Treasure Chest Coffee Table
17,376
274
12
Published
Introduction: Treasure Chest Coffee Table
Refinished old chest.
Step 1:
I have had  this old trunk for as long as I can remember. It was corroded, dirty and somebody had used it to paint a project on it long before it was handed down to me. It even sat for years in a damp basement and stored scrap project wood.
Then for some reason I decided to pull it out one day... I have had this ugly thing sitting around in my living room as a coffee table through two different moves now.
It's time to restore it.
Step 2:
I had been wanting to attach feet to this chest for a long while. Back in my old house I had hardwood floors and the brass on this chest used to drag a little and leave scratches behind.
Browsing through Lowes one day I happened upon these wooden replacement furniture legs. Since these legs have a piece of threaded rod in them, I drilled out a hole in each corner of the chest to sink this rod into. I then drilled  three (3) holes from the inside of the bottom of the chest to attach the feet with deck screws.
Step 3:
There was old paint on the top of the the box that I soaked off with a gel paint stripper.
Step 4:
Next I sanded the top of the box.
I used an electric sander for the larger areas and hand sanded the edges and smaller surfaces. The biggest thing with sanding is to make sure everything looks even, especially since this wood will be stained.
Step 5:
The next step was to test the removal of the tarnish from the brass. I then coated the top of the box with a red mahogany stain. More on these two (2) steps in a moment.
By this point I was really only testing how the look of how this project might turn out.
The results were pretty good..
Step 6:
Time to get serious.
First, clean all of the brass. If you accidentally hit the wood with one of the brushes, it's pretty easy to sand over and fix.
For the brass I wanted a brushed look, something with some texture and a bit of character. To achieve this I bought the two (2) brass brushes shown.
The flat brush is works well to clean around the brass screws, while the other brush was used to clean all of the flat brass strips and achieve that lapped brush look.
** When working with brass, be sure to buy brass brushes! Otherwise you may leave silver streaks behind on your project with a steel brush.
Step 7:
Second Step; Sand Sand Sand.
After the brass is cleaned, go ahead and sand all of the wooden surfaces of the chest.
*​I guess I should also mention that I pulled all of the old, corroded, brass screws out of the wooden areas before sanding. I then cleaned the screws with sand paper before reinstalling them and before coating the chest with polyurethane.*
Step 8:
Third Step; Stain the wood.
After sanding, stain the wood with one light coat of the stain of your choice. For my project I choose a red mahogany.
The stain will need to dry for a few days until it is no longer tacky.
Step 9:
Fourth step; Polyurethane finish.
After the stain has thoroughly dried apply two (2) coats of Polyurethane to all surfaces, including the brass.
** Be sure to apply the coats thinly as any runs will be visible in the final product.
As you can see, I removed the lid to make finishing all of the surfaces a bit easier. This also ensured that I did not accidentally Polyurethane over the hinges, as this would make them stiff.
Step 10:
Reattach the lid and replace the old, rusted handles.
Finished project; One beautiful, functional, Treasure Chest Coffee Table.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    12 Comments
    Thank you guys for all of the views and kind words =)
    Please take a moment and vote for me in the Woodworking Contest if you like this project.
    Thanks!
    Nice work. I'd add casters to the legs and exchange the weak hinges with stronger ones.
    I have some heavy casters, but I wanted something more aesthetically pleasing. Those brass hinges will surprise you, they are very old and fairly thick for their small surface area. Recessed into the wood, they should have no problems.
    This is gorgeous. Thank you so much for sharing your hard work and . . . keep on shining!
    sunshiine
    Great work. For obvious reasons I'm a huge fan of trunk restorations. It's too bad you couldn't recover the old handles, but I've found they usually bear the brunt of the wear and often need replacing.
    Unfortunately the handles on this trunk were not worth salvaging. They didn't match and one was almost rotted through with rust =\ Its actually quite heavy even empty, so I wanted to make sure I had something that could handle the weight.
    Beautiful!!
