loading
This project is currently being used for a middle school intro to engineering program. This project is pretty simple to build and just about any home improvement store will have the supplies.
The kids are given the materials and the trebuchet drawing (see link in description). It takes the average group (2 to 5 kids) about 10 minutes to assembly the trebuchet. There are two variables in the setup. The first is the launching arm – three choices are available: short, medium and long. The other variable is the height of the weight. This is controlled by the distance on the ruler attached on the board at the base of the trebuchet. Data is collected for the three arm lengths across the weight height range (see link to spreadsheet). After the data is collected, a competition is held to hit a target (bucket, 20 feet away).
Although modified for the class requirements, this is not an original design. It was reversed engineered from a combination of the versions you will see online.
See video for actual build.
Step 1: Materials, Tools and Notes
Materials:
  • PVC Pipe, 1/2” diameter x 30” Long (x2)
  • PVC Pipe, 1/2” diameter x 17” Long (x4)
  • PVC Pipe, 1/2” diameter x 4” Long (x3)
  • PVC Pipe, 1/2” diameter x 3” Long (x4)
  • PVC Pipe, 1/2” diameter x 1.5” Long (x12)
  • PVC Pipe, 3/4” diameter x 17” Long
  • PVC Pipe, 3/4” diameter x 8” Long
  • PVC Pipe, 3/4” diameter x 6” Long
  • PVC Pipe, 3/4” diameter x 4.5” Long
  • PVC Pipe, 3/4” diameter x 1.5” Long
  • PVC Elbow, 1/2”, 45 degree, Female Unthreaded Socket Ends (x8)
  • PVC Tee, 1/2”, Female Unthreaded Socket Ends (x10)
  • PVC Tee, 3/4”, Female Unthreaded Socket Ends
  • PVC Cross, 3/4”, Female Unthreaded Socket Ends
  • PVC Adapter, 3/4”, Unthreaded & Female thread
  • PVC Adapter, 3/4”, Unthreaded & Male thread (x3)
  • PVC Cap, 1/2”, Female Unthreaded Socket End (x4)
  • PVC Cap, 3/4”, Female Unthreaded Socket End (x3)
  • PVC Glue/Cement
  • Pin or nail – 1/8” diameter x ¾” long
  • Epoxy
  • Wood – 30” x 4.75” x 5/8”
  • Paper Ruler – 30” long
  • Clear Packing Tape
  • 5lb weight
  • Rope (30”)
  • Rubber squishy ball
  • Fishing line - 26” long
Tools:
  • Saw
  • Drill
  • Ruler
Notes:
Refer to the drawing for build instructions (last step). Note that Upper and Lower frame joints (items 1 and 2) are shown as assemblies on the drawing. This is an optional step which was done to speed up the build process for classes that had limited time. Both of these assemblies were glued together. The launching arm assembly must be glued together to support the weight and swinging motion.
Step 2:
Cut PVC pipe to the lengths shown in materials list
Step 3:
Assembly the lower frames assemblies
Step 4:
Connect assemblies together with 30” pipe
Step 5:
Add the 17” pipes off the 45 degree fittings
Step 6:
Attach the upper frame assemblies to the upper sides of the pipe
Step 7:
Feed the 4” pipe through the launching arm between the two upper frame assemblies
Step 8:
Tie the 5lb weight to the launcher arm
Step 9:
Cut a piece of wood 30” x 4.75”. Thickness doesn't matter (.25” to .75” will work). Find or print out a ruler and attach it to the wood. This version was printed and covered with clear packing tape.
Step 10:
Drill a hole in the ¾” end caps. Pre-bend a pin (nail) to a 60 degree angle. Place pin in the hole and use epoxy to secure the pin to the cap.
Step 11:
As mentioned above, the arm length can be adjusted by swapping out the launcher end caps (short, medium and long). Make sure pin is facing forward.
Step 12:
Cut a piece of fishing line to 26” long. Tie knots on one side of the line. Drill or poke a small hole through the diameter of the squishy ball (slightly bigger than the fishing line). Feed the straight end of the fishing line through the ball. Tie a 1” diameter loop on the other end of the line.
Step 13:
Cock trebuchet by pulling the ball back along the board. Record the cocking distance on the data sheet. The ball should fly up to 50 feet.
