iImage Information
I have been looking to make a travel sized watercolor palette for when I am on vacation or out and just want to paint. I have found that this is an extremely effective palette, and also extremely affordable. I bought it at the dollar store so it was only $1 but if you have one laying around at home, that is even better because it is free. I also like it because it is about the same size as an ipod, in all dimensions. A GREAT piece to add to a portable kit!
Step 1Remove Eye Shadow
iImage Information
After you take it out of the package, remove the eye shadow. I used a knife to get under the corner of the eye shadow, and this particular eye shadow box had the makeup in a little tin, so it came out effortlessly. Also, make sure to remove any adhesive that is under the tin. Be sure to wash it out clean to remove any debris.
I would suggest several tweaks:
First, see if any eyeshadow-wearing humans you know have old compacts they should be replacing, thus making this project more green. (Reduce, Reuse, Recycle and all that.) (One should get rid of old eye makeup fairly often for health reasons.)
Second, paint the lid a medium grey to make a more neutral and thus better mixing surface than white.
For acrylics, try using a wet sponge under a bit of blotting paper to keep them from drying out. The paints sit right on the paper. Make sure to create a good seal for the lid, you could probably do so with some silicone caulking and petroleum jelly. And keep that paper damp or it'll all dry out. (Now that I think of this, this is probably a better idea for an altoid tin than an eye shadow compact)
(Probably don't do this with oil paints. They can have toxic qualities, from the solvents to some pigments.)
Acrylics dry far too fast.
watercolors are the only re-activatable (new word!) art medium there is.
1. Acquire a bead organizer box (plastic box with many small compartments and a hinged lid.).
2. Cut a terry cloth towel (or other absorbent material) to be slightly larger than the box's lid.
3. Fill the compartments with acrylic paint.
4. Moisten the towel, lay it over the top (let the excess hang over the sides) and firmly shut the lid.
5. Use the lid as a pallet when you are painting, wash it after use.
6. Always keep the towel moist and wash out the entire box when you will not be using it for an extended period of time.
For an even more travel friendly pallet, use a pill organizer.
Maybe I'll make an instructable for this when I get the chance!
There's a really great forum for artists at www.wetcanvas.com artists of all mediums and skill levels share experiences and knowledge, I think this idea would be a big hit in the watercolor section
i work in all sorts of mediums, but recently really started enjoying watercolor.
i made an account on wetcanvas...waiting for it to get activated, THANKS!
when i went to the dollar store, i was honestly just trying to find some kind of divider to make a portable pallet out of an altoids can like everyone else had done...then i saw this and thought that it was perfect
