Step 16Linear Slides
First, I added a pair of aluminum bars to the segment of the robot without the electronics, to match the pair on the other segment. To mount the steel rods and the brass tubing to these, I made a clamp system similar to the clamps holding the feet in place. To do this for the large diameter rods, I first clamped two 3/4" squares of aluminum together. I then drilled a 1/8" hole down the intersection of the squares, and then took them apart. I drilled two holes in each square, and corresponding holes in each supporting arm. Then I repeated the process four times. To get the slides perfectly parallel to the threaded rod, I had to bend up the supporting arms on the non-electronics segment of the robot.
Add Comment
