3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tree Climbing Robot
Tree Climbing Robot
After I got comfortable programming and building with an Arduino, I decided to build a robot.  I did not have any particular type in mind, so I wracked my brain (and the internet) for cool robot ideas.  Eventually, somehow the idea popped into my head to build a robot that could climb trees.  At first I dismissed the idea as beyond my skill level, but after further thought, and some time in Sketchup, I decided to take a shot at the challenge.  This is the result of my efforts.
Step 1Design
Design
I started out by creating a basic design in Sketchup.  The robot was to consist of two segments, joined by a spine which could be extended or retracted.  Each segment would have four legs with very sharp points as feet.  To climb, the legs on the top segment would pinch together and the sharp feet would dig into the bark, securing the robot.  Then the spine would be retracted, pulling up the bottom segment.  The legs on the bottom segment would then grip the tree, and the top segment would release.  Finally, the spine would extend, pushing the top segment upwards, and the process would repeat.  The climbing sequence is somewhat similar to the way an inchworm climbs.
In my original design (show in the images above), all four legs in each segment were controlled by one highly geared down motor.  I decided to ditch this idea for a few reasons.  Firstly, I could not find the type of spur gear needed to mesh the legs together.  Also, with all the legs linked together, the robot would have a hard time gripping uneven surfaces.  Finally, I decided that the robot would be much easier to build if the motors drove the legs directly.
The other significant change I made from my original design was the way the spine worked.  In my model, I used a rack and pinion type gearing system to extend and contract the spine.  However, I could not find the necessary parts to build such a system, so I ended up using a threaded rod  coupled to a motor to actuate the spine.
43 comments
1-40 of 43next »
Apr 10, 2012. 5:48 PMraykholo says:
I'm going to build a much larger scale version of this to climb a tree of much bigger diameter. I will have it haul up a throw line [pun intended] as it goes, have a servo arm deploy it in a crotch (where branch meets trunk), and then the robot can lower it (and possibly self-rappel down that line). I will then use the throw line to anchor a friction saver so that I climb the tree myself.
At least, so I plan.  I'll CAD it in Autodesk Inventor and see where that goes.
Great Instructable!
Apr 9, 2012. 12:52 AMgoldenshuttle says:
if anyone wants 2 sell; I will buy a pre-programmed PIC that controls 3 servo's giving them random or psuedo-random movement. speed can be slow since i am planning to use it in a prop. if anyone willing to sell this i need 5 pcs of the same. i will pay thru paypal. some people do not trust overseas buyes, so 2 make u feel safe, u can list it on EBAY and I will buy it thru EBAY, which will guaratntee u get payed. More orders I would place if 1st order went well...I am a serious prop maker and look forward to source my needs thru this website while I concentrate on the mechanical aspects of my props. I m not offering to sell my props or anythng on the website, just buy parts.....please advise if anyone interested to sell. Thanks
Mar 26, 2012. 3:59 PMGENERALCHAOS says:
u can use transistors to control the L298HN like the L293D ?
Mar 26, 2012. 5:31 PMGENERALCHAOS says:
i was asking can it work im making a EAGLE PCB atm i have it done on the proto but i messed it up wired it wrong i have 3 and 1 is im use to control two Honda AC cooler door servos for a solar sun tracking
Mar 26, 2012. 6:18 PMGENERALCHAOS says:
it feels saver with the resistor controlling the 5 volts to CHIP KIT MAX32 the 5 volt gonna be regulated to power the chip kit and the transistor im just wanted to set it up like it make me feel saver theres another 1 to it a 2 pin and leave me with extra pin to control more stuff if u nee to
Dec 26, 2011. 5:03 AMjalalshajahan says:
well done good innovation
Aug 30, 2011. 8:24 AMKaran.Shah says:
beautiful robot !! I and one of my friend had made a similar project using helical climb mechanism !! it is much easier bt bulkier ......... one recommendation those legs could be attched to the body using brake wire which could be spring loaded such that it can each stay in itz place when no movement is taking place
Nov 1, 2011. 7:42 PMngaikwad says:
HEY KARAN CAN U PLS EMAIL ME UR PROJECT AS I THINK THIS TOPICI IS QUITE SUITABLE FOR ME.. SO WOULD U PLS FORWARD ME THE DETAILS..WAITING FOR UR REPLY MEN...nakuljazz4236@gmail.com
Nov 21, 2011. 6:17 PMblinkyblinky says:
Bicycle brake wire...I think...
