Materials:
2 x 4
2 x 6
2 x 8
2 x 10
4 x 4
Deck Screws
Pocket Hole Screws
Polyurethane or Polyacrylic to finish
*Do not use pressure treated lumber or cedar.
Recommended Tools:
Circular Saw
Table Saw
Jig Saw
Pocket Hole Jig
Drill
Power Sander
Useful Tools:
Radial Arm or Compound Saw
Dado Blade
Router
Impact Wrench / Driver
Counter-sink Bits
I didn't provide a the number of boards that you'll need, since not all boards are the same. A 8' 2x4 will give you two 3' boards, where you might squeeze four out of a 12 footer. However, when you get to the lumber yard, you might find the 8' boards are in much nicer shape than the 12' ones. It might also be cheaper to buy two 8' boards than a single 16', so I'll leave this to you to decide what to buy based on quality and price available. What type of wood you buy is largely a matter of personal taste. However, I will say do not use pressure treated wood, even if you have a bunch laying around. Most of you know this, but pressure treated wood is pretty toxic. It's toxic to the touch and off gasses into the air. I wouldn't rely on a finish to make it safe either. Just don't use it for this project.
The list of tools is also just just a suggestion, there's many ways to accomplish the same thing. I personally used all the tools I listed. You could probably get away with just circular saw and drill, but I wouldn't recommend it.
Remove these ads by
Signing UpStep 1: Get Your Lumber, Finalize Your Plan
The boards sizes were chosen for aesthetic purposes, not for structural reasons. As designed, it's built like a tank. If you want to go smaller, I don't know what the minimum board size you need is. I suggest looking up deck codes if you want to know this.
Here are the basic steps to start:
1) Decided on the basic dimensions you want for your bed. This one is 86" x 56" x 51 high" Take things like ceiling fans into consideration as you go up.
2) Decide what boards you need to buy. Basic materials used in the plan:
- Posts 4x4s
- Top Rail 2 x 6s
- Balusters, 2x4s
- Decking 2 x 10s
- Fascia / Joist 2 x 8s
- Ladder, 2x4s
3) Buy your lumber.
4) Measure the lumber width and thickness.
5) Modify your plans as needed to account for the lumber's true width. For example, if you expected your 4x4s to be 3 9/16 x 3 9/16, but found out instead they were 3 7/16 by 3 7/16, you'll have to increase the lengths of your joist or decrease the length of the top rails and balusters to accommodate this.
6) Produce your cut list, a list of all the boards, their quantity and dimensions.
Tree House Bed.skp49 KB
Visit Our Store »
Go Pro Today »
So after we build it, we'll need to take it down and put it back up after the engineered hardwood goes in.
Would that change the plan? The hardware? We plan to use whatever we can afford in the Toyota Camry or Honda Accord of hardwoods.
Great idea and a cool hiding place underneath.
