Tree Branch Key Holder
1,017
20
6
Published
Introduction: Tree Branch Key Holder
About: DIY projects created by 7th and 8th graders as part of their Computer Technology Education class. Follow Us on Twitter @DISdemonsphysed. An opportunity for students to share their independent and collaborat...
Learn how to make a Key Holder made from a tree branch. Repurpose that tree branch that is keeping leaves on the tree in your yard. Reuse that tree branch that was knocked down to the ground from the last wind storm.
Learn how to do some simple wood burning in your kitchen over the open fire of your range top.
Are you sick of losing your keys when you need them? Well, if you are then make this key holder and you will never lose your keys. This key holder is made out of branches and twigs so it’s easy to make.
YADI
The DIS Demon making machine just keeps crunching out great Instructables. Follow MyWlakeTech for more to come.
Step 1: Supplies and Tools
  • 4 Small twigs (with hooks on the ends)
    • Hooks = other twig shoots.
  • 1 thick branch
Tools
  • Wood saw
  • Safety gloves
  • Fine and coarse sandpaper
  • Drill
  • Drill bit (the same diameter as the small twigs)
  • Pair of pliers
  • Piece of thick wire (wire hanger or 10 gauge wire will work)
  • Wood glue
  • Varnish
  • Open Fire (used for wood burning method)
Step 2: Cut Thick Branch
Cut the thick branch to your desired length (about 6 inches). Then make the 4 twigs the same length with their hooks on one end.
Step 3: Sandpaper
Rub the branch with the coarse sandpaper and then use the fine sandpaper to make it smooth.
The rough course sandpaper is used to clean or remove the desired amount of bark from branch. The finer sandpaper is used to give a nice smooth finish.
Step 4: Carve and Whittle
Using a cutter knife or favorite whittling knife , carve a flat area which will be the front area of the key holder.
Step 5: Open Fire Wood Burning
Wearing safety gloves and using a pair of pliers, heat the thick wire over a flame until it is red hot. Once it is red hot, using the wire to burn into the wood any words that you like. I used the word “KEYS”. (It is also a good idea to write the word in pencil on the wood as a guide before you start burning)
Step 6: Drill Twig Holes
Wearing safety gloves, use the drill to drill four holes in the the thick branch. The holes must be on the underside of the word at the front of the branch. This is where the four twigs will go. You can use your hands if the wood is soft enough.
Step 7: Twig Prep
Prepare the 4 twigs so they are smooth and so they fit into the drilled hole. Whittle away bark and shape ends to size.
Step 8: Glue
After checking that all four twigs fit into the holes in the thick branch, put some wood glue in each of the holes and push the four twigs into them. (It doesn’t matter if some glue comes out of the holes when you push the twigs in because you can clean it off when it is dry.) Make sure the hooks on the twigs are facing the front of the thick branch where the word is. Next you need to set it in a position to allow it to dry for 24 hours.
Step 9: Varnish
Apply a clear varnish with a clean towel or non-lint rag to the key holder to protect the wood. Use gloves to protect your hands from the varnish. Allow it to dry for 12 hours.
Step 10: Mounting Hooks
Using small screws and wall hanging hooks screw the hooks into the back of the key holder. Be sure to place the hooks at the same height on the back of the key holder so that it hangs evenly on the wall when finished.
Step 11: Summary
I think this is cool because it is using a natural branches/twigs. Make sure that you are wearing the gloves and goggles for safety when using cutter knife and a saw. If you are a kids like me, be sure to have adult supervision when cutting and burning the wood.
YADI
Follow Us on Twitter!
Made by DIS Maker
mu600247
Fire Challenge 2017
Runner Up in the
Fire Challenge 2017
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    All of us at MyWlakeTech appreciate all the votes.
    Wow, great idea! I love the letter burning idea! And great easy-to-understand instructions too! Nice job!
    Clever method to woodburning.
    Love the use of the "Old School" saw!!!
