>http://shanaihaku.naturum.ne.jp/e1554121.html
<u><strong>WOW<br> what a good job !!! </strong></u>
I just saw this idea today selling at World Market. Original price was $600+, marked down to $350. So to make this yourself is a HUGE savings and a very cool item to have. Thanks for posting it. Here's the world market link where they're selling one: <br> <br>http://www.worldmarket.com/product/clyde-steamer-trunk-bar.do?&amp;from=fn
you are my idol!!
very good good job
Congratulations on being a winner in the digital fabrication contest!
Thanks! I wish I had won the CNC router but I'm sure I can do lots of fun things with the goodies at Inventables.
Congratulations on being a finalist in the be prepare contest! (Look at you go ya little contest ninja!)
Beautiful and practical. I love this!
Thank you!
Now it just needs a Fuller Brushes advertising logo on the outside of the case. Awesome.
http://www.instructables.com/id/Suitcase-Picnic-Table-and-Speaker-System/ <br> <br>this travel bar reminds me of this other instructable that made a picnic table out of a suitcase. couple the travel bar with this picnic table and you can have a good party anywhere. I could also use this set up for organizing all of my gadgets too. add some foam to protect everything.
I love this, especially all your finishing touches. It has given me a great idea for my sewing machine and all it's paraphernalia. Think I'd rather a bar though...
Making a beautiful compartmental box exactly to fit your sewing machine parts would be awesome, too. Maybe add a compartment or two to your sewing box to hold a few bar-like items. ;)
Ingenious! Love the idea of a bar &quot;to go&quot;!
Thank you! You have everything you need all tidy and in one place. :)
My wife loves a classic Manhattan!
About This Instructable
394,613views
1,766favorites
License:
Bio: I'm a visual artist and fashion designer. I make pretty things. I post pictures of what I make on my website: http://theantibromide.com
More by antibromide:The Makeup Box Zebra Cookie Cake Christmas Cookie Forest
Add instructable to:
