Trebuchet business card - Trebucard
 by clide
Featured
Step 9: Fire the trebucard
With the large loop of the paper clip propped up in the air you want to insert the small tab at the end of the card into the top loop of the paper clip. Be sure the loop is tight up against the tab on the card, then you simply allow it to rock forward and throw the paperclip. It should shoot somewhere around 8-10 feet.
A grippy rubber surface provides the best performance, but it can also be more temperamental to fire on such a surface.
You can adjust the loop on the paper clip (or the shape of the tab on the card ) and make it smaller or larger to alter the trajectory of the trebuchet.
A more detailed video of the operation of this card can be found here:
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