Sep 11, 2011. 7:55 PMmarc.cryan says:
Really well done - Can it climb back down?
Aug 31, 2011. 4:53 PMblazinEagle says:
epic!! nice work man!
Aug 26, 2011. 6:13 PMleea9 says:
It seemed like you were waiting for it to fall and catch it.
I wonder if you could test the grip by doing a tug on the just clamped section and measure the current draw or force or something to be sure it is tightly attached. Then you would know it is safe to release the other half and climb.
Aug 26, 2011. 1:20 AMmitch and sean says:
Way to cool man
Aug 25, 2011. 10:35 PMdreadengineer says:
That's a pretty clever setup-- the long pen allows some side-to-side movement during rotation, so the mounting doesn't have to be perfect.
Aug 25, 2011. 1:03 PMRudo says:
What a fantastic project! Perhaps way down the road to extend the idea to a tree trimmer that could trim tree branches at the tops of trees in urban areas to reduce the amount of 'sail' to prevent trees from falling and prevent considerable property damage? Keep honing your considerable skills.
Aug 25, 2011. 7:09 AMMikey_Likes_It says:
Excellent project indeed. As an engineer myself, I can appreciate the not only the project you tackled, but also how comprehensively you documented the build process. Keep doing what you’re doing, I have a feeling that one day engineering might be paying your bills, if it isn’t already.
Aug 25, 2011. 8:09 AMdrhulsey says:
Don't forget McMaster-Carr for gears, including rack and pinion:
http://www.mcmaster.com/#gears/=drutfr
Aug 25, 2011. 11:27 AMHonus says:
That's really cool! If you do ever want to do a rack and pinion setup Servocity sells cheap nylon gear racks and servo mount gears- I use a similar setup with a low profile linear slide for making animatronic Predator gauntlet blades.
Aug 25, 2011. 9:57 AMrimar2000 says:
VOTED!
Aug 25, 2011. 7:15 AMRe-design says:
A most excellent project. Great design, implementation and documentation.
Aug 22, 2011. 11:14 AMLorddrake says:
AWESOME JOB!! ... now i just need to talk you into making one strong enough to attach a tree stand to :)
Aug 24, 2011. 1:01 AM0087adam says:
rofl why, is a climber stand too much for you?
Aug 24, 2011. 4:11 AMLorddrake says:
naaaah ... i just wanna be the first kid on my block with the tree stand that climbs up the tree for me hehehe
on top of that i get to pretend i'm running my own elevator ...
first floor rabbits and chipmunks *ding*
second floor squirrels and the neighbor's cat *ding*
top floor deer and moose and bears oh my *ding*
Aug 24, 2011. 12:44 AM0087adam says:
This is the most epic robot ever! Perfect for getting cats out of trees!
Aug 23, 2011. 1:52 PMlazerus says:
Great Job dude, what a great first robot, very impressive.
Aug 22, 2011. 5:13 PMpantalone says:
You da man! This is the best "first robot" project I've ever seen. Great job!
Aug 22, 2011. 3:25 PMjessyratfink says:
How awesome is that? Seriously great work. :D
Aug 22, 2011. 2:06 PMmJusticz says:
Awesome, Excellent project! You've got my vote!
Aug 22, 2011. 1:24 PMbobby sissom says:
i was very impressed ,nice work and got my vote
Aug 22, 2011. 9:50 AMNotquitepinoy says:
cool robot... put a tail on it and then it can live in the trees with the squirrels... nice job
Aug 21, 2011. 9:24 PMookid says:
That my friend is a very well built robot! I like the design and the way you figured out how to tell when the tree is being gripped. I will vote for you in the epilog contest :D
Aug 21, 2011. 6:51 PMsmessud says:
I could not find you in the Epilog contest.
I would gladly vote for you.
Great project and great ible.
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
87
Author:Technochicken(BuildIts)
