3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Travel Jar Water Pump
I will describe how to build a small motored water pump with a travel jar instead of the accepted bottle cap method. This will bring a number of benefits, including easy accessibility for repairs and adjustments of the internal fan. It's relatively cheap, functions well with vinyl tubing and, err... looks great.
Step 1Materials
Materials
Materials need:
-Travel Jar of your choice of color (Bought @Walmart)
- 3v to 5v dc motor from disk drive, radio shack, hobby lobby, electric sharpener, toy, etc.
    -make sure it has a gear
- glue gun
- 3 to 5 v dc output adapter such as a cell phone charger.
- plastic strips for building a fan rotor.
- Tubes for water inlet and outlet, i.e. from a pen.
Drilling/cutting tools for plastic:
- drill (or some other sharp metallic tube)
- micro torch or other heat source
- scissors
18 comments
Jan 6, 2012. 4:01 AMkushalverma says:
what basically WD-40 is??? Is it a liquid spray or something like gel?????
Jan 2, 2012. 8:07 AMkushalverma says:
but how have you applied any solvent or anything between the motor shaft and blades to make it leakprofed????
Dec 21, 2011. 5:42 AMkushalverma says:
is the shaft of the motor leak proofed with the moving blades?????
Aug 19, 2011. 7:10 AMembochner says:
great stuff- is there a way to waterproof the motor to make it splash safe?
Dec 22, 2011. 3:48 PMheathbar64 says:
I once took a hobby mootor and sealed the vents with glue and ran it completely under water. it sat there and ran perfectly in a jar of water.
Aug 19, 2011. 10:24 AMJimmy Proton says:
You could just cover it in hot glue as long as you don't get any inside.
Aug 25, 2011. 1:08 AMtzq33tdq says:
can you send me a link to print this instructable out???
Aug 19, 2011. 11:23 AMKevinAlien26 says:
Hey man great 'ible I was helping my girlfriends mom with transferring gas from her transmission broken truck to her out of gas van and it got to thinking of ways I could pump water. (I wouldn't risk has since there can always be a problem with electricity).
I had a few questions.
1) can this be done using a larger jar Mainly to fit a larger motor and fan.
2) if so could I just use the fan blades off an old computer fan?
Aug 21, 2011. 9:48 AMngunarathne says:
You could pump petrol with it without the risk of fire if you immerse the whole thing in some sort of insulating oil (like baby oil) and draw out just the two lines.
Aug 21, 2011. 4:52 PMKevinAlien26 says:
Hmm sounds like a good idea. I was also thinking if using the motor farther from the actual chamber would work. Like adding a thing metal rod from the fan inside the pump, to the motor some few feet away.
Aug 21, 2011. 10:52 AMngunarathne says:
There's this awesome cog wheel in diskus inhalers ( http://www.google.lk/imgres?q=diskus+inhaler&um=1&hl=en&biw=1280&bih=629&tbm=isch&tbnid=7nIIqMnzDhQgPM:&imgrefurl=http://www.securingpharma.com/40/articles/527.php&docid=Pv-Ayh18LJuO0M&w=596&h=400&ei=z0RRTsnyBMzMrQfY7KyJDw&zoom=1 ) that you can use as the turbine for this. I'll upload an image later if I find time.
Aug 19, 2011. 7:53 AMafetic says:
For what i can use this ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:Pyrophoric
Carbon-based bipedal life form who thinks digital watches are a neat idea.