<p>That helped me non. I have to do a school project and I don't even know how to put this monster together!</p>
<p>I found that 4 inches for the cross beam was not enough, so I had to use a 5.5 in. Not yet certain if necessary to widen the base structure similarly.</p>
How would i go about converting this to a cup style launching system?
<p>Although common for catapults, cup style launching systems are not typically used for trebuchets. The payload is generally carried in a pouch (google trebuchet components) attached by a rope. We tried this technique but it was not consistent enough for rambunctious middle school kids. </p>
OK, thanks
<p>If i double the diameter alone of the pvc in all portions will it work? If so if i double the length of the pvc and keep the diameter the same will it work? And if i double both the diameter and the length of the pvc beefing the scale up by 100% will it work? With the first 2 questions, will either of the changes if they work will it effect the distance the projectile will travel? </p>
<p>As a general rule of thumb, when a 3D object is scaled up to a larger size, the size of load bearing components, such as the PVC struts, should be increased exponentially. That's why the giant insects in the old movies (see: <em><a href="https://www.pinterest.com/entophile/bug-movies/" rel="nofollow">https://www.pinterest.com/entophile/bug-movies/</a></em> ) couldn't exist. They'd need elephant-like legs just to support their body weight.</p><p>So, if a 3/4&quot; pipe is made twice as long, the new diameter should nominally be 4 times the original, or 3&quot;. If the length is tripled, then 9 times the diameter is needed for the equivalent strength. Given that the load/stress for the trebuchet won't be anywhere near the load limit of the original 3/4&quot; pipe, a 1&quot; or 1.5&quot; the pipe will be fine, and the 3/4&quot; pipe will probably still be adequate at twice the length.</p>
<p>1st question: Yes, it will work. Not needed though - 1/2&quot; diameter is strong enough.</p><p>2nd question: It would most likely fail due to the longer runs of 1/2&quot; pipe (not strong enough)</p><p>3rd question: I think it would work fine if you scaled both. I would actually like to see a scaled up version with 1.5&quot; pipe. Maybe you could launch a soccer ball or something.</p><p>4th question: I don't think the first option would help much - might even slow it down. The second option would probably break. </p>
<p>Also one more question how did you set up the ball and would a mechanism to launch the ball like the one shown on <a href="http://www.fvdes.com/sites/default/files/events/Trebuchet%20Build%20Instructions.pdf" rel="nofollow">http://www.fvdes.com/sites/default/files/events/Tr...</a> &lt;- that project it is on the 6th page of the pdf would that launching mechanism work with this project?</p>
<p>A sling is the most common approach - goes back over 1000 years. It will work but it requires some trial and error to get it totally worked out. We simplified the projectile since we are working with rambunctious middle school kids. We also needed a soft projectile for safety reasons. My co-worker came up with the squishy ball and fishing line (step 12). The ball launches every time without adjustments. I suggest you try both approaches and see which one works better for you.</p>
<p>Because if i am correct that project they did on that pdf is almost identical to yours @mtairymd</p>
<p>I was waiting for the first trebuchet in the contest, nice work ;) To add more stiffness to the launching pole you can glue a smaller pipe inside, or a wooden pole. What about the range? Tested?</p>
<p>Adding more mass to the pole reduces the transfer of momentum to the item being tossed due to the increase of inertia. It is best if the parts of the trebuchet all have the lowest mass possible except for the weight, especially as they are get farther from the pivot.</p>
<p>Thank you. We don't seem to have much bending in the launching arm. As for range, it sends the ball about 45 feet. As part of the project, we roll out a 50 foot ruler on the ground. See excel spreadsheet for test data. </p><p><a href="https://googledrive.com/host/0B21TbB8gGNQbLXMydVlYbVBWeXM/trebuchet.xlsx" rel="nofollow">https://googledrive.com/host/0B21TbB8gGNQbLXMydVlY...</a></p>
If u put it on wheels u could get up to 20% more power
<p>good</p>
<p>good</p>
About This Instructable
30,157views
320favorites
License:
Bio: I like to design and build random things.
More by mtairymd:Math Snake Puzzle Rope Puzzle Succulent Planter From Pallets
Add instructable to:
