Trebuchet business card - Trebucard by clide
Featured
The Trebucard is a business card sized mini trebuchet. It is designed to fire jumbo paper clips and uses 16 pennies as a counter-weight. Unlike a traditional trebuchet the Trebucard uses the surface it is resting on as a pivot rather than being mounted on a frame.
See a demonstration of the card here:
And here is a video that shows you how to make your own:
Step 1: Download the design files
Download the design files for the card in whatever format is easiest for you to work with.
If you have any problems with the Instructables attachments the files are also available here: http://www.thingiverse.com/thing:16735
prushik says: Mar 2, 2012. 6:17 AM
I was not real impressed.. Until he started consistently hitting that cup from so far away, that was crazy and awesome!! Once I saw that, I was thoroughly impressed, this is about as cool as the iris business card, this even has practical applications (if you define "practical" very loosely)
clide (author) says: Mar 2, 2012. 8:43 AM
For the sake of full disclosure I was probably only hitting about 1/3 of the shots out there (or less), and I'm not really sure what all was throwing it off. I think it was largely the wind. In a more controlled environment with smooth concrete floors and no wind I was hitting 80-90%
prushik says: Apr 6, 2012. 7:05 PM
Well, of course wind is going to throw it off, that has to be expected, however, its still incredibly accurate. I am quite impressed.
Most of the applications I can think of are indoors anyway (sinking paperclips in your boss's coffee).
justindouthat says: Mar 20, 2012. 8:06 AM
i made one :)
Dream Dragon says: Mar 6, 2012. 8:06 AM
Excellent Project (voted), and well documented too.
A couple of rules of fun, sorry THUMB!
In a conventional trebuchet, The Counterweight should be about 100 times the weight of the Projectile, the Arm should balance at the pivot when not loaded, and the pivot point is about 1/4 of the length from the counterweight end. Maximum efficiency is achieved if the weight is permitted to fall in a straight line.
Not sure how that might translate to your rocker design but I'd like to see some variations. Let's see if I can find some heavy Card...
clide (author) says: Mar 6, 2012. 10:25 AM
Thanks, I'd like to see some variations and optimization as well.
From my experimentation one of the important things about this rocking design is to have the CG of the counterweight as close as you can get it to the edge of the rocker so that it is as close as possible to the ground as the projectile is launched. I do have a variation which is more optimized in this regard.
Also a grippy surface without any slipping will help performance. Which seems to deviate a bit from that straight line principle in conventional trebuchets. But if you think about it, it makes sense because with the way the card rocks the counterweight's speed relative to the ground will be slowest as it reaches the lowest point. In the ideal scenario where the counterweight is at the very end of the trebuchet and in contact with the ground with no slippage at the time of launch then the speed of the counterweight relative to the ground would be zero which is exactly what you want. Although unless you have an infinitely dense material you will always have some speed relative to the ground and some angular momentum that won't be fully used.
But I do think you could get some pretty good efficiency out of this design with a dense counterweight and making the rest of the device as light as possible. One bad thing is that it doesn't scale well. Anything beyond what one or two people could lift would have to have a big frame to lift and support it for launching. But I've been thinking about trying to scale it up to golfball size projectiles and seeing how well it works on a medium scale.
HelenaTroy says: Mar 2, 2012. 8:07 AM
for those of us who don't have (assuming!) US pennies, how much should the counterweight weigh, please?
clide (author) says: Mar 2, 2012. 8:22 AM
Mine weighs in at about 42 grams.
HelenaTroy says: Mar 2, 2012. 10:20 AM
thanks, dear!
Kiteman says: Feb 28, 2012. 10:03 AM
That is great - such a simple concept, yet so efficient!
clide (author) says: Feb 28, 2012. 11:51 AM
Thanks Kiteman. I actually did a rough calculation of the mechanical efficiency and came up with 45% which isn't bad considering there are many things that could be done to optimize it's performance (at the cost of being harder to make/use and less durability).
For comparison the Cardapult V2 launches the same size paper clip about the same distance, but requires about 3x the energy input.
Ketzer says: Mar 2, 2012. 7:24 AM
What kind of changes? Altering the curves?
clide (author) says: Mar 2, 2012. 8:36 AM
That's one thing that could be looked at, as well as the overall length of the card. If I was going for maximum efficiency the main things I would go for would be moving the counterweight as close to the outside edge as possible (which may also include using a denser counterweight). And minimizing the weight and air resistance of the rest of the device especially as you get more towards the projectile end because it will be moving the fastest on that end. Also a proper sling might help, but it's hard to do on this scale.
Kiteman says: Feb 28, 2012. 12:08 PM
Cool.
giddy_yup says: Mar 1, 2012. 8:59 PM
You, sir, are awesome! :) Voted!
gverble says: Mar 1, 2012. 5:17 PM
I am not an old fuddy duddy, but I don't understand the purpose of this item, nor have I ever heard of such a thing, but it was a well presented instructable, so I voted for you. ☺
clide (author) says: Mar 1, 2012. 7:07 PM
A trebuchet is an old siege engine that was used to hurl large rocks into castle walls. These days it serves no purpose other than being a fun way to make stuff fly through the air.
It can also be useful for demonstrating principles of physics like conservation of energy. The energy from dropping the relatively heavy weight of the pennies a few inches is used to launch the lighter projectile several feet.
This is just a scaled down and highly simplified version.
Thanks for the vote.
building king says: Mar 1, 2012. 1:59 PM
Such a great idea! Voted!
clide (author) says: Mar 1, 2012. 3:34 PM
Thanks for the vote!
GASSYPOOTS says: Feb 29, 2012. 4:22 PM
how open .cds and .svg
clide (author) says: Mar 1, 2012. 12:35 PM
They are all the same file in different formats, so if you can open the PDF it's the same thing.
Although svg is probably a bit easier to edit if you need to make changes and works with the free program 'Inkscape'
sitearm says: Mar 1, 2012. 11:19 AM
@Clide; Tweeted! Cheers : ) Site
a918bmxr says: Mar 1, 2012. 9:56 AM
:O
builderv says: Mar 1, 2012. 7:20 AM
this is awesome i love all of your clide cards i will be making it today thumbs up good job
Dangertoys says: Mar 1, 2012. 6:47 AM
Ha! What a great idea!
And what a great idea to promote a company.
I hope you don't mind if I use it to make my own?
Thanks a lot, I think this is wonderful.
I will now have to go and have a look what else you posted. It is always a pleasure to see somebody being creative.
mitch and sean says: Feb 29, 2012. 12:22 PM
Thnx so much
I've been waiting so long for another Clide Card, and here one is :)
artworker says: Feb 28, 2012. 8:44 PM
Super cool man! The distance travelled by the clips amuse me!
hardj009 says: Feb 28, 2012. 1:20 PM
these are amazing had so much fun at school playing with them
dombeef says: Feb 27, 2012. 6:13 PM
Wow, once again you amaze me!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
