3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tree Climbing Robot
Step 3Motor Controller
Motor Controller
  • last photo ←
The motor controller I built for this robot is based off the L298HN Dual Full Bridge chip.  To use the chip, I followed the guide here.  To start out, I placed all the components on a piece of perf board, to figure out the layout.  With this chip, each motor requires three inputs to work:  an enable signal and two input signals.  The enable signal is used to control the motor speed with PWM, but since I did not need to control PWM, I just wired all the enable pins in parallel to a 5V line when I hooked the controller up to the Arduino.  Once I figured out the layout, I soldered all the components in place, and made connections with 22AWG solid core wire.  Finally, I spread some thermal paste on the back of the L298's, and screwed on the heatsinks.  The particular heatsinks I used were made by cutting in half a northbridge heatsink from a computer motherboard, and drilling and tapping a hole for the screw.  They are probably much larger than needed, but there is no harm in having over sized heatsinks.  A higher resolution image of the labeled board can be found here.
When finished, this motor controller should be able to bidirectionally control 4 DC motors at up to 2A each (probably 2A continuously, because of the size of the heatsinks).  As you may notice, this leaves me one motor short.  My original design used a servo to actuate the spine, but I had to change my design to using a DC motor.  To power it, I wired my third L298 chip to a molex connector (so I can disconnect the motor) and soldered on wires for all the connections.  It does not look as pretty as my controller on a circuit board, but it works.
5 comments
Mar 26, 2012. 3:59 PMGENERALCHAOS says:
u can use transistors to control the L298HN like the L293D ?
Mar 26, 2012. 5:31 PMGENERALCHAOS says:
i was asking can it work im making a EAGLE PCB atm i have it done on the proto but i messed it up wired it wrong i have 3 and 1 is im use to control two Honda AC cooler door servos for a solar sun tracking
Mar 26, 2012. 6:18 PMGENERALCHAOS says:
it feels saver with the resistor controlling the 5 volts to CHIP KIT MAX32 the 5 volt gonna be regulated to power the chip kit and the transistor im just wanted to set it up like it make me feel saver theres another 1 to it a 2 pin and leave me with extra pin to control more stuff if u nee to
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
87
Author:Technochicken(BuildIts)
